HP ProBook 450 G10 Intel Core i5-1335U 16GB 256GB SSD 15.6" Windows 11 Professional
Quicklinx: HJNSWS00 Mfr#: 967W0ET#ABU
£745.85 ex VAT
£895.02 inc VAT
The HP ProBook 450 15-inch laptop provides growing businesses with the commercial-grade performance, multi-layered endpoint security, and durability in an easily upgradeable design. Powered by the latest Intel processor and long battery life, this feature-rich PC is well-equipped for long-term productivity and helps enable hybrid work.
  • Windows 11
    Work anywhere without compromising on performance or security with Windows 11 powered by HP's collaboration and connectivity technology.
  • 13th Gen Intel multi-core processor
    Get the perfect combination of power, snappy performance, and value with a 13th gen Intel Core processor to handle multiple work tasks smoothly and reliably with multiple processing cores.
  • Security is your top priority
    The HP Wolf Pro Security Edition provides preconfigured enterprise-level PC protection for small and medium sized businesses.
  • Fast and efficient wireless LAN
    The portability of your PC and the reliability of a fast connection determines where you can work. Get a fast and reliable connection in dense wireless environments with gigabit-speed Wi-Fi 6.
  • HP Sure Sense
    Malware is evolving rapidly and traditional antivirus can't always recognize new attacks. Protect your PC against never-before-seen attacks with HP Sure Sense, which uses deep learning AI to provide exceptional protection against advanced malware.
  • Browse confidently
    Help protect your PC from websites and read only Microsoft Office and PDF attachments with embedded malware, ransomware, or viruses with hardware-enforced security from HP Sure Click.
HP ProBook 450 G10 Notebook - 15.6" - Intel Core i5 - 1335U - 16 GB RAM - 256 GB SSD - UK - with HP Wolf Pro Security Edition (1 year)
Notebook - 177-degree hinge design
Operating System
Win 11 Pro - English
Intel Core i5 (13th Gen) - 1335U / 1.3 GHz, up to 4.6 GHz / 12 MB Cache
16 GB DDR4 (1 x 16 GB)
Storage
256 GB SSD - NVMe, HP Value
Display
15.6" WLED 1920 x 1080 / Full HD @ 60 Hz
Graphics
Intel UHD Graphics
Input Device
ClickPad
Keyboard
Numeric Keypad
Integrated Webcam
802.11a/b/g/n/ac/ax (Wi-Fi 6E), Bluetooth 5.3, Gigabit Ethernet
3-cell
HP Tamper Lock
Security
Trusted Platform Module (TPM 2.0) Security Chip, fingerprint reader
Pike silver aluminium
35.94 cm x 23.39 cm x 1.99 cm
1.79 kg
Manufacturer Selling Program
HP Smart Buy
Environmental Standards
TCO Certified Notebooks 9, ENERGY STAR Qualified
Carbon Footprint
140 kg carbon emissions
Limited warranty - parts and labour - 1 year
Bundled with
Operating System
Windows 11 Pro - English
Bundled with
Processor / Chipset
CPU
Intel Core i5 (13th Gen) 1335U / 1.3 GHz
Max Turbo Speed
4.6 GHz
Number of Cores
10-core
Cache
L3 - 12 MB
Intel Turbo Boost Technology
RAM
16 GB (1 x 16 GB)
Max RAM Supported
32 GB
DDR4 SDRAM - non-ECC
Speed
3200 MHz
Rated Speed
3200 MHz
SO-DIMM 260-pin
Slots Qty
2
Empty Slots
1
Storage
Main Storage
256 GB SSD M.2 2230 PCIe - NVM Express (NVMe), HP Value
Display
15.6" - IPS
LCD Backlight Technology
WLED backlight
Resolution
1920 x 1080 (Full HD)
V-Sync Rate at Max Res.
60 Hz
Widescreen
Image Brightness
250 cd/m²
Colour Gamut
45% NTSC
Full HD ultra wide-viewing angle (UWVA) eDP anti-glare, narrow bezel bent
Keyboard Name
HP Premium
Audio & Video
Graphics Processor
Intel UHD Graphics
Camera
Yes - HD
Video Resolutions
720p
Camera Features
Privacy shutter, Temporal Noise Reduction
Sound
Dual stereo speakers, dual array microphone
Codec
Realtek ALC3247
Input
Keyboard, ClickPad
Keyboard Layout
Numeric Keypad
Multi-touch clickpad, gesture function, spill-resistant
Communications
Wireless
Bluetooth Class
Class 2
Wireless Controller
Intel Wi-Fi 6E AX 211
Network Interface
Gigabit Ethernet
Miracast, dual stream (2x2), CNVi, 160 MHz Wi-Fi bandwidth
IEEE 802.11d, IEEE 802.11i, Wi-Fi CERTIFIED, IEEE 802.11h, IEEE 802.11e, IEEE 802.11k, IEEE 802.11r, IEEE 802.11v
3-cell lithium polymer
202.5 g
51 Wh
AC Adapter
Input
AC 115/230 V (50/60 Hz)
Output
65 Watt, 19.5 V, 11 A
Connections & Expansion
Interfaces Details
2 x USB-C 3.2 Gen 2 (supports DisplayPort 2.1 Alt Mode) (Power Delivery) , USB 3.2 Gen 1 (charging) , USB 3.2 Gen 1 (powered) , HDMI , Headphone/microphone combo jack , LAN (RJ-45)
Software
Software Included
HP Support Assistant, HP Power Manager, HP Hotkey Support, HP Secure Erase, HP Client Catalogue (free download), HP Notifications, HP Connection Optimizer, HP Sure Click, HP Privacy Settings, HP Cloud Recovery, HP Sure Sense, HP Sure Admin, HP QuickDrop, HP Client Management Script Library (free download), HP BIOSphere Gen6, HP Wake on WLAN, myHP, HP Image Assistant Gen5 (free download), HP Client Security Manager Gen7, HP Smart Support (free download), HP Sure Run Gen5, HP PC Hardware Diagnostics Windows, HP Services Scan, HP Sure Start Gen7, HP Driver Packs (free download), HP Manageability Integration Kit Gen4 (free download)
Integrated Options
HP Tamper Lock
Security
BIOS Absolute Persistence, HP Automatic Drive Lock, HP DriveLock, HP Fast Charge, BIOS Update via Network, Secured-core PC enabled
Theft/Intrusion Protection
Security Slot Type
Kensington nano security slot
HP 65 Watt Smart nPFC AC Adapter
CSA, VCCI, BSMI, GS, CCC, FIPS 140-2 Level 2, FCC, RoHS, KCC, WEEE, CISPR, ICES, Common Criteria EAL4+, KC, SRRC, NCC, low halogen, UL 62368-1, TEC, KES, Low Blue Light certified (LBL), Ukraine NSoC, EAEU Compliance, Saudi Arabian Compliance
Localization
HP Smart Buy
1.79 kg
6.9 cm x 48.3 cm x 30.5 cm
Sustainability Information
TCO Certified
- TCO Certified Notebooks 9
ENERGY STAR Certified
Carbon Footprint
Manufacturing (kg CO2e)
120
Logistics (kg CO2e)
4
Use (kg CO2e)
19
EOL (kg CO2e)
0.8
Total Carbon w/o Use Phase (kg CO2e)
140
35 °C
10 - 90% (non-condensing)
Shock Tolerance (operating)
40 g @ 2 ms half-sine
Shock Tolerance (non-operating)
240 g @ 2 ms half-sine
Vibration Tolerance (operating)
1.043 g @ RMS (random)
Vibration Tolerance (non-operating)
3.5 g @ RMS (random)
Essential Accessories (12)
Get more from your purchase from one of our essential accessories
HJNS HP 65W Smart AC Adapter In Stock £21.18
HJNS HP 90W Smart AC Adapter In Stock £32.21
HJNS HP USB-C Dock G5 Docking Station USB-C GigE 100 Watt In Stock £116.78
HJNS HP USB-C/A Universal Dock G2 - Docking station - USB-C HDMI DP GigE 100 Watt In Stock £145.96
HJNS HP USB-C TO RJ45 Adapter In Stock £187.85
HJNS HP Thunderbolt Dock G4 - HDMI, 2 x DP, Thunderbolt, USB-C - 1GbE, 2.5GbE In Stock £144.80
HJNS HP USB-C Power Adapter - 65 Watt In Stock £57.16
HJNS HP Prelude Top Load 15.6" Notebook Carrying Case In Stock £10.35
HJNS HP USB-C LC Power Adapter - 65 Watt In Stock £15.28
HJNS HP Smart AC Adapter - 65 Watt In Stock £18.02
HJNS HP Renew Business - Notebook carrying shoulder bag - 17.3" In Stock £19.13
HJNS HP USB-C 65W LAPTOP CHARGER UK In Stock £19.60
Warranty Packs (6)
Protect your investment by taking out one of our great value warranty packs
HJNS HP Care Pack NBD Hardware Support for Travelers with Defective Media Retention 3 Years On-Site In Stock £87.09
HJNS HP Care Pack Next Business Day Hardware Support Extended Service Agreement 5 Years On-Site In Stock £120.04
HJNS HP Care Pack Pick-Up and Return Service Extended Service Agreement 4 Years In Stock £71.79
HJNS HP Care Pack Next Business Day Hardware Support Extended Service Agreement 3 Years On-Site In Stock £76.50
HJNS HP Care Pack NBD HW Support with Defective Media Retention Extended Service Agreement 3 Yrs On-Site In Stock £84.19
HJNS HP Care Pack Pick-Up and Return Service with Defective Media Retention - 3 years In Stock £65.90
Other bundles (55)
HJNS HP USB-C To VGA Adapter In Stock £22.09
HJNS HP USB Travel Mouse In Stock £10.91
HJNS HP USB G2 Stereo Headset In Stock £20.44
HJNS HP 128 Wired Mouse In Stock £8.56
HJNS HP 455 Programmable Keyboard - Wireless - UK In Stock £26.46
HJNS HP USB-C to RJ45 Adapter G2 In Stock £13.20
HJNS HP 325 Webcam In Stock £19.07
HJNS Poly Voyager Focus 2 UC-M C USB-A WW In Stock £99.99
HJNS Poly Voyager Surround 80 UC USB-C Headset + USB-C/A Adapter In Stock £240.58
HJNS Poly Voyager Surround 80 UC MS Teams Certified USB-C + USB-C/A In Stock £234.68
HJNS Poly Voyager 4320 UC V4320-M C USB-A WW In Stock £124.75
HJNS Poly Voyager 4320 UC V4320 C USB-C WW In Stock £103.93
HJNS Poly TRIO C60 EXPANSION MICROPHONES In Stock £134.01
HJNS Poly Blackwire C3225 USB-A Headset In Stock £51.43
HJNS Poly EncorePro HW520 Stereo Headset (Noise Cancelling) In Stock £81.71
HJNS Poly EncorePro HW510 Mono Headset (N/C) In Stock £86.11
HJNS Poly Voyager 4320 UC V4320-M C USB-C WW In Stock £98.60
HJNS Poly Voyager 4310 UC V4310-M C USB-A WW In Stock £110.75
HJNS Poly Voyager 4320 UC V4320 C USB-C CS WW In Stock £119.34
HJNS Poly Voyager 4320 UC V4320-M C USB-C CS WW In Stock £110.60
HJNS Poly Voyager 4320 UC V4320 C USB-A WW In Stock £97.00
HJNS Poly Voyager 4310 UC V4310 C USB-A WW In Stock £113.52
HJNS Poly EncorePro 525 USB EP525 USB-A Headset In Stock £84.71
HJNS Poly EncorePro HW510 Mono Headset (VT) In Stock £73.73
HJNS Poly Voyager Focus 2 UC-M USB-C Headset with Stand In Stock £141.12
HJNS Poly Blackwire 8225 Stereo Microsoft Teams Certified USB-C In Stock £92.95
HJNS Poly Blackwire 3320 on-ear - wired - USB-C - black - Certified for Microsoft Teams, UC certified In Stock £34.67
HJNS Poly Poly Blackwire 3320 Stereo USB-C/A Adapter In Stock £33.49
HJNS Poly Blackwire 5220 Stereo USB-C Headset + 3.5mm Plug + USB-C In Stock £75.19
HJNS Poly Spare BT700 Bluetooth USB Adapter In Stock £58.49
HJNS Poly Blackwire 3315 headset - on-ear - wired - 3.5 mm jack, USB-C - black - UC certified In Stock £49.32
HJNS HP 724pf Series 7 Pro 23.8" 1920x1080 5ms HDMI DisplayPort IPS LED Monitor In Stock £164.32
HJNS Poly Blackwire 3210 headset - on-ear - wired - USB-C - black In Stock £25.20
HJNS Poly Blackwire 5210 Monaural USB-C Headset +3.5mm Plug +USB-C/A Adapter In Stock £65.77
HJNS Poly Blackwire 3310 headset - on-ear - wired - USB-A - black In Stock £28.00
HJNS Poly Blackwire 3220 headset - on-ear - wired - USB-C - black In Stock £31.11
HJNS Poly Blackwire 3220 headset - on-ear - wired - USB-C - black In Stock £29.33
HJNS Poly Blackwire 3310 Monaural USB-C Headset + USB-C/A Adapter In Stock £28.00
HJNS Poly EncorePro 515-M headset - on-ear - wired - USB-A - black In Stock £75.67
HJNS HP P34hc G4 P-Series 34" 3440x1440 5ms HDMI DisplayPort USB-C LED Curved Monitor In Stock £320.60
HJNS Poly EncorePro 530 headset - in-ear - wired - Quick Disconnect - black In Stock £81.56
HJNS Poly EncorePro 530 - headset - Quick Disconnect In Stock £81.56
HJNS HP 732pk Series 7 Pro 32" 3840x2160 5ms HDMI DisplayPort Thunderbolt 4 IPS LED Monitor In Stock £825.46
HJNS HP E24mv G4 23.8" 1920x1080 5ms VGA HDMI DisplayPort IPS LED Conferencing Monitor In Stock £153.30
HJNS HP 324pv Series 3 Pro 23.8" 1920x1080 5ms VGA HDMI LED Monitor In Stock £73.89
HJNS Poly EncorePro HW520D - headset - Quick Disconnect In Stock £107.03
HJNS HP E24m G4 23.8" 1920x1080 5ms HDMI DisplayPort USB-C IPS LED Conferencing Monitor In Stock £211.74
HJNS Poly Blackwire 3325 - headset - 3.5 mm jack, USB-C In Stock £54.64
HJNS HP 230 - keyboard and mouse set - UK Input Device In Stock £36.54
HJNS HP 715 - mouse - multi-device, rechargeable - Bluetooth 3.0, 2.4 GHz - black In Stock £51.11
HJNS HP 524pf Series 5 Pro 24" 1920x1080 5ms HDMI DisplayPort IPS LED Monitor In Stock £110.29
HJNS HP E27 G5 27" 1920x1080 5ms HDMI DisplayPort USB IPS LED Monitor In Stock £127.93
HJNS HP 524pm Series 5 Pro 24" 1920x1080 5ms HDMI DisplayPort USB-C IPS LED Conferencing Monitor In Stock £242.62
Brand: HP
Price Range Ex VAT: £500 - £750
