HP Pro 3135 Athlon II X2 250 2GB 320GB DVD+/-RW Windows 7 Pro 64-Bit
HP Pro 3135 Microtower-PC
Quicklinx: 7D8LWS00 Mfr#: XT249EA#ABU
  • Athlon II X2
  • ATI Radeon HD 4200
  • Microsoft Windows 7 Professional 64-bit Edition
Performance meets expandability. The HP Pro 3135 Microtower Business PC has proven industry-standard technology with dual core processing powerful enough to handle your everyday demands. Plus options for expansion that's ready to grow when you are.
  • Impressive, intelligent performance
    The latest AMD technology with your choice of AthlonTM or PhenomTM processors designed to support the demand of your graphics rich business applications with ease.
  • Flexibility comes standard
    Your business needs evolve. The HP Pro 3135 is designed to change with you. Available ports, slots, and bays allow you to configure your PC to meet your needs today and expand your capabilities when the time is right.
  • Out-of-the-box productivity
    This PC is ready to go with the AMD processors, ample storage with hard drives up to 750 GB , genuine Windows 7* operating system, and dual monitor support ; a PC equipped to make an impact.
  • Do more with pre-qualified options
    Easily transfer files with a 22-in-1 Media Card Reader or burn labels directly onto discs with a SuperMulti Lightscribe Drive.
  • Give your business a boost
    Enhance your visual experience via graphics cards with DirectX 11 support.
HP Pro 3135 - micro tower Athlon II X2 250 3 GHz - 2 GB - HDD 320 GB
Personal computer - micro tower
AMD Athlon II X2 250 / 3 GHz (Dual-Core)
Cache Memory
2 MB L2 Cache
Cache Per Processor
2 MB
RAM
2 GB (installed) / 16 GB (max) - DDR3 SDRAM
Storage Controller
SATA (SATA 3Gb/s)
Hard Drive
HDD 320 GB - SATA 3Gb/s - 7200 rpm
Optical Storage
DVD SuperMulti with LightScribe Technology
Card Reader
22 in 1
Graphics Controller
ATI Radeon HD 4200 Shared Video Memory (UMA)
Audio Output
Stereo - integrated
10Mb LAN, 100Mb LAN
AC 120/230 V
OS Provided
Microsoft Office Preloaded
Includes a pre-loaded image of select Microsoft Office 2010 suites. Purchase an Office 2010 Product Key Card or disc to activate preloaded software on this PC.
18.5 cm x 41.6 cm x 38.5 cm
7.6 kg
Limited warranty - parts and labour - 1 year - on-site
Personal computer
Recommended Use
Small business, corporate business
Product Form Factor
Micro tower
Processor / Chipset
CPU
Clock Speed
3 GHz
Number of Cores
Dual-Core
64-bit Computing
CPU Qty
1
Max CPU Qty
1
Chipset Type
AMD 785G
Cache Memory
Installed Size
L2 Cache - 2 MB
Cache Per Processor
2 MB
RAM
Installed Size
DDR3 SDRAM
Effective Memory Speed
1333 MHz
DIMM 240-pin
Slots
4 (Total)
Hard Drive
HDD
1 x 320 GB
Interface Type
SATA 3Gb/s
Spindle Speed
7200 rpm
Native Command Queuing (NCQ)
Storage Controller
1 x SATA - integrated
Controller Interface Type
SATA 3Gb/s
Optical Storage
DVD±RW (±R DL) / DVD-RAM DVD SuperMulti - SATA
Read Speed
48x (CD) / 16x (DVD)
Write Speed
48x (CD) / 16x (DVD±R) / 8x (DVD±R DL)
CD / DVD Rewrite Speed
32x (CD) / 6x (DVD-RW) / 8x (DVD+RW) / 12x (DVD-RAM)
Disc Labeling Technology
Card Reader
22 in 1 card reader
Supported Flash Memory Cards
Memory Stick, Memory Stick PRO, Microdrive, MultiMediaCard, SD Memory Card, Memory Stick Duo, xD-Picture Card, Memory Stick PRO Duo, miniSD, RS-MMC, MultiMediaCardmobile, microSD, MultiMediaCardplus, CFast Card type I, CFast Card type II, SDHC Memory Card, miniSDHC, microSDHC, Memory Stick PRO-HG Duo
Monitor
Monitor Type
None.
Graphics Controller
Integrated
Graphics Processor
Video Interfaces
VGA, DVI
Audio Output
Integrated
Sound Output Mode
Stereo
High Definition Audio
Input Device
Mouse, keyboard
Integrated
Ethernet Controller
Realtek RTL8105E
Ethernet, Fast Ethernet
Wake on LAN (WoL)
IEEE 802.2, IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p
Bays
2 (total) / 1 (free) x internal 3.5" x 1/3H , 1 (total) / 0 (free) x external 3.5" x 1/3H , 2 (total) / 1 (free) x external 5.25" x 1/2H
Slots
4 DIMM 240-pin , 3 (total) / 3 (free) x PCIe x1 - full-height , 1 (total) / 1 (free) x PCIe x16 - full-height , 1 (total) / 0 (free) x CPU , 1 (total) / 1 (free) x Mini PCI
8 x USB 2.0 (2 front, 6 rear) , 1 x VGA , 1 x DVI-D , 1 x LAN , 1 x SPDIF output , 1 x audio line-in , 1 x audio line-out , 2 x microphone (1 in front) , 1 x headphones (1 in front)
Theft/Intrusion Protection
Security lock slot (cable lock sold separately), padlock loop
RoHS, WEEE
Power supply
AC 120/230 V
Power Provided
300 Watt
Power Factor Correction
Yes (active)
Operating System / Software
OS Provided
18.5 cm
41.6 cm
38.5 cm
7.6 kg
5 °C
35 °C
10 - 90%
