This keyboard can be used as a replacement for your original laptop keyboard, if the original is damaged or broken. The keyboards are very easy to fit, with no soldering required.
- HP - keyboard - UK - silver, jack black Input Device
- Keyboard
- Interface
- USB
- Connectivity Technology
- Wired
- Localization and Layout
- UK
- Silver, jack black
- Designed For
- HP t5325, t5545, t5550, t5565, t5570, t5630, t5740, t5745; Flexible t610; Thin Client t5125, t5135, t5140, t5300, t5305, t5500, t5510, t5515, t5520, t5525, t5530, t5700, t5710, t5720, t5723, t5725, t5730; Workstation Z420, Z620, Z820; HPE t5145, t5540; Compaq Thin Client t5735
- Keyboard
- Interface
- USB
- UK
- Region
- United Kingdom
- OS Required
- Windows 8
- Designed For
- HP t5325, t5545, t5550, t5565, t5570, t5570e, t5630, t5630w, t5740, t5740e, t5740w, t5745 , HP Flexible t610, t610 PLUS , HP Workstation Z420, Z620, Z820 , HP Compaq Thin Client t5125, t5135, t5140, t5300, t5305, t5500, t5510, t5515, t5520, t5525, t5530, t5700, t5710, t5720, t5723, t5725, t5730, t5730w , HPE t5145, t5540 , HPE Compaq Thin Client t5735
