HP ProBook 450 G9 Intel Core i5-1235U 16GB 256GB SSD 15.6" Windows 11 Professional 64-bit
Quicklinx: H4GJWS00 Mfr#: 6A1T8EA#ABU
Type: Laptop
Screen Size: 15.6in
Processor Model: I5-1235U
Operating System: Windows 11 Pro
Installed Memory: 16GB
  • Core i5
  • IEEE 802.11n
£807.78 ex VAT
£969.33 inc VAT
The HP ProBook 450 Laptop provides growing businesses with the commercial-grade performance, HP Wolf Security for Business, and durability in a compact design. This PC is powered by an Intel processor and protected with always-on security you can trust.
  • Windows 11
    Work anywhere without compromising on performance or security with Windows 11 powered by HP's collaboration and connectivity technology.
  • Fast and efficient wireless LAN
    The portability of your PC and the reliability of a fast connection determines where you can work. Get a fast and reliable connection in dense wireless environments with gigabit-speed Wi-Fi 6.
  • HP Sure Sense
    Malware is evolving rapidly and traditional antivirus can't always recognize new attacks. Protect your PC against never-before-seen attacks with HP Sure Sense, which uses deep learning AI to provide exceptional protection against advanced malware.
  • Browse confidently
    Help protect your PC from websites and read only Microsoft Office and PDF attachments with embedded malware, ransomware, or viruses with hardware-enforced security from HP Sure Click.
  • Work without interruption
    Keep productivity high and downtime low with the fully integrated and automated features of the HP BIOSphere Gen6 firmware ecosystem. Your PCs have extra protection thanks to automatic updates and security checks.
  • Speed up the basics of IT management
    The HP Manageability Integration Kit helps speed up image creation and management of hardware, BIOS, and security through Microsoft System Center Configuration Manager.
HP ProBook 450 G9 Notebook - 15.6" - Intel Core i5 - 1235U - 16 GB RAM - 256 GB SSD - UK
Notebook
Operating System
Win 11 Pro - English
Intel Core i5 (12th Gen) - 1235U / 1.3 GHz, up to 4.4 GHz / 12 MB Cache
16 GB DDR4 (1 x 16 GB)
Storage
256 GB SSD - NVMe, HP Value
Display
15.6" WLED 1366 x 768 / HD @ 60 Hz
Graphics
Intel Iris Xe Graphics
Input Device
ClickPad
Keyboard
Keyboard Backlight
Numeric Keypad
Integrated Webcam
802.11a/b/g/n/ac/ax, Bluetooth 5.2, Gigabit Ethernet
3-cell - up to 12.25 hours
HP Tamper Lock
Security
Trusted Platform Module (TPM 2.0) Security Chip
35.94 cm x 23.39 cm x 1.99 cm
1.79 kg
Environmental Standards
TCO Certified Notebooks 9, ENERGY STAR Qualified
Limited warranty - parts and labour - 1 year , Limited warranty - battery - 1 year
Notebook
Operating System
Windows 11 Pro - English
Processor / Chipset
CPU
Intel Core i5 (12th Gen) 1235U / 1.3 GHz
Max Turbo Speed
4.4 GHz
Number of Cores
10-core
Cache
L3 - 12 MB
Intel Turbo Boost Technology
RAM
16 GB (1 x 16 GB)
Max RAM Supported
32 GB
DDR4 SDRAM - non-ECC
Speed
3200 MHz
Rated Speed
3200 MHz
SO-DIMM 260-pin
Slots Qty
2
Empty Slots
1
Storage
Main Storage
256 GB SSD M.2 PCIe 3.0 - NVM Express (NVMe), HP Value
Display
15.6"
LCD Backlight Technology
WLED backlight
Resolution
1366 x 768 (HD)
V-Sync Rate at Max Res.
60 Hz
Widescreen
Image Brightness
250 cd/m²
Colour Gamut
45% NTSC
HD standard-viewing angle (SVA) eDP anti-glare, narrow bezel bent
Keyboard Name
HP Premium
Audio & Video
Graphics Processor
Camera
Yes - HD
Video Resolutions
720p
Camera Features
Privacy shutter, Temporal Noise Reduction
Sound
Dual stereo speakers, dual array microphone
Codec
Realtek ALC3247-CG
Input
Keyboard, ClickPad
Keyboard Backlight
Keyboard Layout
Numeric Keypad
Multi-touch clickpad, gesture function, spill-resistant
Communications
Wireless
Bluetooth Class
Class 2
Wireless Controller
Realtek RTL8852BE - PCI Express Mini Card (M.2)
Network Interface
Gigabit Ethernet
Ethernet Controller
Realtek RTL8111HSH
Remote Management Protocol
SNMP 2
Miracast, dual stream (2x2), MU-MIMO
Wi-Fi CERTIFIED
3-cell lithium polymer
51.3 Wh
Run Time
Up to 12.25 hours
AC Adapter
Input
AC 115/230 V (50/60 Hz)
Output
45 Watt, 5 / 9 / 12 / 15 V, 5 A
Connections & Expansion
Interfaces Details
USB 3.2 Gen 1 (powered) , USB 3.2 Gen 1 (charging) , USB 3.2 Gen 1 , USB-C 3.2 Gen 2 (supports DisplayPort 2.1 Alt Mode) (Power Delivery) , LAN , Headphone/microphone combo jack , HDMI
Software
Software Included
HP Support Assistant, HP Power Manager, HP Hotkey Support, HP Secure Erase, HP Client Catalogue (free download), HP Image Assistant (free download), HP PC Hardware Diagnostics, HP MAC Address Manager, HP Notifications, HP Connection Optimizer, HP Sure Click, HP Privacy Settings, HP Sure Sense, HP Sure Admin, HP QuickDrop, HP Client Management Script Library (free download), HP BIOSphere Gen6, HP Wake on WLAN, myHP, Touchpoint Customiser for Commercial, Tile, HP Smart Support, HP Quick Touch, HP Sure Start Gen7, HP Driver Packs (free download)
Integrated Options
HP Tamper Lock
Security
BIOS Absolute Persistence, HP Automatic Drive Lock, HP DriveLock, HP Fast Charge, BIOS Update via Network, MIL-STD-810H tested
Theft/Intrusion Protection
Security lock slot (cable lock sold separately), chassis intrusion sensor
Security Slot Type
Kensington nano security slot
HP 45 Watt nPFC USB-C AC Adapter
CSA, UL, VCCI, BSMI, GS, SABS, CCC, FIPS 140-2 Level 2, FCC, RoHS, WEEE, A-Tick, ICES, Common Criteria EAL4+, KC, CECP, EAC, CIT, UL 1642, low halogen, IEEE 1680, ICCP, RED, BNCI
Localization
1.79 kg
Sustainability Information
TCO Certified
- TCO Certified Notebooks 9
ENERGY STAR Certified
35 °C
10 - 90% (non-condensing)
Shock Tolerance (operating)
40 g @ 2 ms half-sine
Shock Tolerance (non-operating)
200 g @ 2 ms half-sine
Vibration Tolerance (operating)
1.043 g @ RMS (random)
Vibration Tolerance (non-operating)
3.5 g @ RMS (random)
Essential Accessories (12)
Get more from your purchase from one of our essential accessories
H4GJ HP 65W Smart AC Adapter In Stock £21.18
H4GJ HP USB-C Dock G5 Docking Station USB-C GigE 100 Watt In Stock £116.78
H4GJ HP USB-C/A Universal Dock G2 - Docking station - USB-C HDMI DP GigE 100 Watt In Stock £145.96
H4GJ HP Thunderbolt Dock G4 - HDMI, 2 x DP, Thunderbolt, USB-C - 1GbE, 2.5GbE In Stock £144.80
H4GJ HP USB-C Power Adapter - 65 Watt In Stock £57.16
H4GJ HP Prelude Top Load 15.6" Notebook Carrying Case In Stock £10.35
H4GJ HP Thunderbolt Dock G4 - USB-C / Thunderbolt 4 - HDMI, 2 x DP, Thunderbolt, USB-C - 1GbE, 2.5GbE In Stock £193.84
H4GJ HP USB-C LC Power Adapter - 65 Watt In Stock £15.28
H4GJ HP Smart AC Adapter - 65 Watt In Stock £18.02
H4GJ HP Nano - Security Cable Lock In Stock £15.92
H4GJ HP Renew Business - Notebook carrying shoulder bag - 17.3" In Stock £19.13
H4GJ HP USB-C 65W LAPTOP CHARGER UK In Stock £19.60
Warranty Packs (8)
Protect your investment by taking out one of our great value warranty packs
H4GJ HP Care Pack Pick-Up and Return Service Extended Service Agreement 3 Years In Stock £54.14
H4GJ HP Care Pack Next Business Day Hardware Support Extended Service Agreement 1 Year On-Site In Stock £23.19
H4GJ HP Care Pack NBD Hardware Support for Travelers with Defective Media Retention 3 Years On-Site In Stock £87.09
H4GJ HP Care Pack Next Business Day Hardware Support Extended Service Agreement 5 Years On-Site In Stock £120.04
H4GJ HP Care Pack Pick-Up and Return Service Extended Service Agreement 4 Years In Stock £71.79
H4GJ HP Care Pack Next Business Day Hardware Support Extended Service Agreement 3 Years On-Site In Stock £76.50
H4GJ HP Care Pack NBD HW Support with Defective Media Retention Extended Service Agreement 3 Yrs On-Site In Stock £84.19
H4GJ HP Care Pack Pick-Up and Return Service with Defective Media Retention - 3 years In Stock £65.90
Other bundles (63)
H4GJ HP USB-C To VGA Adapter In Stock £22.09
H4GJ HP USB Travel Mouse In Stock £10.91
H4GJ HP USB G2 Stereo Headset In Stock £20.44
H4GJ HP 128 Wired Mouse In Stock £8.56
H4GJ HP 455 Programmable Keyboard - Wireless - UK In Stock £26.46
H4GJ HP 325 Webcam In Stock £19.07
H4GJ HP P22v G5 21.4" 1920x1080 5ms HDMI VGA LED Monitor In Stock £131.20
H4GJ Poly Voyager Focus 2 UC-M C USB-A WW In Stock £99.99
H4GJ Poly Voyager Surround 80 UC USB-C Headset + USB-C/A Adapter In Stock £240.58
H4GJ Poly Voyager Surround 80 UC MS Teams Certified USB-C + USB-C/A In Stock £234.68
H4GJ Poly P5 1080P HD Webcam In Stock £36.52
H4GJ Poly Voyager 4320 UC V4320-M C USB-A WW In Stock £124.75
H4GJ Poly Voyager 4320 UC V4320 C USB-C WW In Stock £103.93
H4GJ Poly DA85-M Sound Card In Stock £53.34
H4GJ Poly Voyager Focus 2 UC-M USB-A with Stand In Stock £108.52
H4GJ Poly TRIO C60 EXPANSION MICROPHONES In Stock £134.01
H4GJ Poly Blackwire C3225 USB-A Headset In Stock £51.43
H4GJ Poly EncorePro HW520 Stereo Headset (Noise Cancelling) In Stock £81.71
H4GJ Poly DA85 Headset Cable - USB-C to Quick Disconnect In Stock £53.34
H4GJ Poly EncorePro HW510 Mono Headset (N/C) In Stock £86.11
H4GJ Poly Voyager 4320 UC V4320-M C USB-A CS WW In Stock £108.73
H4GJ Poly Voyager 4320 UC V4320-M C USB-C WW In Stock £98.60
H4GJ Poly Voyager 4320 UC V4320 C USB-A CS WW In Stock £131.93
H4GJ Poly Voyager 4310 UC V4310-M C USB-A WW In Stock £110.75
H4GJ Poly Voyager 4320 UC V4320 C USB-C CS WW In Stock £119.34
H4GJ Poly Voyager 4320 UC V4320-M C USB-C CS WW In Stock £110.60
H4GJ Poly Voyager 4310 UC V4310-M C USB-A CS WW In Stock £121.68
H4GJ Poly Voyager 4320 UC V4320 C USB-A WW In Stock £97.00
H4GJ Poly Voyager 4310 UC V4310 C USB-A WW In Stock £113.52
H4GJ Poly Voyager 4310 UC V4310 C USB-A CS WW In Stock £121.68
H4GJ Poly Sync 10 SY10-M USB-A/C WW In Stock £60.31
H4GJ Poly EncorePro 525 USB EP525 USB-A Headset In Stock £84.71
H4GJ Poly EncorePro HW510 Mono Headset (VT) In Stock £73.73
H4GJ Poly Voyager Focus 2 UC-M USB-C Headset with Stand In Stock £141.12
H4GJ Poly Sync 40 SY40-M WW In Stock £139.01
H4GJ Poly Voyager Focus 2 UC USB-A Headset with Stand In Stock £143.47
H4GJ Poly Blackwire 8225 Stereo Microsoft Teams Certified USB-C In Stock £92.95
H4GJ Poly Blackwire 3320 on-ear - wired - USB-C - black - Certified for Microsoft Teams, UC certified In Stock £34.67
H4GJ Poly Poly Blackwire 3320 Stereo USB-C/A Adapter In Stock £33.49
H4GJ Poly Blackwire 5220 Stereo USB-C Headset + 3.5mm Plug + USB-C In Stock £75.19
H4GJ Poly Spare BT700 Bluetooth USB Adapter In Stock £58.49
H4GJ Poly Blackwire 3315 headset - on-ear - wired - 3.5 mm jack, USB-C - black - UC certified In Stock £49.32
H4GJ Poly Wireless Headset System Base for Bluetooth headset - for Poly Voyager In Stock £91.05
H4GJ HP 724pf Series 7 Pro 23.8" 1920x1080 5ms HDMI DisplayPort IPS LED Monitor In Stock £164.32
H4GJ Poly Blackwire 5210 Monaural USB-C Headset +3.5mm Plug +USB-C/A Adapter In Stock £65.77
H4GJ Poly Blackwire 3310 headset - on-ear - wired - USB-A - black In Stock £28.00
H4GJ Poly Blackwire 3220 headset - on-ear - wired - USB-C - black In Stock £31.11
H4GJ Poly Blackwire 3310 Monaural USB-C Headset + USB-C/A Adapter In Stock £28.00
H4GJ Poly EncorePro 515-M headset - on-ear - wired - USB-A - black In Stock £75.67
H4GJ HP 125 - Mouse - wired - USB - black In Stock £6.26
H4GJ Poly EncorePro 530 headset - in-ear - wired - Quick Disconnect - black In Stock £81.56
H4GJ Poly EncorePro 530 - headset - Quick Disconnect In Stock £81.56
H4GJ HP 732pk Series 7 Pro 32" 3840x2160 5ms HDMI DisplayPort Thunderbolt 4 IPS LED Monitor In Stock £825.46
H4GJ HP E24mv G4 23.8" 1920x1080 5ms VGA HDMI DisplayPort IPS LED Conferencing Monitor In Stock £153.30
H4GJ Poly Voyager 4310 Mono UC V4310 USB-C Microsoft Teams In Stock £121.68
H4GJ HP 324pv Series 3 Pro 23.8" 1920x1080 5ms VGA HDMI LED Monitor In Stock £73.89
H4GJ Poly EncorePro HW520D - headset - Quick Disconnect In Stock £107.03
H4GJ HP E24m G4 23.8" 1920x1080 5ms HDMI DisplayPort USB-C IPS LED Conferencing Monitor In Stock £211.74
H4GJ Poly Blackwire 3325 - headset - 3.5 mm jack, USB-C In Stock £54.64
H4GJ HP 524pf Series 5 Pro 24" 1920x1080 5ms HDMI DisplayPort IPS LED Monitor In Stock £110.29
H4GJ HP E27 G5 27" 1920x1080 5ms HDMI DisplayPort USB IPS LED Monitor In Stock £127.93
Type: Laptop
Screen Size: 15.6in
Hard Drive Capacity: 256GB
Graphics: Intel Iris Xe Graphics
Brand: HP
Price Range Ex VAT: £750 - £1000
