The thin, light, tough design of the HP ProBook 430 gives mobile professionals powerful tools to stay productive on the go. Equipped for productivity, this ProBook delivers the performance and security features essential for today’s mobile workforce.
Designed for mobility
Travel in style with the 33,8 cm (13.3") diagonal HP ProBook 430 with a new gravity black LCD cover design. Confidently take on the day with a PC built with an aluminum reinforced keyboard deck and 120,000 hours of HP Testing.
Safeguard data and devices
Help keep sensitive data secure with comprehensive security features like HP BIOSphere design as well as the embedded TPM.
Powerful processing
Power through projects with 6th Gen Intel® Core™ processors and multiple HDD and SSD drives options to suit your needs.
Immersive experience
Enjoy the rich user experience of the HP ProBook 430 with long battery life and features designed to create a stunning visual and audio experience with options like an HD display, an HD touch display, and DTS Studio Sound.™
Let nothing stand in your way
Be productive in any situation. Experience the new features of Windows 10 Pro on the thin, light, touch optional HP ProBook 430. -
Tested to go the distance
Stand up to the workload with an ProBook that passed MIL-STD 810G testing. -
Help secure critical data
With TPM your critical data has protection with hardware-based encryption keys. -
Protect against minor spills
Help protect your ProBook from minor spills with a spill-resistant HP Premium Keyboard. -
Customized protection
HP BIOSphere boosts security and keeps mission-critical data and systems under lock and key with customizable authentication and BIOS-level passwords.
- HP ProBook 430 G3 Notebook - 13.3" - Intel Core i5 - 6200U - 4 GB RAM - 500 GB HDD - UK
- Product Type
- Notebook
- Operating System
- Win 7 Pro 64-bit (downgrade from Windows 10 Pro 64-bit) + Windows 10 Pro 64-bit Licence - English
- Processor
- Intel Core i5 (6th Gen) - 6200U / 2.3 GHz, up to 2.8 GHz / 3 MB Cache
- Memory
- 4 GB DDR4 (1 x 4 GB)
- Storage
- 500 GB HDD / 7200 rpm
- Display
- 13.3" LED backlight 1366 x 768 / HD
- Graphics
- Intel HD Graphics 520
- Keyboard
- UK
- Integrated Webcam
- Networking
- Bluetooth 4.0, 802.11a/b/g/n/ac, Gigabit Ethernet
- Battery
- 4-cell - up to 10.25 hours
- Security
- Trusted Platform Module (TPM 1.2) Security Chip
- 32.6 cm x 23.35 cm x 2.09 cm
- 1.5 kg
- Localisation
- Environmental Standards
- - ENERGY STAR Qualified EPEAT Climate+
- Limited warranty - 1 year , Limited warranty - battery - 1 year
- Product Type
- Notebook
- Operating System
- Microsoft Windows 7 Professional 64-bit Edition (available through downgrade rights from Windows 10 Pro 64-bit) + Windows 10 Pro 64-bit Licence - English
Processor / Chipset
- CPU
- Intel Core i5 (6th Gen) 6200U / 2.3 GHz
- Max Turbo Speed
- 2.8 GHz
- Number of Cores
- Dual-Core
- Cache
- 3 MB
- 64-bit Computing
- Hyper-Threading Technology, Intel Turbo Boost Technology 2.0, Intel Smart Cache
- RAM
- 4 GB (1 x 4 GB)
- Max RAM Supported
- 16 GB
- Technology
- DDR4 SDRAM
- Speed
- 2133 MHz / PC4-17000
- Rated Speed
- 2133 MHz
- Form Factor
- SO-DIMM 260-pin
- Slots Qty
- 2
- Empty Slots
- 1
Storage
- Main Storage
- 500 GB HDD SATA 6Gb/s / 7200 rpm
Display
- 13.3"
- LCD Backlight Technology
- LED backlight
- Resolution
- 1366 x 768 (HD)
- Widescreen
- Image Aspect Ratio
- 16:9
- Image Brightness
- 220 cd/m²
- HD standard-viewing angle (SVA) eDP anti-glare
Audio & Video
- Graphics Processor
- Camera
- Yes - 720p
- Sound
- Stereo speakers, two microphones
- High Definition Audio, DTS Studio Sound
Input
- Keyboard, touchpad
- Keyboard Layout
- UK
- Spill-resistant, touchpad with gesture support
Communications
- Wireless
- Bluetooth Class
- Class 2
- Wireless Controller
- Intel Dual Band Wireless-AC 3165 - PCI Express Mini Card (M.2)
- Network Interface
- Gigabit Ethernet
- Remote Management Protocol
- SNMP 2
- Wake-on-LAN (WOL)
- IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.1x, IEEE 802.11i, Wi-Fi CERTIFIED, IEEE 802.3az
- Technology
- 4-cell Lithium Ion
- Capacity
- 40 Wh
- Run Time
- Up to 10.25 hours
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 45 Watt, 19.5 V
Connections & Expansion
- Interfaces Details
- 2 x USB 3.0 , USB 2.0 , HDMI , Headphone/microphone combo jack , LAN , VGA
- Memory Card Reader
- Yes (SD Card, SDHC Card, SDXC Card)
Software
- Software Included
- Drivers & Utilities, CyberLink Power2Go, HP Recovery Disc Creator, Skype, LANDesk Management Suite, Microsoft Security Essentials, CyberLink Youcam, HP SoftPaq Download Manager, HP Recovery Manager, HP Support Assistant, Bing Toolbar, HP Connection Manager, HP ePrint, HP Hotkey Support, CyberLink YouCam BE, CyberLink PowerDVD BD Edition, Foxit PhantomPDF Express, Intel Wireless Display, HP Client Security, HP Mobile Connect, HP Systems Software Manager (free download), HP Secure Erase, HP Security Manager, HP BIOSphere, HP GPS and Location, HP BIOS Configuration Utility (free download), HP Client Catalogue (free download), Absolute Persistence, HP Driver Packs, HP CIK for Microsoft SCCM (free download), HP 3D DriveGuard, HP Noise Reduction Software, HP Caller Dashboard
- Security
- HP 3D DriveGuard, HP BIOS Protection, Automatic DriveLock, HP Drive Encryption, HP DriveLock, Master Record Security, Power On Authentication, Pre-Boot Security, 1 USB 2.0 charging port, Pre-boot Authentication
- Theft/Intrusion Protection
- Security Slot Type
- Kensington security slot
- Included Accessories
- Power adapter
- ACPI, CSA, UL, VCCI, BSMI, GOST, SABS, CCC, FCC, RoHS, WEEE, A-Tick, ICES, KC, CIT
- Localization
- 1.5 kg
Sustainability Information
- TCO Certified
- EPEAT Compliant
- EPEAT Climate+
- ENERGY STAR Certified
- 0 °C
- 35 °C
- 10 - 90% (non-condensing)
- Shock Tolerance (operating)
- 40 g @ 2 ms half-sine pulse
- Shock Tolerance (non-operating)
- 200 g @ 2 ms half-sine pulse
- Vibration Tolerance (operating)
- 0.75 g @ RMS (random)
- Vibration Tolerance (non-operating)
- 1.5 g @ RMS (random)
Essential Accessories (5)
Get more from your purchase from one of our essential accessories
HP 90W Smart AC Adapter | In Stock | £22.69 |
HP 45W Adaptor NPFC Smart RC 4.5MM NSLIM | In Stock | £16.87 |
HP 65W Smart AC Adapter | In Stock | £18.54 |
HP Power Connector Adaptor DC Jack 7.4mm (F) To DC Jack | In Stock | £13.44 |
HP Dual Head Keyed Cable Lock | In Stock | £43.00 |
Other bundles (6)
HPE HDMI to DVI Adapter | In Stock | £9.89 |
HP USB Travel Mouse | In Stock | £10.58 |
HP X4000b Bluetooth Mouse | In Stock | £28.71 |
HP DreamColour 31.1" 4096x2160 10ms 2xHDMI 2xDisplayPort USB-C LED Monitor | In Stock | £2,821.06 |
HP E 24" G4 WUXGA 1920 x 1200 LED Backlit Monitor | In Stock | £150.00 |
HP E24u G4 24" 1920x1080 5ms HDMI DisplayPort USB-C IPS LED Monitor | In Stock | £215.30 |
