HP Probook 4530s Intel® Core™ i5 2410M, 4GB, 320G,B 15.6", Windows 7 Professional 64-bit
HP ProBook 4530s Notebook PC
Quicklinx: 7JXMWS00 Mfr#: LH282EA#ABU
  • Core i5
  • Microsoft Windows 7 Professional 64-bit Edition
  • IEEE 802.11n
Stylish performance. Watch, present, video conference , and multitask on this durable, stylish notebook. This versatile and secure HP ProBook boasts a 39,6 cm (15.6") diagonal HD monitor to make an impression in and out of the office.
  • Equipped to get the job done
    Gain strong processor capabilities, wireless functionality and a 39,6 cm (15.6") diagonal HD display.
  • Stylish design
    The metallic gray color complements the vertically brushed aluminum finish. Your PC's good looks stand up to the commute between home and work with added aluminum casing.
  • Security beyond passwords
    Secure access to your information, using HP Face Recognition or fingerprint-reading technology, and protect your notebook and the sensitive data it holds with HP ProtectTools (select models).
  • Easily stay productive
    Use HP QuickWeb to access the internet, email, contacts and calendar fast at the touch of a button without long boot-up times.
  • Crystal clear collaboration
    Reduce your communication costs and improve your productivity with HD webcam, for video conferencing, dual array microphones and SRS Premium Sound for better sound quality.
  • The best of both worlds
    With Switchable Graphics, you can get high performance from discrete graphics or the long battery life of integrated graphics in the same notebook.
HP ProBook 4530s - 15.6" - Core i5 2410M - 4 GB RAM - 320 GB HDD
Notebook
Operating System
Win 7 Pro 64-bit
Intel Core i5 (2nd Gen) 2410M / 2.3 GHz (2.9 GHz) / 3 MB Cache
4 GB DDR3
Storage
320 GB HDD / 5400 rpm
Optical Drive
DVD SuperMulti
Display
15.6" LED backlight HD anti-glare 1366 x 768 / HD
Graphics
AMD Radeon HD 6470M
Video Memory
512 MB GDDR5 SDRAM
Numeric Keypad
Integrated Webcam
802.11b/g/n, Bluetooth 2.1 EDR, Bluetooth 3.0 HS, Gigabit Ethernet
6-cell - up to 6.25 hours
37.4 cm x 25.6 cm x 2.9 cm
2.5 kg
Microsoft Office Preloaded
Includes a pre-loaded image of select Microsoft Office 2010 suites. Purchase an Office 2010 Product Key Card or disc to activate preloaded software on this PC.
Environmental Standards
ENERGY STAR Qualified
Limited warranty - 1 year , Limited warranty - battery - 1 year
Notebook
Recommended Use
Small business, corporate business
Operating System
Processor / Chipset
CPU
Max Turbo Speed
2.9 GHz
Number of Cores
Dual-Core
Cache
L3 - 3 MB
64-bit Computing
Chipset
Mobile Intel HM65 Express
Intel Turbo Boost Technology 2.0
RAM
4 GB
Max RAM Supported
8 GB
DDR3 SDRAM
Speed
1333 MHz / PC3-10600
Rated Speed
1333 MHz
SO-DIMM 204-pin
Slots Qty
2
Storage
Main Storage
320 GB HDD SATA 3Gb/s / 5400 rpm
Optical Drive
DVD±RW (±R DL) / DVD-RAM fixed
Read Speed
24x (CD) / 8x (DVD)
Write Speed
24x (CD) / 8x (DVD±R) / 6x (DVD±R DL)
CD / DVD Rewrite Speed
24x (CD) / 6x (DVD-RW) / 8x (DVD+RW) / 5x (DVD-RAM)
Display
15.6"
LCD Backlight Technology
LED backlight
Resolution
1366 x 768 (HD)
Widescreen
Image Aspect Ratio
16:9
HD anti-glare
Audio & Video
Graphics Processor
AMD Radeon HD 6470M
Video Memory
512 MB GDDR5 SDRAM
Camera
Sound
Stereo speakers, stereo microphone
Codec
IDT 92HD87
SRS Premium Sound, High Definition Audio
Input
Keyboard, touchpad
Numeric Keypad
Volume control, spill-resistant
Communications
Wireless
Bluetooth Class
Class 2
Network Interface
Gigabit Ethernet
Remote Management Protocol
SNMP
IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, Wi-Fi CERTIFIED, IEEE 802.3az
6-cell Lithium Ion
47 Wh
Run Time
Up to 6.25 hours
AC Adapter
Input
Output
90 Watt, 19 V
Connections & Expansion
Slots
1 x ExpressCard/34 (1 free)
HDMI , VGA , Headphone output , Microphone input , LAN , 4 x USB 2.0
Memory Card Reader
Yes (SD Card, Memory Stick, Memory Stick PRO, MultiMediaCard, microSD)
Software
Software Included
HP ProtectTools Security Manager, Skype, HP Recovery Manager, HP Support Assistant, HP QuickWeb, HP Power Assistant, HP DayStarter, HP SoftPaq Download Manager (free download), PDF Complete Special Edition (60 days trial), Norton Internet Security 2011 (60 days subscription), ArcSoft TotalMedia Suite, HP Connection Manager 4.0, HP Hotkey Support, HP ProtectTools for Central Management
Security lock slot (cable lock sold separately), HP ProtectTools Embedded Security, HP 3D DriveGuard, HP DuraFinish, Enhanced Pre-Boot Security, HP SpareKey, One-Step Logon, HP File Sanitizer
ACPI, CSA, UL, VCCI, BSMI, CISPR 22 Class B, EN 60950, IEC950, IEC 60950, UL 60950, CCC, EMC, FCC, RoHS, ETS 300 826, KCC, WEEE, A-Tick, ICES, ETS 300 328, cULus
Localization
2.5 kg
Sustainability Information
ENERGY STAR Certified
5 °C
35 °C
10 - 90% (non-condensing)
Shock Tolerance
125 g @ 2ms half-sine pulse (operating) / 200 g @ 2ms half-sine pulse (non-operating)
Vibration Tolerance
0.75 g @ RMS (random) (operating) / 1.5 g @ RMS (random) (non-operating)
