Built for productivity, the HP ProBook 450 delivers the performance and security features essential for today's workforce. The sleek and tough design provides professionals a flexible platform to stay productive in or out of the office.
Designed for mobility
Work in style with the powerful 39.6 cm (15.6-inch) diagonal HP ProBook 450 with a new asteroid silver design. Confidently take on the day with a PC that’s designed to pass MIL-STD 810G testing, built with an aluminum reinforced keyboard.
Powerful processing
Power through projects with 7th Gen Intel® Core™ processors and optional NVIDIA® GeForce® discrete graphics.
Safeguard data and devices
Help keep sensitive data secure with comprehensive security features like HP BIOSphere as well as the embedded TPM and an optional fingerprint reader.
Immersive experience
Enjoy the rich user experience of the HP ProBook 450 with long battery life and features designed to create a stunning visual and audio experience with HP Audio Boost, HP Noise Cancellation, and options like an FHD display, and an HD touch display.
Let nothing stand in your way
Be productive in any situation. Experience the new features of Windows 10 Pro on the powerful, touch optional HP ProBook 450. -
Tested to go the distance
Stand up to the workload with a ProBook that is designed to pass MIL-STD 810G testing. -
Cut out the chatter
Help suppress ambient noise including keyboard clicks with HP Noise Cancellation Software. -
Give your speakers a boost
Help make good speakers sound great with the HP Audio Boost. -
Help secure critical data
With TPM 2.0 embedded security your critical data has protection with hardware-based encryption keys. -
Protect against minor spills
Help protect your ProBook from minor spills with an optional backlit spill-resistant HP Premium Keyboard.
- HP ProBook 450 G4 Notebook - 15.6" - Intel Core i5 - 7200U - 4 GB RAM - 256 GB SSD - UK
- Product Type
- Notebook
- Operating System
- Win 10 Pro 64-bit - English
- Processor
- Intel Core i5 (7th Gen) - 7200U / 2.5 GHz, up to 3.1 GHz / 3 MB Cache
- Memory
- 4 GB DDR4 (1 x 4 GB)
- Storage
- 256 GB SSD
- Optical Drive
- DVD SuperMulti
- Display
- 15.6" LED backlight 1366 x 768 / HD
- Graphics
- Intel HD Graphics 620
- Input Device
- ClickPad
- Keyboard
- UK
- Integrated Webcam
- Networking
- 802.11a/b/g/n/ac, Bluetooth 4.2, Gigabit Ethernet
- Battery
- 3-cell - up to 14.25 hours
- Security
- Trusted Platform Module (TPM 2.0) Security Chip, fingerprint reader
- 38.2 cm x 26.3 cm x 2.44 cm
- 2.04 kg
- Localisation
- Environmental Standards
- - ENERGY STAR Qualified EPEAT Climate+
- Limited warranty - 1 year ¦ Limited warranty - battery - 1 year
- Product Type
- Notebook
- Operating System
- Windows 10 Pro 64-bit Edition - English
Processor / Chipset
- CPU
- Intel Core i5 (7th Gen) 7200U / 2.5 GHz
- Max Turbo Speed
- 3.1 GHz
- Number of Cores
- Dual-Core
- Cache
- 3 MB
- 64-bit Computing
- Hyper-Threading Technology, Intel Turbo Boost Technology 2.0, Intel Smart Cache
- RAM
- 4 GB (1 x 4 GB)
- Max RAM Supported
- 16 GB
- Technology
- DDR4 SDRAM
- Speed
- 2133 MHz / PC4-17000
- Rated Speed
- 2133 MHz
- Form Factor
- SO-DIMM 260-pin
- Slots Qty
- 2
- Empty Slots
- 1
Storage
- Main Storage
- 256 GB SSD M.2 2280 SATA 6Gb/s
- Optical Drive
- DVD±RW (±R DL) / DVD-RAM - tray
Display
- 15.6"
- LCD Backlight Technology
- LED backlight
- Resolution
- 1366 x 768 (HD)
- Widescreen
- Slim Design, HD standard-viewing angle (SVA) anti-glare
- Keyboard Name
- HP Premium
Audio & Video
- Graphics Processor
- Camera
- Yes - 720p
- Video Resolutions
- 1280 x 720
- Camera Features
- 720p HD movie recording
- Sound
- Stereo speakers, two microphones
- Codec
- Conexant CX7700
Input
- Keyboard, ClickPad
- Keyboard Layout
- UK
- Spill-resistant, ClickPad with gesture support
Communications
- Wireless
- Bluetooth Class
- Class 2
- Wireless Controller
- Intel Dual Band Wireless-AC 7265 - PCI Express Mini Card (M.2)
- Network Interface
- Gigabit Ethernet
- Remote Management Protocol
- SNMP 2
- Wake-on-LAN (WOL)
- IEEE 802.1x, IEEE 802.11i, Wi-Fi CERTIFIED
- Technology
- 3-cell Lithium Ion
- Capacity
- 48 Wh
- Run Time
- Up to 14.25 hours
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 45 Watt, 19.5 V
Connections & Expansion
- Interfaces Details
- USB 3.0 , 2 x USB 2.0 , USB-C , HDMI , Headphone/microphone combo jack , LAN , VGA
- Memory Card Reader
- Yes (SD Card, SDHC Card, SDXC Card)
- Security
- HP 3D DriveGuard, HP BIOS Protection, Automatic DriveLock, Preboot Security, SecureBoot, HP DriveLock, Hybrid Boot, Master Record Security, Measured Boot, Power On Authentication, Pre-boot Authentication
- Theft/Intrusion Protection
- Security Slot Type
- Kensington security slot
- Included Accessories
- Power adapter
- CSA, UL, VCCI, BSMI, GOST, SABS, CCC, FCC, RoHS, WEEE, A-Tick, ICES, KC, CIT
- Localization
- 2.04 kg
Sustainability Information
- TCO Certified
- EPEAT Compliant
- EPEAT Climate+
- ENERGY STAR Certified
- 5 °C
- 35 °C
- 10 - 90% (non-condensing)
- Shock Tolerance (operating)
- 40 g @ 2 ms half-sine pulse
- Shock Tolerance (non-operating)
- 200 g @ 2 ms half-sine pulse
- Vibration Tolerance (operating)
- 0.75 g @ RMS (random)
- Vibration Tolerance (non-operating)
- 1.5 g @ RMS (random)
