The HP Pro Mini 400 provides users with the commercial-grade performance, security, and the flexible deployment capabilities needed for small, varied workspaces. This reliable, ultra-small PC is powered to handle mainstream enterprise and SMBs with an Intel processor and protected with always-on security you can trust.
Automatic recovery from firmware attacks
Firmware attacks can completely devastate your PC. Stay protected with HP's self-healing BIOS - HP Sure Start Gen7 automatically recovers the BIOS from malware, rootkits, or corruption. -
Work without interruption
Keep productivity high and downtime low with the fully integrated and automated features of the HP BIOSphere Gen6 firmware ecosystem. Your PCs have extra protection thanks to automatic updates and security checks. -
Browse confidently
Help protect your PC from websites and read only Microsoft Office and PDF attachments with embedded malware, ransomware, or viruses with hardware-enforced security from HP Sure Click. -
Erase your drive
HP Secure Erase removes the contents of a hard drive for repurposing or reassignment. -
Simple PC management
Spend less time and get right to the updates you need with HP Support Assistant. -
Speed up the basics of IT management
The HP Manageability Integration Kit helps speed up image creation and management of hardware, BIOS, and security through Microsoft System Center Configuration Manager.
- HP Pro 400 G9 - mini Core i5 13500T 1.6 GHz - 8 GB - SSD 256 GB - UK
- Personal computer - mini
- Localisation
- Processor
- Intel Core i5 (13th Gen) 13500T / 1.6 GHz (up to 4.6 GHz, (14-core)
- Processor Main Features
- Intel Turbo Boost Technology
- Cache Memory
- 24 MB L3 Cache
- Cache Per Processor
- 24 MB
- RAM
- 8 GB (installed) / 64 GB (max) - DDR4 SDRAM
- Hard Drive
- SSD 256 GB - PCI Express - M.2 2280 - NVM Express (NVMe)
- Optical Storage
- No optical drive
- Graphics Controller
- Intel UHD Graphics 770 Dynamic Video Memory Technology
- Networking
- 1GbE, 802.11a, 802.11b/g/n, Wi-Fi 5, Bluetooth 5.2, Wi-Fi 6E
- Keyboard
- UK
- Power
- (50/60 Hz)
- OS Provided
- Windows 11 Pro
- Software Included
- HP Support Assistant, HP PC Hardware Diagnostics UEFI, HP Secure Erase, HP Client Catalogue (free download), HP Driver Packs, HP Image Assistant (free download), HP Manageability & Integration Kit (free download), HP Notifications, HP Connection Optimizer, HP Sure Click, HP Privacy Settings, HP Sure Sense, HP Sure Admin, HP Client Management Script Library (free download), HP BIOSphere Gen6, Touchpoint Customiser for Commercial, HSA Fusion for Commercial, HSA Telemetry for Commercial, HP Desktop Support Utilities, HP Easy Clean, Absolute Persistence Module, HP Connect for Microsoft Endpoint Manager, HP Patch Assistant (free download), HP PC Hardware Diagnostics Windows, HP Easy Clean Keyboard Driver, HPX for CMIT, HP Sure Start Gen7
- 17.7 cm x 17.5 cm x 3.42 cm
- 1.42 kg
- Manufacturer Selling Program
- HP Smart Buy
- Environmental Standards
- TCO Certified Desktops 9, ENERGY STAR Qualified
- Limited warranty - parts and labour - 1 year - on-site
- Personal computer
- Product Form Factor
- Mini
- Built-in Devices
- Speaker
- Sensors
- HP Tamper Lock
- Embedded Security
- Trusted Platform Module (TPM 2.0) Security Chip
- Localisation
Processor / Chipset
- CPU
- Clock Speed
- 1.6 GHz (P-core) / 1.2 GHz (E-core)
- Max Turbo Speed
- 4.6 GHz (P-core) / 3.2 GHz (E-core)
- Number of Cores
- 14-core
- CPU Qty
- 1
- Max CPU Qty
- 1
- L2 cache
- 11.5 MB
- CPU Upgradability
- Upgradable
- Chipset Type
- Intel Q670
Cache Memory
- Installed Size
- L3 Cache - 24 MB
- 24 MB
RAM
- Installed Size
- Technology
- DDR4 SDRAM
- Effective Memory Speed
- 3200 MHz
- Rated Memory Speed
- 3200 MHz
- Form Factor
- SO-DIMM 260-pin
- Slots
- 2 (Total) / 1 (empty)
- Configuration Features
- 1 x 8 GB
Hard Drive
- SSD - M.2 2280
- Capacity
- 1 x 256 GB
- Interface Type
- PCI Express
Optical Storage
- No optical drive
Monitor
- Monitor Type
- None.
Graphics Controller
- Graphics Processor
- Video Interfaces
- HDMI, DisplayPort
- HDCP Compatible
Audio Output
- High Definition Audio
Input Device
- Mouse, keyboard
Keyboard
- Keyboard Name
- HP 320K
- Interface
- USB
- Localization & Layout
- UK
Mouse
- Mouse Name
- HP 125
- Interface (Bus) Type
- PCI Express Mini Card (M.2)
- Wireless LAN Supported
- Wireless NIC
- Intel Wi-Fi 6E AX 211
- Data Link Protocol
- Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, Bluetooth 5.2, IEEE 802.11ax (Wi-Fi 6E)
- Remote Management Protocol
- SNMP 2
- Wake on LAN (WoL), ACPI support, auto-uplink (auto MDI/MDI-X), PXE 2.1 support, dual stream (2x2)
- IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.11d, IEEE 802.11i, Wi-Fi CERTIFIED, IEEE 802.11h, IEEE 802.11e, IEEE 802.11k, IEEE 802.3az, IEEE 802.11r, IEEE 802.11v
- Bays
- 1 (total) / 1 (free) x internal 2.5"
- Slots
- 1 (total) / 0 (free) x M.2 Card - 2230 (for wireless module) , 1 (total) / 0 (free) x M.2 Card - 2280 (for internal storage)
- 1 x headphones/microphone (1 in front) (CTIA headset support) , 2 x USB 3.2 Gen 2 (2 in front) (one of them is charging) , 1 x USB-C 3.2 Gen 2x2 (1 in front) (charging) , 1 x USB 3.2 Gen 2 , 2 x DisplayPort 1.4a , 1 x HDMI , 2 x USB 3.2 Gen 1 (wake functionality) , 1 x LAN (Gigabit Ethernet)
- Theft/Intrusion Protection
- Security lock slot (cable lock sold separately), chassis intrusion sensor, retractable padlock loop
- Security Slot Type
- Kensington security slot
- FIPS 140-2 Level 2, RoHS, WEEE, Common Criteria EAL4+, low halogen
- HP Smart Buy
- Power adapter
- Power Device Name
- HP Smart AC Adapter
- Voltage Required
- AC 90-264 V (50/60 Hz)
- Power Provided
- 90 Watt
- Efficiency
- 89% (230VAC), 88% (115VAC)
- Power Factor Correction
- Yes (active)
Operating System / Software
- OS Provided
- Windows 11 Pro English
- Software
Sustainability Information
- TCO Certified
- ENERGY STAR Certified
- 17.7 cm
- 17.5 cm
- 3.42 cm
- 1.42 kg
- Shipping Width
- 49.8 cm
- Shipping Depth
- 23.5 cm
- Shipping Height
- 13.2 cm
- Shipping Weight
- 3.4 kg
- 10 °C
- 35 °C
- 10 - 90% RH (non-condensing)
Warranties (4)
HP Care Pack Next Business Day Hardware Support - Extended serv | In Stock | £47.07 |
HP Care Pack Next Business Day Hardware Support with Defective Media Retention - 5 years | In Stock | £105.53 |
HP Care Pack Active Care NBD Hardware Support - extended service agreement - 3 years - on-site | In Stock | £65.90 |
HP Care Pack Next Business Day Active Care Service with Defective Media Retention - 5 years on-site | In Stock | £136.51 |
Accessories (2)
HP B250 Mounting Kit for LCD Display/Thin Client | In Stock | £33.61 |
HP DM V4+ VESA Sleeve | In Stock | £25.22 |
Monitors (10)
HP P22h G5 P-Series LED Monitor Full HD (1080p) 21.5" | In Stock | £148.31 |
HP P22v G5 21.4" 1920x1080 5ms HDMI VGA LED Monitor | In Stock | £131.20 |
HP 724pf Series 7 Pro 23.8" 1920x1080 5ms HDMI DisplayPort IPS LED Monitor | In Stock | £164.32 |
HP 732pk Series 7 Pro 32" 3840x2160 5ms HDMI DisplayPort Thunderbolt 4 IPS LED Monitor | In Stock | £825.46 |
HP E24mv G4 23.8" 1920x1080 5ms VGA HDMI DisplayPort IPS LED Conferencing Monitor | In Stock | £153.30 |
HP 324pv Series 3 Pro 23.8" 1920x1080 5ms VGA HDMI LED Monitor | In Stock | £73.89 |
HP E24m G4 23.8" 1920x1080 5ms HDMI DisplayPort USB-C IPS LED Conferencing Monitor | In Stock | £211.74 |
HP 524pf Series 5 Pro 24" 1920x1080 5ms HDMI DisplayPort IPS LED Monitor | In Stock | £110.29 |
HP E27 G5 27" 1920x1080 5ms HDMI DisplayPort USB IPS LED Monitor | In Stock | £127.93 |
HP 524pm Series 5 Pro 24" 1920x1080 5ms HDMI DisplayPort USB-C IPS LED Conferencing Monitor | In Stock | £242.62 |
Keyboards and Mice (4)
HP 128 Wired Mouse | In Stock | £8.56 |
HP 455 Programmable Keyboard - Wireless - UK | In Stock | £26.46 |
HP 125 - Mouse - wired - USB - black | In Stock | £6.26 |
HP 125 G2 - keyboard - full size - UK - black Input Device | In Stock | £15.88 |
Other bundles (59)
HPE DisplayPort to VGA Adapter | In Stock | £21.98 |
HP Keyed Cable Lock 10mm | In Stock | £26.40 |
HP USB G2 Stereo Headset | In Stock | £20.44 |
Poly Voyager Focus 2 UC-M C USB-A WW | In Stock | £99.99 |
Poly Voyager Surround 80 UC USB-C Headset + USB-C/A Adapter | In Stock | £240.58 |
Poly Voyager Surround 80 UC MS Teams Certified USB-C + USB-C/A | In Stock | £234.68 |
Poly P5 1080P HD Webcam | In Stock | £36.52 |
Poly Savi 8240-M Office Headset | In Stock | £238.74 |
Poly Voyager 4320 UC V4320-M C USB-A WW | In Stock | £124.75 |
Poly Voyager 4320 UC V4320 C USB-C WW | In Stock | £103.93 |
Poly DA85-M Sound Card | In Stock | £53.34 |
Poly Voyager Focus 2 UC-M USB-A with Stand | In Stock | £108.52 |
Poly Blackwire C3225 USB-A Headset | In Stock | £51.43 |
Poly EncorePro HW520 Stereo Headset (Noise Cancelling) | In Stock | £81.71 |
Poly DA85 Headset Cable - USB-C to Quick Disconnect | In Stock | £53.34 |
Poly EncorePro HW510 Mono Headset (N/C) | In Stock | £86.11 |
Poly Voyager 4320 UC V4320-M C USB-A CS WW | In Stock | £108.73 |
Poly Voyager 4320 UC V4320-M C USB-C WW | In Stock | £98.60 |
Poly Voyager 4320 UC V4320 C USB-A CS WW | In Stock | £131.93 |
Poly Voyager 4310 UC V4310-M C USB-A WW | In Stock | £110.75 |
Poly Voyager 4320 UC V4320 C USB-C CS WW | In Stock | £119.34 |
Poly Voyager 4320 UC V4320-M C USB-C CS WW | In Stock | £110.60 |
Poly Voyager 5200 UC B5200 Headset with Case | In Stock | £93.27 |
Poly Voyager 4310 UC V4310-M C USB-A CS WW | In Stock | £121.68 |
Poly Voyager 4320 UC V4320 C USB-A WW | In Stock | £97.00 |
Poly Voyager 4310 UC V4310 C USB-A WW | In Stock | £113.52 |
Poly Voyager 4310 UC V4310 C USB-A CS WW | In Stock | £121.68 |
Poly Sync 10 SY10-M USB-A/C WW | In Stock | £60.31 |
Poly EncorePro 525 USB EP525 USB-A Headset | In Stock | £84.71 |
Poly EncorePro HW510 Mono Headset (VT) | In Stock | £73.73 |
Poly Voyager Focus 2 UC-M USB-C Headset with Stand | In Stock | £141.12 |
Poly Sync 40 SY40-M WW | In Stock | £139.01 |
Poly Voyager Focus 2 UC USB-A Headset with Stand | In Stock | £143.47 |
Poly Blackwire 8225 Stereo Microsoft Teams Certified USB-C | In Stock | £92.95 |
Poly Blackwire 3320 on-ear - wired - USB-C - black - Certified for Microsoft Teams, UC certified | In Stock | £34.67 |
Poly Poly Blackwire 3320 Stereo USB-C/A Adapter | In Stock | £33.49 |
Poly Blackwire 5220 Stereo USB-C Headset + 3.5mm Plug + USB-C | In Stock | £75.19 |
Poly Spare BT700 Bluetooth USB Adapter | In Stock | £58.49 |
Poly Blackwire 3315 headset - on-ear - wired - 3.5 mm jack, USB-C - black - UC certified | In Stock | £49.32 |
Poly Savi 8420 Office headset - on-ear - DECT / Bluetooth - wireless - active noise cancelling | In Stock | £164.89 |
Poly Wireless Headset System Base for Bluetooth headset - for Poly Voyager | In Stock | £91.05 |
HyperX SoloCast USB Microphone | In Stock | £50.29 |
HyperX Pulsefire Core Gaming Mouse | In Stock | £27.07 |
HyperX Pulsefire Mat Gaming Mouse Pad | In Stock | £12.57 |
Poly Savi 8410 Office headset - on-ear - DECT / Bluetooth - wireless - black | In Stock | £239.21 |
Poly Blackwire 5210 Monaural USB-C Headset +3.5mm Plug +USB-C/A Adapter | In Stock | £65.77 |
HP Flex IO V3 Card - serial port | In Stock | £19.61 |
Poly Blackwire 3310 headset - on-ear - wired - USB-A - black | In Stock | £28.00 |
Poly Blackwire 3220 headset - on-ear - wired - USB-C - black | In Stock | £31.11 |
Poly Blackwire 3220 headset - on-ear - wired - USB-C - black | In Stock | £29.33 |
Poly Blackwire 3310 Monaural USB-C Headset + USB-C/A Adapter | In Stock | £28.00 |
Poly EncorePro 515-M headset - on-ear - wired - USB-A - black | In Stock | £75.67 |
Poly EncorePro 530 headset - in-ear - wired - Quick Disconnect - black | In Stock | £81.56 |
Poly EncorePro 530 - headset - Quick Disconnect | In Stock | £81.56 |
Poly Voyager 4310 Mono UC V4310 USB-C Microsoft Teams | In Stock | £121.68 |
Poly EncorePro HW520D - headset - Quick Disconnect | In Stock | £107.03 |
Poly Blackwire 3325 - headset - 3.5 mm jack, USB-C | In Stock | £54.64 |
