HP Pro Slate 12 Qualcomm Snapdragon APQ8074-AB 2GB 32GB 12.3" Android 4.4.4 (KitKat)
Quicklinx: BBDZWS00 Mfr#: K7X87AA#ABU
  • Android 4.4.4 (KitKat)
Work seamlessly with the HP Pro Slate 12, which runs Android Lollipop with native Work Profiles, a feature of Android for Work, and has hardware-enabled security, a Qualcomm Snapdragon 800 series processor, and an integrated HP Duet Pen.
  • Designed to defend
    Help protect your tablet with device authentication and tamper-resistant features.
  • Enterprise-friendly
    Customize your enterprise mobility solution with HP Managed Mobility Services.
  • Cloud-based IT management made simple
    Manage data, security, and a wide array of branded devices from the cloud with HP Touchpoint Manager. Use Locate Device to remotely locate, lock, and wipe your tablet.
  • Ready for your environment
    Easily integrate your devices with optional, leading EMM solutions.
  • Excel with built-in extras
    Do more with up to 32 GB storage, micro USB 2.0 connectivity, and integrated communication tools.
  • Functional for business
    Go business-class all the way with innovative optional accessories that connect easily with a zero-force, Pogo pin connector. Make it yours with a choice of adapters, HP Bluetooth Keyboard Folio or HP Paper Folio for use with the HP Duet Pen.
HP Pro Slate 12 - tablet - Android 4.4.4 (KitKat) - 32 GB - 12.3"
Tablet
Operating System
Android 4.4.4 (KitKat) - English
Display
12.3" IPS - 1600 x 1200 (163 ppi) - Multi-Touch
Qualcomm Snapdragon 800 (Quad-Core)
Processor Clock Speed
2.3 GHz
Storage
32 GB eMMC
RAM
2 GB
Supported Flash Memory Cards
microSD
Wireless Connectivity
Bluetooth 4.0, 802.11a/b/g/n/ac, NFC
Rear Camera
8 Megapixel focus: automatic
Front Camera
2 Megapixel
Navigation System
GPS
Battery Run Time
Up to 14.75 hours
22.195 cm x 0.799 cm x 30.03 cm
850 g
Grey
English / United Kingdom
1-year warranty
Tablet
Operating System
Display
12.3" IPS
Resolution
Touchscreen
Multi-Touch
Image Aspect Ratio
4:3
10-point multi-touch, Direct Bonding technology, Corning Concore Glass, Wide Viewing Angle
2.3 GHz
Number of Cores
Quad-Core
Storage
32 GB eMMC
RAM
2 GB - LPDDR3 SDRAM
microSD
Max Supported Capacity
32 GB
Communications
Security Protocols & Features
Wi-Fi Miracast, Android Beam
Rear Camera
Sensor Resolution
8 Megapixel
Focus Adjustment
Automatic
HDR Mode
Auto HDR mode
Front Camera
Sensor Resolution
2 Megapixel
Navigation System
Receiver
GPS
Multimedia
Audio
Two microphones, stereo speakers
Software
Preloaded Software
Skype, Evernote, Secure Boot, Kingsoft Office, Corel Painter Mobile, HP Print, Avast Mobile Security, HP TouchPoint Manager, HP Notes, HP Duet Pen Software
Expansion and Connectivity
Expansion Slots
1 x microSD , 1 x Nano-SIM card , 1 x ZIF
1 x headset mini jack (3.5mm) , 1 x Micro-USB , 1 x HDMI (supporting via optional adapter)
Lithium polymer
37 Wh
Run Time
Up to 14.75 hours
Run Time Details
Video playback: up to 14.75 hour(s)
Grey
Sensors
Accelerometer, ambient light sensor, proximity sensor, digital compass, barometer, gyro sensor, hall sensor
Capacitive touch screen, UV protection, soft-touch surface, Data-at-Rest Encryption, SecureBoot, smudge-resistant, ARM TrustZone, DTS Sound+, TrustZone-based Key Store, 256-bit hardware acceleration
Power adapter, stylus, SD/SIM card tray eject tool
Micro-USB to USB cable
CSA, UL, CISPR 24, EN55022, ICES-003, EN55024, CISPR 22, CB, RSS-102, EMC, IC, FCC, FIPS 140-2, FCC CFR47 Part 15, EN 60950-1, EN 301 908, EN 62311, EN 300.440, EN 300 328, EN 301 489, EN 301 893
22.195 cm
0.799 cm
30.03 cm
850 g
Limited warranty - parts and labour - 1 year
10 - 90% (non-condensing)
Min Storage Temperature
-20 °C
Max Storage Temperature
60 °C
