HP ProBook 450 G4 Intel Core i3-7100U 4GB 500GB 15.6" Win 10 Pro
Quicklinx: CH2QWS00 Mfr#: Y8A06ET#ABU
  • Core i3
  • IEEE 802.11n
Built for productivity, the HP ProBook 450 delivers the performance and security features essential for today's workforce. The sleek and tough design provides professionals a flexible platform to stay productive in or out of the office.
Designed for mobility
Work in style with the powerful 39.6 cm (15.6-inch) diagonal HP ProBook 450 with a new asteroid silver design. Confidently take on the day with a PC that’s designed to pass MIL-STD 810G testing, built with an aluminum reinforced keyboard.
Ultimate power with 7th Generation Intel® processors
Power through projects with 7th Gen Intel® Core™ processors and optional NVIDIA® GeForce® discrete graphics.
Safeguard data and devices
Help keep sensitive data secure with comprehensive security features like HP BIOSphere as well as the embedded TPM and an optional fingerprint reader.
Immersive experience
Enjoy the rich user experience of the HP ProBook 450 with long battery life and features designed to create a stunning visual and audio experience with HP Audio Boost, HP Noise Cancellation, and options like an FHD display, and an HD touch display.
Windows 10 - Familiar and better than ever
Feels familiar
Windows 10 is the familiar feel of Windows – only better. The Start menu is back and better than ever so you can expand and customize it.
Compatible
With Windows 10 you don't have to replace all your stuff.
More protection. Prompt updates
Windows Update provides more than just security updates and patches. Now you get prompt updates to help you stay current with the latest Windows experience.
Fast and responsive
Technologies like InstantGo* let you boot up and resume quickly. Your apps and the web run speedy-fast because the system balances the memory and processor resources efficiently.
  • Let nothing stand in your way
    Be productive in any situation. Experience the new features of Windows 10 Pro on the powerful, touch optional HP ProBook 450.
  • Tested to go the distance
    Stand up to the workload with a ProBook that is designed to pass MIL-STD 810G testing.
  • Cut out the chatter
    Help suppress ambient noise including keyboard clicks with HP Noise Cancellation Software.
  • Give your speakers a boost
    Help make good speakers sound great with the HP Audio Boost.
  • Help secure critical data
    With TPM 2.0 embedded security your critical data has protection with hardware-based encryption keys.
  • Protect against minor spills
    Help protect your ProBook from minor spills with an optional backlit spill-resistant HP Premium Keyboard.
HP ProBook 450 G4 Notebook - 15.6" - Intel Core i3 - 7100U - 4 GB RAM - 500 GB HDD - UK
Notebook
Operating System
Win 10 Pro 64-bit - English
Intel Core i3 (7th Gen) - 7100U / 2.4 GHz / 3 MB Cache
4 GB DDR4 (1 x 4 GB)
Storage
500 GB HDD / 7200 rpm
Optical Drive
DVD SuperMulti
Display
15.6" WLED 1366 x 768 / HD
Graphics
Intel HD Graphics 620
Input Device
ClickPad
Keyboard
Integrated Webcam
802.11a/b/g/n/ac, Bluetooth 4.2, Gigabit Ethernet
3-cell
Security
Trusted Platform Module (TPM 2.0) Security Chip, fingerprint reader
38.2 cm x 26.3 cm x 2.44 cm
2.04 kg
Manufacturer Selling Program
HP Smart Buy
Limited warranty - 1 year , Limited warranty - battery - 1 year
Notebook
Operating System
Windows 10 Pro 64-bit Edition - English
Processor / Chipset
CPU
Intel Core i3 (7th Gen) 7100U / 2.4 GHz
Number of Cores
Dual-Core
Cache
L3 - 3 MB
64-bit Computing
RAM
4 GB (1 x 4 GB)
Max RAM Supported
16 GB
DDR4 SDRAM
Speed
2133 MHz / PC4-17000
Rated Speed
2133 MHz
SO-DIMM 260-pin
Slots Qty
2
Empty Slots
1
Storage
Main Storage
500 GB HDD SATA 6Gb/s / 7200 rpm
Optical Drive
DVD±RW (±R DL) / DVD-RAM - tray
Display
15.6"
LCD Backlight Technology
WLED backlight
Resolution
1366 x 768 (HD)
Widescreen
Image Brightness
220 cd/m²
Slim Design
Audio & Video
Graphics Processor
Camera
Yes - 720p
Sound
Stereo speakers, two microphones
Codec
Conexant CX7700
Input
Keyboard, ClickPad
Keyboard Layout
Spill-resistant, ClickPad with gesture support
Communications
Wireless
Wireless Controller
Intel Dual Band Wireless-AC 8265 - PCI Express Mini Card (M.2)
Network Interface
Gigabit Ethernet
Remote Management Protocol
SNMP 2
Wake-on-LAN (WOL)
IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.1x, IEEE 802.11i, Wi-Fi CERTIFIED, IEEE 802.3az
3-cell Lithium Ion
48 Wh
AC Adapter
Input
Output
19.5 V
Connections & Expansion
Interfaces Details
2 x USB 2.0 , USB 3.0 , USB-C , HDMI , Headphone/microphone combo jack , LAN , VGA
Memory Card Reader
Yes (SD Card, SDHC Card, SDXC Card)
Software
Software Included
Skype, HP SoftPaq Download Manager, HP Recovery Manager, HP Support Assistant, Bing Toolbar, HP ePrint, HP Hotkey Support, Windows Defender, HP Systems Software Manager (free download), HP Secure Erase, HP Security Manager, HP BIOSphere, HP BIOS Configuration Utility (free download), HP Client Catalogue (free download), HP CIK for Microsoft SCCM (free download), HP 3D DriveGuard, HP Driver Packs (free download)
Security
HP 3D DriveGuard, HP BIOS Protection, Automatic DriveLock, Preboot Security, SecureBoot, HP DriveLock, Hybrid Boot, Master Record Security, Measured Boot, Power On Authentication, Pre-boot Authentication
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
Power adapter
CSA, UL, VCCI, BSMI, GOST, SABS, CCC, FCC, A-Tick, ICES, KC, CIT
Localization
HP Smart Buy
2.04 kg
Sustainability Information
TCO Certified
5 °C
35 °C
10 - 90% (non-condensing)
Shock Tolerance (operating)
40 g @ 2 ms half-sine pulse
Shock Tolerance (non-operating)
200 g @ 2 ms half-sine pulse
Vibration Tolerance (operating)
0.75 g @ RMS (random)
Vibration Tolerance (non-operating)
1.5 g @ RMS (random)
