Let nothing stand in your way
Experience the new features of Windows 10 Pro on the thin, light, touch optional HP ProBook 450. -
Protect your data with multi-factor authentication
Fortify your security by using multiple factors of authentication including fingerprints and facial recognition. -
Storage options
Get the best of both worlds with dual solid-state and hard drive storage options from HP. -
Outstanding battery life and fast charging
Battery life that gets you through the workday and beyond. Fast charge 90% in 90 minutes. -
Stay Connected
Stay connected with self-healing wireless driver technology and support for the latest global 4G LTE wireless broadband technology. -
Tested to go the distance
Stand up to the workload with a ProBook that is designed to pass MIL-STD 810G testing.
- HP ProBook 450 G5 Notebook - 15.6" - Intel Core i3 - 7100 - 8 GB RAM - 256 GB SSD - UK
- Product Type
- Notebook
- Operating System
- Win 10 Pro - English
- Processor
- Intel Core i3 (7th Gen) - 7100 / 3.9 GHz / 3 MB Cache
- Memory
- 8 GB DDR4 (1 x 8 GB)
- Storage
- 256 GB SSD - NVMe, TLC, HP Value
- Display
- 15.6" LED backlight 1366 x 768 / HD
- Graphics
- Intel HD Graphics 630
- Input Device
- ClickPad
- Keyboard
- UK
- Integrated Webcam
- Networking
- 802.11a/b/g/n/ac, Bluetooth 4.2, Gigabit Ethernet
- Battery
- 3-cell
- Security
- Trusted Platform Module (TPM 2.0) Security Chip, fingerprint reader
- 37.6 cm x 26.3 cm x 2.09 cm
- 2.02 kg
- Localisation
- Product Type
- Notebook
- Operating System
- Windows 10 Pro - English
Processor / Chipset
- CPU
- Intel Core i3 (7th Gen) 7100 / 3.9 GHz
- Number of Cores
- Dual-Core
- Cache
- 3 MB
- 64-bit Computing
- Hyper-Threading Technology, Intel Smart Cache
- RAM
- 8 GB (1 x 8 GB)
- Max RAM Supported
- 32 GB
- Technology
- DDR4 SDRAM
- Speed
- 2133 MHz
- Rated Speed
- 2400 MHz
- Form Factor
- SO-DIMM 260-pin
- Slots Qty
- 2
- Empty Slots
- 1
Storage
- Main Storage
- 256 GB SSD M.2 2280 PCIe - NVM Express (NVMe), triple-level cell (TLC), HP Value
Display
- 15.6" - TN
- LCD Backlight Technology
- LED backlight
- Resolution
- 1366 x 768 (HD)
- Widescreen
- Image Brightness
- 220 cd/m²
- Colour Gamut
- 45% sRGB
- HD standard-viewing angle (SVA) eDP anti-glare
- Keyboard Name
- HP Premium
Audio & Video
- Graphics Processor
- Camera
- Yes - HD
- Video Resolutions
- 720p
- Sound
- Stereo speakers, dual array microphone
Input
- Keyboard, ClickPad
- Keyboard Layout
- UK
- Spill-resistant, multi-touch clickpad, ClickPad with gesture support
Communications
- Wireless
- Bluetooth Class
- Class 2
- Wireless Controller
- Intel Dual Band Wireless-AC 8265
- Network Interface
- Gigabit Ethernet
- Ethernet Controller
- Realtek RTL8111HSH
- IEEE 802.1x, IEEE 802.11i, Wi-Fi CERTIFIED
- Technology
- 3-cell Lithium Ion
- Capacity
- 48 Wh
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 45 Watt, 19.5 V
Connections & Expansion
- Interfaces Details
- USB-C 3.1 , USB 2.0 (powered) , 2 x USB 3.1 Gen 1 , HDMI , LAN , VGA , Headphone/microphone combo jack
- Memory Card Reader
- Yes (SD Card, SDHC Card, SDXC Card)
- Security
- HP Automatic Drive Lock, HP DriveLock, Power On Authentication, Pre-boot Authentication, Master Boot Record Security
- Theft/Intrusion Protection
- Security Slot Type
- Kensington security slot
- Included Accessories
- Power adapter
- CSA, UL, VCCI, BSMI, GOST, SABS, CCC, FCC, A-Tick, ICES, KC, CIT
- Localization
- 2.02 kg
Sustainability Information
- TCO Certified
- 0 °C
- 35 °C
- 10 - 90% (non-condensing)
- Shock Tolerance (operating)
- 40 g @ 2 ms half-sine pulse
- Shock Tolerance (non-operating)
- 200 g @ 2 ms half-sine pulse
- Vibration Tolerance (operating)
- 0.75 g @ RMS (random)
- Vibration Tolerance (non-operating)
- 1.5 g @ RMS (random)
