HP ProBook 4 G1iR Intel Core 5-120U 16GB 256GB SSD 16" Windows 11 Professional
Quicklinx: JCZGWS00 Mfr#: B3AC8AT#ABU
Screen Size: 16in
Processor Model: 120U
Operating System: Windows 11 Pro
Hard Drive Capacity: 256GB
Graphics: Intel Graphics
  • IEEE 802.11n
More than 50 In Stock
£805.12 ex VAT
£966.14 inc VAT
The HP ProBook 4 G1iR 16-inch Notebook PC provides growing businesses with commercial-grade performance, multi-layered endpoint security, and durability in an easily upgradeable design. Powered by the latest Intel processor and long battery life, this feature-rich PC is future-ready for long-term productivity and helps enable hybrid work.
HP ProBook 4 G1iR Notebook AI - 16" - Intel Core 5 - 120U - 16 GB RAM - 256 GB SSD - UK
Notebook - 177-degree hinge design
Operating System
Win 11 Pro - English
Intel Core 5 (Series 1) - 120U / 1.4 GHz, up to 5 GHz / 12 MB Cache
16 GB DDR5 (1 x 16 GB)
Storage
256 GB SSD - NVMe
Display
16" 1920 x 1200 / WUXGA @ 60 Hz
Graphics
Intel Graphics
Input Device
ClickPad
Keyboard
Numeric Keypad
Integrated Webcam
Microsoft Copilot
802.11a/b/g/n/ac/ax (Wi-Fi 6E), Bluetooth 5.3
3-cell
HP Sure Platform, thermal sensor, HP Tamper Lock, hall sensor
Security
Trusted Platform Module (TPM 2.0) Security Chip, fingerprint reader
Pike silver
35.94 cm x 25.1 cm x 1.7 cm
1.74 kg
Manufacturer Selling Program
HP Smart Buy
Environmental Standards
ENERGY STAR Qualified EPEAT Gold, EPEAT Climate+
Operating System
Windows 11 Pro - English
Processor / Chipset
CPU
Intel Core 5 (Series 1) 120U / 1.4 GHz
Max Turbo Speed
5 GHz
Number of Cores
10-core
Performance Cores
2
Efficient Cores
8
Cache
L3 - 12 MB
RAM
16 GB (1 x 16 GB)
Max RAM Supported
48 GB
DDR5 SDRAM
Speed
5200 MT/s
Rated Speed
5600 MT/s
SO-DIMM 262-pin
Slots Qty
2
Empty Slots
1
Storage
Main Storage
256 GB SSD PCIe - NVM Express (NVMe)
Display
16" - IPS
Resolution
1920 x 1200 (WUXGA)
V-Sync Rate at Max Res.
60 Hz
Widescreen
Image Aspect Ratio
16:10
Image Brightness
300 cd/m²
Colour Gamut
62.5% sRGB
WUXGA ultra wide-viewing angle (UWVA) anti-glare eDP, 90.6% screen-to-body ratio, narrow bezel bent
Keyboard Name
HP Standard Keyboard
Audio & Video
Graphics Processor
Intel Graphics
Camera
Yes - Full HD
Video Resolutions
1080p
Camera Features
Privacy shutter
Sound
Dual stereo speakers, dual array microphone
Audio Features
Output: Poly Studio
Input
Keyboard, ClickPad
Keyboard Layout
Numeric Keypad
Multi-touch clickpad, gesture function, precision touchpad, image sensor, glass touchpad, volume control, spill-resistant, DuraKeys
Communications
Wireless
Bluetooth Class
Class 2
Wireless Controller
Intel Wi-Fi 6E AX 211 - PCI Express Mini Card (M.2)
Ethernet Controller
Realtek RTL8111HSH-CG
Dual stream (2x2), Miracast
IEEE 802.11d, IEEE 802.11e, IEEE 802.11h, IEEE 802.11i, IEEE 802.11k, IEEE 802.11r, IEEE 802.11v, Wi-Fi CERTIFIED
3-cell lithium polymer
56.04 Wh
AC Adapter
Input
AC 100-240 V (50/60 Hz)
Output
65 watt, 5 / 9 / 12 / 15 / 20 V, 8 A
Connections & Expansion
Interfaces Details
2 x USB-C 3.2 Gen 2x2 (supports DisplayPort 1.4 Alt Mode) (Power Delivery 3.0, Sleep & Charge) , HDMI , Headphone/microphone combo jack , 2 x USB 3.2 Gen 1 (powered) , LAN (RJ-45)
Software
Software Included
HP Sure Admin, Audio Permanent Disable, HP BIOS Recovery, HP BIOSphere, HP Secure Erase, HP Wake on WLAN, Windows Hello, HP Sure Click, HP Sure Recover, HP Sure Run, HP Sure Sense, HP Sure Start, HP Services Scan, HP Smart Support, HP Support Assistant, myHP, HSA Fusion for Commercial, HSA Telemetry for Commercial, Poly Camera Pro, Poly Lens, Edge Customization, HP Connection Optimizer, HP Hotkey Support, HP MAC Address Manager, HP Notifications, HP UEFI BIOS Certification level 2.8, HP PC Hardware Diagnostics Windows, HP Privacy Settings, HP Client Catalogue (free download), HP Client Management Script Library (free download), HP Cloud Recovery, HP Connect for Microsoft Endpoint Manager, HP Driver Packs (free download), HP Image Assistant (free download), HP Manageability Integration Kit (free download), HP Power Manager with Battery Health Manager (download)
Microsoft Copilot
Pike silver
Integrated Options
Security
BIOS Absolute Persistence, BIOS Update via Network, HP DriveLock, Automatic DriveLock, Secured-core PC enabled, MIL-STD-810H tested, HP Fast Charge
Theft/Intrusion Protection
Security lock slot (cable lock sold separately), chassis intrusion sensor
Security Slot Type
Kensington security slot
HP 65W USB-C AC Adapter
UL 62368-1, FCC, ICES, CISPR, VCCI, CCC, SRRC, BSMI, NCC, KCC, KC, KES, Ukraine NSoC, TEC, EAEU Compliance, Saudi Arabian Compliance, Low Blue Light certified (LBL), RoHS, CECP, EMC, IEC 60601-1-2:2014, EN 60601-1-2:2015, Common Criteria EAL4+, FIPS 140-2 Level 2, low halogen
Localization
HP Smart Buy
1.74 kg
Sustainability Information
EPEAT Compliant
EPEAT Gold
EPEAT Climate+
ENERGY STAR Certified
Product Recycled Content
Post-consumer recycled plastic, ocean-bound plastics, recycled metal
35 °C
10 - 90% (non-condensing)
Shock Tolerance (operating)
40 g @ 2 ms half-sine
Shock Tolerance (non-operating)
240 g @ 2 ms half-sine
Vibration Tolerance (operating)
1.043 g @ RMS (random)
Vibration Tolerance (non-operating)
3.5 g @ RMS (random)
Essential Accessories (6)
Get more from your purchase from one of our essential accessories
JCZG HP USB-C Dock G5 Docking Station USB-C GigE 100 Watt In Stock £185.94
JCZG HP USB-C Power Adapter - 65 Watt In Stock £56.88
JCZG HP USB-C LC Power Adapter - 65 Watt In Stock £15.15
JCZG HP Nano - Security Cable Lock In Stock £15.78
JCZG HP Renew Business - Notebook carrying shoulder bag - 17.3" In Stock £18.95
JCZG HP USB-C 65W LAPTOP CHARGER UK In Stock £19.07
Warranty Packs (2)
Protect your investment by taking out one of our great value warranty packs
JCZG HP Care Pack Pick-Up and Return Service Extended Service Agreement 3 Years In Stock £55.26
JCZG HP Electronic HP Care Pack Onsite Support - extended service agreement - 3 years - on-site In Stock £73.89
Other bundles (68)
JCZG HP USB-C To VGA Adapter In Stock £23.07
JCZG HP USB Travel Mouse In Stock £9.28
JCZG HP USB-C to HDMI 2.0 Adapter In Stock £47.48
JCZG HP USB G2 Stereo Headset In Stock £20.27
JCZG HP 128 Wired Mouse In Stock £8.49
JCZG HP 455 Programmable Keyboard - Wireless - UK In Stock £46.54
JCZG HP USB-C to RJ45 Adapter G2 In Stock £13.11
JCZG Poly Voyager Surround 80 UC USB-C Headset + USB-C/A Adapter In Stock £208.06
JCZG Poly Voyager Surround 80 UC MS Teams Certified USB-C + USB-C/A In Stock £216.07
JCZG Poly Voyager 4320 UC V4320-M C USB-A WW In Stock £103.25
JCZG Poly Voyager 4320 UC V4320 C USB-C WW In Stock £106.60
JCZG Poly EncorePro HW520 Stereo Headset (Noise Cancelling) In Stock £65.27
JCZG Poly EncorePro HW510 Mono Headset (N/C) In Stock £72.84
JCZG Poly Voyager 4320 UC V4320-M C USB-A CS WW In Stock £108.73
JCZG Poly Voyager 4320 UC V4320-M C USB-C WW In Stock £103.25
JCZG Poly Voyager 4320 UC V4320 C USB-A CS WW In Stock £117.00
JCZG Poly Savi 7320 Office S7320 Stereo Headset In Stock £242.98
JCZG Poly Voyager 4320 UC V4320 C USB-C CS WW In Stock £120.32
JCZG Poly Voyager 4320 UC V4320-M C USB-C CS WW In Stock £111.68
JCZG Poly Voyager 4310 UC V4310-M C USB-A CS WW In Stock £108.17
JCZG Poly Voyager 4320 UC V4320 C USB-A WW In Stock £103.25
JCZG Poly Voyager 4310 UC V4310 C USB-A WW In Stock £98.17
JCZG Poly Voyager 4310 UC V4310 C USB-A CS WW In Stock £108.17
JCZG Poly Sync 10 SY10-M USB-A/C WW In Stock £55.47
JCZG Poly EncorePro 525 USB EP525 USB-A Headset In Stock £87.67
JCZG Poly Sync 40 SY40-M WW In Stock £123.47
JCZG Poly EncorePro 525 USB EP525-M USB-A Headset In Stock £90.57
JCZG Poly Blackwire 8225 Stereo Microsoft Teams Certified USB-C In Stock £109.67
JCZG Poly Blackwire 3320 on-ear - wired - USB-C - black - Certified for Microsoft Teams, UC certified In Stock £29.68
JCZG Poly Poly Blackwire 3320 Stereo USB-C/A Adapter In Stock £29.68
JCZG Poly Blackwire 5220 Stereo USB-C Headset + 3.5mm Plug + USB-C In Stock £68.27
JCZG Poly Blackwire 3315 headset - on-ear - wired - 3.5 mm jack, USB-C - black - UC certified In Stock £45.23
JCZG Poly Savi 8420 Office headset - on-ear - DECT / Bluetooth - wireless - active noise cancelling In Stock £164.89
JCZG HP 724pf Series 7 Pro 23.8" 1920x1080 5ms HDMI DisplayPort IPS LED Monitor In Stock £167.73
JCZG Poly Blackwire 3210 headset - on-ear - wired - USB-C - black In Stock £25.87
JCZG Poly Blackwire 5210 Monaural USB-C Headset +3.5mm Plug +USB-C/A Adapter In Stock £59.09
JCZG Poly Blackwire 3310 headset - on-ear - wired - USB-A - black In Stock £24.80
JCZG Poly Blackwire 3220 headset - on-ear - wired - USB-C - black In Stock £29.67
JCZG Poly Blackwire 3220 headset - on-ear - wired - USB-C - black In Stock £25.27
JCZG Poly Blackwire 3310 Monaural USB-C Headset + USB-C/A Adapter In Stock £24.80
JCZG Poly EncorePro 515-M headset - on-ear - wired - USB-A - black In Stock £77.77
JCZG HP 125 - Mouse - wired - USB - black In Stock £6.20
JCZG HP P34hc G4 P-Series 34" 3440x1440 5ms HDMI DisplayPort USB-C LED Curved Monitor In Stock £501.52
JCZG Poly EncorePro 530 headset - in-ear - wired - Quick Disconnect - black In Stock £68.08
JCZG HP 732pk Series 7 Pro 32" 3840x2160 5ms HDMI DisplayPort Thunderbolt 4 IPS LED Monitor In Stock £621.41
JCZG HP E24mv G4 23.8" 1920x1080 5ms VGA HDMI DisplayPort IPS LED Conferencing Monitor In Stock £168.87
JCZG Poly Voyager 4310 Mono UC V4310 USB-C Microsoft Teams In Stock £108.17
JCZG HP 324pv Series 3 Pro 23.8" 1920x1080 5ms VGA HDMI LED Monitor In Stock £76.56
JCZG Poly HP Poly Blackwire 3325 - headset - 3.5 mm jack, USB-C In Stock £49.75
JCZG HP 230 - keyboard and mouse set - UK Input Device In Stock £36.36
JCZG Poly HP Poly Blackwire 3325 - headset - 3.5 mm jack, USB-C In Stock £48.40
JCZG HP 715 - mouse - multi-device, rechargeable - Bluetooth 3.0, 2.4 GHz - black In Stock £50.45
JCZG Poly Voyager Focus 2 - headset - USB-C via Bluetooth adapter In Stock £138.16
JCZG HP 524pf Series 5 Pro 24" 1920x1080 5ms HDMI DisplayPort IPS LED Monitor In Stock £112.58
JCZG HP 324ph Series 3 Pro 24" 1920x1080 5ms VGA HDMI DisplayPort IPS LED Monitor In Stock £90.06
JCZG HP 524pm Series 5 Pro 24" 1920x1080 5ms HDMI DisplayPort USB-C IPS LED Conferencing Monitor In Stock £253.29
JCZG HP 125 G2 - keyboard - full size - UK - black Input Device In Stock £8.22
JCZG Poly HP Poly Blackwire 3215 - headset - 3.5 mm jack, USB-C In Stock £46.27
JCZG HP 725 Wireless Keyboard + Mouse - 2.4GHz - Multi-Device In Stock £47.15
JCZG Poly Voyager Focus 2 - headset - USB-C via Bluetooth adapter In Stock £138.68
JCZG HP Desktop 320MK - Keyboard and mouse set - full size - USB - UK - black In Stock £15.34
JCZG Poly Blackwire 5210 - headset - 3.5 mm jack, USB-C In Stock £53.80
JCZG HP 435 - mouse - multi-device - 2.4 GHz, Bluetooth 5.2 In Stock £19.63
JCZG Poly Blackwire 3220 USB-C HS +USB-C/A Headset In Stock £26.96
JCZG Poly Blackwire 5220 USB-C HS +USB-C/A Headset In Stock £55.67
JCZG HP 320K Wired Keyboard In Stock £11.79
JCZG Poly Poly Voyager Focus 2 - Headset - On-Ear In Stock £133.27
Screen Size: 16in
Brand: HP
Price Range Ex VAT: £750 - £1000
