Drive business growth with the commercial-grade HP Pro x360 435 convertible touchscreen laptop. Focus on business priorities with a well-equipped device for hybrid work, that's durably built and easily upgradeable for long-term performance.
Security is your top priority
The HP Wolf Pro Security Edition provides preconfigured enterprise-level PC protection for small and medium sized businesses. -
Look your best, even in low light
Optimize your video calls in low lighting with an HD camera and temporal noise reduction that lowers the effects of visual noise and pixelation. -
Fast and efficient wireless LAN
The portability of your PC and the reliability of a fast connection determines where you can work. Get a fast and reliable connection in dense wireless environments with gigabit-speed Wi-Fi 6. -
Automatic recovery from firmware attacks
Firmware attacks can completely devastate your PC. Stay protected with HP's self-healing BIOS - HP Sure Start Gen7 automatically recovers the BIOS from malware, rootkits, or corruption. -
Keep your PC's security protections in place
Stop unwanted changes to security settings and help limit the spread of malware with HP Sure Run Gen5 which identifies, quarantines, and provides reporting on attackers trying to kill processes. -
Browse confidently
Help protect your PC from websites and read only Microsoft Office and PDF attachments with embedded malware, ransomware, or viruses with hardware-enforced security from HP Sure Click.
- HP Pro x360 435 G10 Notebook - 13.3" - AMD Ryzen 5 - 7530U - 8 GB RAM - 256 GB SSD - UK - with HP Wolf Pro Security Edition (1 year)
- Product Type
- Notebook - 2-in-1 - flip design
- Operating System
- Win 11 Pro - English
- Processor
- AMD Ryzen 5 7530U / 2 GHz, up to 4.5 GHz / 16 MB Cache
- Memory
- 8 GB DDR4 (1 x 8 GB)
- Storage
- 256 GB SSD - NVMe, HP Value
- Display
- 13.3" WLED touchscreen 1920 x 1080 / Full HD @ 60 Hz
- Graphics
- AMD Radeon Graphics
- Input Device
- ClickPad
- Keyboard
- UK
- Keyboard Backlight
- Integrated Webcam
- Networking
- 802.11a/b/g/n/ac/ax (Wi-Fi 6E), Bluetooth 5.3
- Battery
- 3-cell
- HP Tamper Lock
- Security
- Trusted Platform Module (TPM 2.0) Security Chip, fingerprint reader
- Pike silver aluminium
- 30.85 cm x 22.29 cm x 1.79 cm
- 1.45 kg
- Localisation
- Manufacturer Selling Program
- HP Smart Buy
- Environmental Standards
- TCO Certified Notebooks 9, ENERGY STAR Qualified
- Carbon Footprint
- 130 kg carbon emissions
- Limited warranty - parts and labour - 1 year
- Bundled with
- HP Wolf Pro Security Edition (1 year)
- Product Type
- Notebook - Yes - flip design
- Operating System
- Windows 11 Pro - English
- Bundled with
Processor / Chipset
- CPU
- Max Turbo Speed
- 4.5 GHz
- Number of Cores
- 6-core
- Cache
- L3 - 16 MB
- RAM
- 8 GB (1 x 8 GB)
- Max RAM Supported
- 32 GB
- Technology
- DDR4 SDRAM - non-ECC
- Speed
- 3200 MHz
- Rated Speed
- 3200 MHz
- Form Factor
- SO-DIMM 260-pin
- Slots Qty
- 2
- Empty Slots
- 1
Storage
- Main Storage
- 256 GB SSD M.2 2280 PCIe 4.0 x4 - NVM Express (NVMe), HP Value
Display
- 13.3" - IPS
- LCD Backlight Technology
- WLED backlight
- Touchscreen
- Resolution
- 1920 x 1080 (Full HD)
- V-Sync Rate at Max Res.
- 60 Hz
- Widescreen
- Image Brightness
- 250 cd/m²
- Colour Gamut
- 45% NTSC
- Slim Design, Full HD ultra wide-viewing angle (UWVA) BrightView eDP, Corning Gorilla glass 5
- Keyboard Name
- HP Premium
Audio & Video
- Graphics Processor
- Camera
- Yes - HD
- Video Resolutions
- 720p
- Camera Features
- Privacy shutter, IR camera, Windows Hello
- Sound
- Dual stereo speakers, dual array microphone
- Codec
- Realtek ALC3247-CG
Input
- Keyboard, ClickPad
- Keyboard Layout
- UK
- Multi-touch clickpad, gesture function, spill-resistant, DuraKeys
Communications
- Wireless
- Bluetooth Class
- Class 1.5
- Wireless Controller
- MediaTek RZ616 - PCI Express Mini Card (M.2)
- Miracast, Wake-on-LAN (WOL), dual stream (2x2)
- IEEE 802.11d, IEEE 802.11i, Wi-Fi CERTIFIED, IEEE 802.11h, IEEE 802.11e, IEEE 802.11k, IEEE 802.11j, IEEE 802.11w, IEEE 802.11r, IEEE 802.11v, IEEE 802.11mc
- Technology
- 3-cell lithium polymer
- 190 g
- Capacity
- 42.75 Wh
AC Adapter
- Input
- AC 115/230 V (50/60 Hz)
- Output
- 45 Watt, 19.5 V, 8 A
Connections & Expansion
- Interfaces Details
- USB-C 3.1 Gen 2 (supports DisplayPort 1.4 Alt Mode) (Power Delivery) , USB 3.2 Gen 1 (charging) , USB 3.2 Gen 1 , HDMI , Headphone/microphone combo jack
- Memory Card Reader
- Yes (microSD)
Software
- Software Included
- HP Support Assistant, HP Power Manager, HP Hotkey Support, HP Secure Erase, HP Client Catalogue (free download), HP Notifications, HP Connection Optimizer, HP Sure Click, HP Privacy Settings, HP Cloud Recovery, HP Sure Sense, HP Sure Admin, HP QuickDrop, HP Client Management Script Library (free download), HP BIOSphere Gen6, HP Wake on WLAN, myHP, HP Image Assistant Gen5 (free download), HP Smart Support (free download), HP Connect for Microsoft Endpoint Manager, HP Patch Assistant (free download), HP Sure Recover Gen5, HP Sure Run Gen5, HP PC Hardware Diagnostics Windows, HP Services Scan, HP Sure Start Gen7, HP Driver Packs (free download), HP Manageability Integration Kit Gen4 (free download)
- Integrated Options
- HP Tamper Lock
- Security
- BIOS Absolute Persistence, HP Fast Charge, BIOS Update via Network, MIL-STD-810H tested, Secured-core PC enabled
- Theft/Intrusion Protection
- Security Slot Type
- Kensington nano security slot
- Included Accessories
- HP 45 Watt Smart nPFC AC Adapter
- CSA, VCCI, BSMI, GS, ISO 9241, CCC, FIPS 140-2 Level 2, FCC, RoHS, KCC, CISPR, ICES, Common Criteria EAL4+, KC, SRRC, NCC, low halogen, UL 62368-1, TEC, KES, Low Blue Light certified (LBL), Ukraine NSoC, EAEU Compliance, Saudi Arabian Compliance
- Localization
- HP Smart Buy
- 1.45 kg
- Shipping Dimensions (WxDxH) / Weight
- 6.9 cm x 48.3 cm x 30.5 cm
Sustainability Information
- TCO Certified
- - TCO Certified Notebooks 9
- ENERGY STAR Certified
- Carbon Footprint
- Manufacturing (kg CO2e)
- 125
- Logistics (kg CO2e)
- 4
- Use (kg CO2e)
- 1
- EOL (kg CO2e)
- 0.5
- Total Carbon w/o Use Phase (kg CO2e)
- 129
- 0 °C
- 35 °C
- 10 - 90% (non-condensing)
- Shock Tolerance (operating)
- 40 g @ 2 ms half-sine
- Shock Tolerance (non-operating)
- 200 g @ 2 ms half-sine
- Vibration Tolerance (operating)
- 0.75 g @ RMS (random)
- Vibration Tolerance (non-operating)
- 1.5 g @ RMS (random)
Essential Accessories (12)
Get more from your purchase from one of our essential accessories
HP 65W Smart AC Adapter | In Stock | £21.18 |
HP 90W Smart AC Adapter | In Stock | £32.21 |
HP USB-C Dock G5 Docking Station USB-C GigE 100 Watt | In Stock | £116.78 |
HP USB-C TO RJ45 Adapter | In Stock | £187.85 |
HP Thunderbolt Dock G4 - HDMI, 2 x DP, Thunderbolt, USB-C - 1GbE, 2.5GbE | In Stock | £144.80 |
HP USB-C Power Adapter - 65 Watt | In Stock | £57.16 |
HP Prelude Top Load 15.6" Notebook Carrying Case | In Stock | £10.35 |
HP USB-C LC Power Adapter - 65 Watt | In Stock | £15.28 |
HP Smart AC Adapter - 65 Watt | In Stock | £18.02 |
HP Renew Business - Notebook carrying shoulder bag - 17.3" | In Stock | £19.13 |
HP Slim - digital pen - harbor grey | In Stock | £33.49 |
HP USB-C 65W LAPTOP CHARGER UK | In Stock | £19.60 |
Warranty Packs (8)
Protect your investment by taking out one of our great value warranty packs
HP Care Pack Pick-Up and Return Service Extended Service Agreement 3 Years | In Stock | £54.14 |
HP Care Pack Pick-Up and Return Service Extended Service Agreement 2 Years | In Stock | £36.49 |
HP Care Pack NBD Hardware Support for Travelers with Defective Media Retention 3 Years On-Site | In Stock | £87.09 |
HP Care Pack Next Business Day Hardware Support Extended Service Agreement 5 Years On-Site | In Stock | £120.04 |
HP Care Pack Pick-Up and Return Service Extended Service Agreement 4 Years | In Stock | £71.79 |
HP Care Pack Next Business Day Hardware Support Extended Service Agreement 3 Years On-Site | In Stock | £76.50 |
HP Care Pack NBD HW Support with Defective Media Retention Extended Service Agreement 3 Yrs On-Site | In Stock | £84.19 |
HP Care Pack Pick-Up and Return Service with Defective Media Retention - 3 years | In Stock | £65.90 |
Other bundles (57)
HP USB-C To VGA Adapter | In Stock | £22.09 |
HP USB Travel Mouse | In Stock | £10.91 |
HP USB G2 Stereo Headset | In Stock | £20.44 |
HP 128 Wired Mouse | In Stock | £8.56 |
HP 455 Programmable Keyboard - Wireless - UK | In Stock | £26.46 |
HP USB-C to RJ45 Adapter G2 | In Stock | £13.20 |
HP 325 Webcam | In Stock | £19.07 |
Poly Voyager Focus 2 UC-M C USB-A WW | In Stock | £99.99 |
Poly Voyager Surround 80 UC USB-C Headset + USB-C/A Adapter | In Stock | £240.58 |
Poly Voyager Surround 80 UC MS Teams Certified USB-C + USB-C/A | In Stock | £234.68 |
Poly Voyager 4320 UC V4320-M C USB-A WW | In Stock | £124.75 |
Poly Voyager 4320 UC V4320 C USB-C WW | In Stock | £103.93 |
Poly TRIO C60 EXPANSION MICROPHONES | In Stock | £134.01 |
Poly Blackwire C3225 USB-A Headset | In Stock | £51.43 |
Poly EncorePro HW520 Stereo Headset (Noise Cancelling) | In Stock | £81.71 |
Poly EncorePro HW510 Mono Headset (N/C) | In Stock | £86.11 |
Poly Voyager 4320 UC V4320-M C USB-C WW | In Stock | £98.60 |
Poly Voyager 4310 UC V4310-M C USB-A WW | In Stock | £110.75 |
Poly Voyager 4320 UC V4320 C USB-C CS WW | In Stock | £119.34 |
Poly Voyager 4320 UC V4320-M C USB-C CS WW | In Stock | £110.60 |
Poly Voyager 4320 UC V4320 C USB-A WW | In Stock | £97.00 |
Poly Voyager 4310 UC V4310 C USB-A WW | In Stock | £113.52 |
Poly EncorePro 525 USB EP525 USB-A Headset | In Stock | £84.71 |
Poly EncorePro HW510 Mono Headset (VT) | In Stock | £73.73 |
Poly Voyager Focus 2 UC-M USB-C Headset with Stand | In Stock | £141.12 |
Poly Blackwire 8225 Stereo Microsoft Teams Certified USB-C | In Stock | £92.95 |
Poly Blackwire 3320 on-ear - wired - USB-C - black - Certified for Microsoft Teams, UC certified | In Stock | £34.67 |
Poly Poly Blackwire 3320 Stereo USB-C/A Adapter | In Stock | £33.49 |
Poly Blackwire 5220 Stereo USB-C Headset + 3.5mm Plug + USB-C | In Stock | £75.19 |
Poly Spare BT700 Bluetooth USB Adapter | In Stock | £58.49 |
Poly Blackwire 3315 headset - on-ear - wired - 3.5 mm jack, USB-C - black - UC certified | In Stock | £49.32 |
HP 724pf Series 7 Pro 23.8" 1920x1080 5ms HDMI DisplayPort IPS LED Monitor | In Stock | £164.32 |
Poly Blackwire 3210 headset - on-ear - wired - USB-C - black | In Stock | £25.20 |
Poly Blackwire 5210 Monaural USB-C Headset +3.5mm Plug +USB-C/A Adapter | In Stock | £65.77 |
Poly Blackwire 3310 headset - on-ear - wired - USB-A - black | In Stock | £28.00 |
Poly Blackwire 3220 headset - on-ear - wired - USB-C - black | In Stock | £31.11 |
Poly Blackwire 3220 headset - on-ear - wired - USB-C - black | In Stock | £29.33 |
Poly Blackwire 3310 Monaural USB-C Headset + USB-C/A Adapter | In Stock | £28.00 |
Poly EncorePro 515-M headset - on-ear - wired - USB-A - black | In Stock | £75.67 |
HP 125 - Mouse - wired - USB - black | In Stock | £6.26 |
HP P34hc G4 P-Series 34" 3440x1440 5ms HDMI DisplayPort USB-C LED Curved Monitor | In Stock | £320.60 |
Poly EncorePro 530 headset - in-ear - wired - Quick Disconnect - black | In Stock | £81.56 |
Poly EncorePro 530 - headset - Quick Disconnect | In Stock | £81.56 |
HP 732pk Series 7 Pro 32" 3840x2160 5ms HDMI DisplayPort Thunderbolt 4 IPS LED Monitor | In Stock | £825.46 |
HP E24mv G4 23.8" 1920x1080 5ms VGA HDMI DisplayPort IPS LED Conferencing Monitor | In Stock | £153.30 |
HP 324pv Series 3 Pro 23.8" 1920x1080 5ms VGA HDMI LED Monitor | In Stock | £73.89 |
Poly EncorePro HW520D - headset - Quick Disconnect | In Stock | £107.03 |
HP E24m G4 23.8" 1920x1080 5ms HDMI DisplayPort USB-C IPS LED Conferencing Monitor | In Stock | £211.74 |
Poly Blackwire 3325 - headset - 3.5 mm jack, USB-C | In Stock | £54.64 |
HP 230 - keyboard and mouse set - UK Input Device | In Stock | £36.54 |
HP 715 - mouse - multi-device, rechargeable - Bluetooth 3.0, 2.4 GHz - black | In Stock | £51.11 |
HP 524pf Series 5 Pro 24" 1920x1080 5ms HDMI DisplayPort IPS LED Monitor | In Stock | £110.29 |
HP E27 G5 27" 1920x1080 5ms HDMI DisplayPort USB IPS LED Monitor | In Stock | £127.93 |
HP 324ph Series 3 Pro 24" 1920x1080 5ms VGA HDMI DisplayPort IPS LED Monitor | In Stock | £86.02 |
HP 524pm Series 5 Pro 24" 1920x1080 5ms HDMI DisplayPort USB-C IPS LED Conferencing Monitor | In Stock | £242.62 |
