HP Pro 400 G9 Mini Intel Core i5-12500T 8GB 256GB SSD Windows 10 Professional 64-bit
Quicklinx: H1MJWS00 Mfr#: 6B2D2EA#ABU
  • Core i5
  • IEEE 802.11n
The HP Pro Mini 400 provides users with the commercial-grade performance, security,?and the flexible deployment capabilities?needed for small workspaces.?This?ultrasmall form factor PC?is?powered by an Intel ?processor?and?protected with always-on security you can trust.
  • Windows 11
    Work anywhere without compromising on performance or security with Windows 11 powered by HP's collaboration and connectivity technology.
  • High performance, high portability
    Get the exceptional combination of responsive performance, connectivity and speed with a 12th Gen Intel Core processor that lets you launch, create, and connect fast and reliably.
  • Automatic recovery from firmware attacks
    Firmware attacks can completely devastate your PC. Stay protected with HP's self-healing BIOS - HP Sure Start Gen7 automatically recovers the BIOS from malware, rootkits, or corruption.
  • Work without interruption
    Keep productivity high and downtime low with the fully integrated and automated features of the HP BIOSphere Gen6 firmware ecosystem. Your PCs have extra protection thanks to automatic updates and security checks.
  • Browse confidently
    Help protect your PC from websites and read only Microsoft Office and PDF attachments with embedded malware, ransomware, or viruses with hardware-enforced security from HP Sure Click.
  • Erase your drive
    HP Secure Erase removes the contents of a hard drive for repurposing or reassignment.
HP Pro 400 G9 - mini Core i5 12500T 2 GHz - 8 GB - SSD 256 GB - UK
Personal computer - mini
Intel Core i5 (12th Gen) 12500T / 2 GHz (up to 4.4 GHz, (6-core)
Processor Main Features
Intel Turbo Boost Technology 2
Cache Memory
18 MB L3 Cache
Cache Per Processor
18 MB
RAM
8 GB (installed) / 64 GB (max) - DDR4 SDRAM
Storage Controller
SATA
Hard Drive
SSD 256 GB - PCI Express - M.2 2280 - NVM Express (NVMe)
Optical Storage
No optical drive
Graphics Controller
Intel UHD Graphics 770 Dynamic Video Memory Technology
Audio Output
Stereo
1GbE, 802.11a, 802.11b/g/n, Wi-Fi 5, Bluetooth 5.2, Wi-Fi 6E
Keyboard
(50/60 Hz)
OS Provided
Windows 10 Pro 64-bit Edition (downgrade from Windows 11 Pro) + Windows 11 Pro Licence
Software Included
HP Support Assistant, HP PC Hardware Diagnostics UEFI, HP Secure Erase, HP Client Catalogue (free download), HP Setup Integrated OOBE, HP Notifications, HP Connection Optimizer, HP Privacy Settings, HP Cloud Recovery, HP QuickDrop, HP Client Management Script Library (free download), HP BIOSphere Gen6, myHP, Touchpoint Customiser for Commercial, HP Desktop Support Utilities, HP Image Assistant Gen5 (free download), HP Easy Clean, HP Smart Support (free download), HP Manageability Integration Kit (free download), HP Patch Assistant (free download)
17.7 cm x 17.5 cm x 3.42 cm
1.42 kg
Environmental Standards
TCO Certified Desktops 9, ENERGY STAR Qualified
Carbon Footprint
150 kg carbon emissions
Limited warranty - parts and labour - 1 year - on-site
Personal computer
Product Form Factor
Mini
Sensors
HP Tamper Lock
Embedded Security
Trusted Platform Module (TPM 2.0) Security Chip
Processor / Chipset
CPU
Clock Speed
2 GHz
Max Turbo Speed
4.4 GHz
Number of Cores
6-core
CPU Qty
1
Max CPU Qty
1
CPU Upgradability
Upgradable
Chipset Type
Intel Q670
Cache Memory
Installed Size
L3 Cache - 18 MB
Cache Per Processor
18 MB
RAM
Installed Size
DDR4 SDRAM
Effective Memory Speed
3200 MHz
Rated Memory Speed
3200 MHz
SO-DIMM 260-pin
Slots
2 (Total) / 1 (empty)
Configuration Features
1 x 8 GB
Hard Drive
SSD - M.2 2280
1 x 256 GB
Interface Type
PCI Express
NVM Express (NVMe)
Storage Controller
1 x SATA
Channel Qty
1
Optical Storage
No optical drive
Monitor
Monitor Type
None.
Graphics Controller
Graphics Processor
Video Interfaces
HDMI, DisplayPort
HDCP Compatible
Audio Output
Sound Output Mode
Stereo
Max Sampling Rate
192 kHz
High Definition Audio
Input Device
Mouse, keyboard
Keyboard
Keyboard Name
HP 320K
USB
Localization & Layout
Mouse
Mouse Name
HP 125
Interface (Bus) Type
PCI Express Mini Card (M.2)
Wireless LAN Supported
Wireless NIC
Intel Wi-Fi 6E AX 211
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, Bluetooth 5.2, IEEE 802.11ax (Wi-Fi 6E)
Remote Management Protocol
SNMP 2
Wake on LAN (WoL), ACPI support, auto-uplink (auto MDI/MDI-X), PXE 2.1 support, dual stream (2x2)
IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.11d, IEEE 802.1x, IEEE 802.11i, Wi-Fi CERTIFIED, IEEE 802.11h, IEEE 802.11e, IEEE 802.11k, IEEE 802.3az, IEEE 802.11r, IEEE 802.11v
Bays
1 (total) / 1 (free) x internal 2.5"
Slots
1 (total) / 0 (free) x M.2 Card - 2230 (PCIe x1 mode (for wireless module)) , 1 (total) / 0 (free) x M.2 Card - 2280 (PCIe x4 mode (for internal storage))
1 x headphones/microphone (1 in front) (CTIA headset support) , 2 x USB 3.2 Gen 2 (2 in front) (one of them is charging) , 1 x USB-C 3.2 Gen 2x2 (1 in front) (charging) , 1 x USB 3.2 Gen 2 , 2 x DisplayPort 1.4a , 1 x HDMI , 2 x USB 3.2 Gen 1 (wake functionality) , 1 x LAN (Gigabit Ethernet)
Theft/Intrusion Protection
Security lock slot (cable lock sold separately), padlock loop, chassis intrusion sensor
Security Slot Type
Kensington security slot
FCC Class B certified, ICES-003, CCC, FIPS 140-2 Level 2, RoHS, WEEE, KCC Class B, Common Criteria EAL4+, VCCI Class B, low halogen, CAN/CSA-C22.2 No. 62368-1, UL 62368-1, IEEE 1680.1-2018
Power adapter
Power Device Name
HP Smart AC Adapter
AC 90-264 V (50/60 Hz)
Power Provided
90 watt
Efficiency
89% (230VAC), 88% (115VAC)
Power Factor Correction
Yes (active)
Operating System / Software
OS Provided
Windows 10 Pro 64-bit Edition (available through downgrade rights from Windows 11 Pro) + Windows 11 Pro Licence - English
Software
Sustainability Information
TCO Certified
ENERGY STAR Certified
Carbon Footprint
Manufacturing (kg CO2e)
101
Use (kg CO2e)
46
EOL (kg CO2e)
0.8
17.7 cm
17.5 cm
3.42 cm
1.42 kg
Shipping Width
49.7 cm
Shipping Depth
13.2 cm
Shipping Height
23.5 cm
Shipping Weight
3.4 kg
5 °C
35 °C
5 - 90% (non-condensing)
Warranties (2)
H1MJ HP Care Pack Next Business Day Hardware Support - Extended serv In Stock £39.36
H1MJ HP Care Pack Next Business Day Hardware Support with Defective Media Retention - 5 years In Stock £84.57
Accessories (2)
H1MJ HP Dual VESA Sleeve v3 - Desktop sleeve for HP 260 G4 In Stock £26.92
H1MJ HP B250 Mounting Kit for LCD Display/Thin Client In Stock £19.91
Keyboards and Mice (2)
H1MJ HP 128 Wired Mouse In Stock £8.49
H1MJ HP 455 Programmable Keyboard - Wireless - UK In Stock £46.54
Other bundles (44)
H1MJ HPE DisplayPort DVI-D Adapter In Stock £19.77
H1MJ HPE DisplayPort to VGA Adapter In Stock £13.14
H1MJ HPE USB to Serial Port Adapter In Stock £13.95
H1MJ HP USB G2 Stereo Headset In Stock £20.27
H1MJ HP Flex IO V2 Card - VGA port In Stock £12.28
H1MJ Poly Voyager Surround 80 UC USB-C Headset + USB-C/A Adapter In Stock £208.06
H1MJ Poly Voyager Surround 80 UC MS Teams Certified USB-C + USB-C/A In Stock £216.07
H1MJ Poly DA75 Sound Card In Stock £27.52
H1MJ Poly Voyager 4320 UC V4320-M C USB-A WW In Stock £103.25
H1MJ Poly Voyager 4320 UC V4320 C USB-C WW In Stock £106.60
H1MJ Poly EncorePro HW520 Stereo Headset (Noise Cancelling) In Stock £65.27
H1MJ Poly DA85 Headset Cable - USB-C to Quick Disconnect In Stock £43.34
H1MJ Poly EncorePro HW510 Mono Headset (N/C) In Stock £72.84
H1MJ Poly Voyager 4320 UC V4320-M C USB-A CS WW In Stock £108.73
H1MJ Poly Voyager 4320 UC V4320-M C USB-C WW In Stock £103.25
H1MJ Poly Voyager 4320 UC V4320 C USB-A CS WW In Stock £117.00
H1MJ Poly Voyager 4320 UC V4320 C USB-C CS WW In Stock £117.00
H1MJ Poly Voyager 4320 UC V4320-M C USB-C CS WW In Stock £111.68
H1MJ Poly Voyager 4310 UC V4310-M C USB-A CS WW In Stock £108.17
H1MJ Poly Voyager 4320 UC V4320 C USB-A WW In Stock £103.25
H1MJ Poly Voyager 4310 UC V4310 C USB-A WW In Stock £98.17
H1MJ Poly Voyager 4310 UC V4310 C USB-A CS WW In Stock £108.17
H1MJ Poly Sync 10 SY10-M USB-A/C WW In Stock £53.41
H1MJ Poly EncorePro 525 USB EP525 USB-A Headset In Stock £87.21
H1MJ Poly Voyager Focus 2 UC-M USB-C Headset with Stand In Stock £141.12
H1MJ Poly Sync 40 SY40-M WW In Stock £123.47
H1MJ Poly Blackwire 8225 Stereo Microsoft Teams Certified USB-C In Stock £109.67
H1MJ Poly Poly Blackwire 3320 Stereo USB-C/A Adapter In Stock £29.68
H1MJ Poly Blackwire 5220 Stereo USB-C Headset + 3.5mm Plug + USB-C In Stock £68.27
H1MJ Poly Blackwire 3315 headset - on-ear - wired - 3.5 mm jack, USB-C - black - UC certified In Stock £45.04
H1MJ HyperX Cloud Stinger 2 Core Gaming Headset In Stock £37.49
H1MJ HyperX SoloCast USB Microphone In Stock £50.55
H1MJ HyperX Pulsefire Core Gaming Mouse In Stock £28.26
H1MJ HyperX Pulsefire Mat Gaming Mouse Pad In Stock £12.63
H1MJ HyperX Wrist Rest In Stock £20.11
H1MJ Poly Blackwire 3210 headset - on-ear - wired - USB-C - black In Stock £25.87
H1MJ Poly Blackwire 5210 Monaural USB-C Headset +3.5mm Plug +USB-C/A Adapter In Stock £59.09
H1MJ Poly Blackwire 3310 headset - on-ear - wired - USB-A - black In Stock £24.80
H1MJ Poly Blackwire 3220 headset - on-ear - wired - USB-C - black In Stock £29.67
H1MJ Poly Blackwire 3220 headset - on-ear - wired - USB-C - black In Stock £25.27
H1MJ Poly Blackwire 3310 Monaural USB-C Headset + USB-C/A Adapter In Stock £24.80
H1MJ Poly EncorePro 515-M headset - on-ear - wired - USB-A - black In Stock £77.77
H1MJ Poly EncorePro 530 headset - in-ear - wired - Quick Disconnect - black In Stock £68.08
