The HP Pro SFF 290 helps optimize business resources. Equipped with a powerful Intel processor, essential tools, and security features for business, this affordably priced and easy to set up PC has a scalable and functional design that can grow with your business.
Windows 11
Work anywhere without compromising on performance or security with Windows 11 powered by HP's collaboration and connectivity technology. -
13th Gen Intel multi-core processor
Get the perfect combination of power, snappy performance, and value with a 13th gen Intel Core processor to handle multiple work tasks smoothly and reliably with multiple processing cores. -
Simple PC management
Spend less time and get right to the updates you need with HP Support Assistant.
- HP Pro 290 G9 - SFF Core i5 13500 2.5 GHz - 8 GB - SSD 512 GB - UK
- Personal computer - SFF
- Localisation
- Processor
- Intel Core i5 (13th Gen) 13500 / 2.5 GHz (up to 4.8 GHz, (14-core)
- Processor Main Features
- Intel Turbo Boost Technology
- Cache Memory
- 24 MB L3 Cache
- Cache Per Processor
- 24 MB
- RAM
- 8 GB (installed) / 64 GB (max) - DDR4 SDRAM
- Hard Drive
- SSD 512 GB - PCI Express - M.2 - NVM Express (NVMe)
- Optical Storage
- No optical drive
- Graphics Controller
- Intel UHD Graphics 770 Dynamic Video Memory Technology
- Audio Output
- Stereo
- Networking
- 1GbE
- Keyboard
- UK
- OS Provided
- Windows 11 Pro
- Software Included
- HP Support Assistant, McAfee LiveSafe, HP Setup Integrated OOBE, HP Documentation, HP Audio Switch, Xerox DocuShare (30 days trial)
- 9.5 cm x 30.3 cm x 27 cm
- 4.2 kg
- Manufacturer Selling Program
- HP Smart Buy
- Environmental Standards
- ENERGY STAR Qualified
- Limited warranty - parts and labour - 1 year - on-site
- Personal computer
- Product Form Factor
- SFF
- Embedded Security
- Trusted Platform Module (TPM 2.0) Security Chip
- Localisation
Processor / Chipset
- CPU
- Clock Speed
- 2.5 GHz (P-core) / 1.8 GHz (E-core)
- Max Turbo Speed
- 4.8 GHz (P-core) / 3.5 GHz (E-core)
- Number of Cores
- 14-core
- CPU Qty
- 1
- Max CPU Qty
- 1
- L2 cache
- 11.5 MB
- CPU Upgradability
- Upgradable
- Chipset Type
- Intel H670
Cache Memory
- Installed Size
- L3 Cache - 24 MB
- 24 MB
RAM
- Installed Size
- Technology
- DDR4 SDRAM
- Effective Memory Speed
- 3200 MHz
- Rated Memory Speed
- 3200 MHz
- Form Factor
- DIMM 288-pin
- Slots
- 2 (Total) / 1 (empty)
- Configuration Features
- 1 x 8 GB
Hard Drive
- SSD - M.2
- Capacity
- 1 x 512 GB
- Interface Type
- PCI Express
Optical Storage
- No optical drive
Monitor
- Monitor Type
- None.
Graphics Controller
- Graphics Processor
- Video Interfaces
- VGA, HDMI
- HDCP Compatible
Audio Output
- Sound Output Mode
- Stereo
- Max Sampling Rate
- 192 kHz
- High Definition Audio
Input Device
- Mouse, keyboard
Keyboard
- Keyboard Name
- HP 125
- Localization & Layout
- UK
Mouse
- Mouse Name
- HP 125
- Data Link Protocol
- Wake on LAN (WoL), ACPI support, PXE 2.1 support
- Bays
- 1 (total) / 1 (free) x external 5.25" Slim Line , 1 (total) / 1 (free) x internal 3.5"
- Slots
- 1 (total) / 1 (free) x PCIe 4.0 x16 , 1 (total) / 1 (free) x PCIe 3.0 x1 , 1 (total) / 0 (free) x M.2 Card - 2230 (for WLAN) , 1 (total) / 0 (free) x M.2 Card - 2242/2280 (for internal storage)
- 1 x headphones/microphone , 4 x USB 3.2 Gen 1 , 4 x USB 2.0 , 1 x audio line-in , 1 x audio line-out , 1 x HDMI , 1 x VGA , 1 x LAN (Gigabit Ethernet)
- Theft/Intrusion Protection
- Security lock slot (cable lock sold separately), padlock loop, integrated accessories cable lock
- Security Slot Type
- Kensington security slot
- CSA, UL, RoHS, ETS 300 826, WEEE, ETS 300 328, FCC CFR47 Part 15 C, LVD, CECP, SEPA, IEC 950, ErP Lot 3 2013 Ready, Japan PC Green Label, Taiwan Green Mark, Korea Eco-Label
- HP Smart Buy
- Power supply
- Power Provided
- 180 watt
- Efficiency
- 90%
- Power Factor Correction
- Yes (active)
Operating System / Software
- OS Provided
- Windows 11 Pro English
- Software
Sustainability Information
- ENERGY STAR Certified
- 9.5 cm
- 30.3 cm
- 27 cm
- 4.2 kg
- Shipping Width
- 49.8 cm
- Shipping Depth
- 19.6 cm
- Shipping Height
- 34.6 cm
- Shipping Weight
- 6 kg
- 0 °C
- 40 °C
- 10 - 90% RH (non-condensing)
Warranties (2)
HP Care Pack Next Business Day Hardware Support - Extended serv | In Stock | £35.99 |
HP Care Pack Active Care NBD Hardware Support - extended service agreement - 3 years - on-site | In Stock | £53.71 |
Monitors (8)
HP 724pf Series 7 Pro 23.8" 1920x1080 5ms HDMI DisplayPort IPS LED Monitor | In Stock | £164.32 |
HP P34hc G4 P-Series 34" 3440x1440 5ms HDMI DisplayPort USB-C LED Curved Monitor | In Stock | £491.31 |
HP 732pk Series 7 Pro 32" 3840x2160 5ms HDMI DisplayPort Thunderbolt 4 IPS LED Monitor | In Stock | £608.77 |
HP E24mv G4 23.8" 1920x1080 5ms VGA HDMI DisplayPort IPS LED Conferencing Monitor | In Stock | £165.42 |
HP 324pv Series 3 Pro 23.8" 1920x1080 5ms VGA HDMI LED Monitor | In Stock | £77.18 |
HP 524pf Series 5 Pro 24" 1920x1080 5ms HDMI DisplayPort IPS LED Monitor | In Stock | £115.80 |
HP 324ph Series 3 Pro 24" 1920x1080 5ms VGA HDMI DisplayPort IPS LED Monitor | In Stock | £82.71 |
HP 524pm Series 5 Pro 24" 1920x1080 5ms HDMI DisplayPort USB-C IPS LED Conferencing Monitor | In Stock | £266.13 |
Other bundles (54)
HP 325 Webcam | In Stock | £18.87 |
Poly Voyager Surround 80 UC USB-C Headset + USB-C/A Adapter | In Stock | £208.06 |
Poly Voyager Surround 80 UC MS Teams Certified USB-C + USB-C/A | In Stock | £208.06 |
Poly DA75 Sound Card | In Stock | £26.51 |
Poly Voyager 4320 UC V4320-M C USB-A WW | In Stock | £108.17 |
Poly Voyager 4320 UC V4320 C USB-C WW | In Stock | £106.60 |
Poly DA85-M Sound Card | In Stock | £44.59 |
Poly EncorePro HW520 Stereo Headset (Noise Cancelling) | In Stock | £65.27 |
Poly DA85 Headset Cable - USB-C to Quick Disconnect | In Stock | £43.34 |
Poly Voyager 4320 UC V4320-M C USB-A CS WW | In Stock | £108.73 |
Poly Voyager 4320 UC V4320-M C USB-C WW | In Stock | £110.85 |
Poly Voyager 4320 UC V4320 C USB-A CS WW | In Stock | £117.00 |
Poly Savi 7320 Office S7320 Stereo Headset | In Stock | £242.98 |
Poly Voyager 4310 UC V4310-M C USB-A WW | In Stock | £98.17 |
Poly Voyager 4320 UC V4320-M C USB-C CS WW | In Stock | £115.93 |
Poly Voyager 4310 UC V4310-M C USB-A CS WW | In Stock | £108.17 |
Poly Voyager 4320 UC V4320 C USB-A WW | In Stock | £106.60 |
Poly Voyager 4310 UC V4310 C USB-A WW | In Stock | £98.17 |
Poly Voyager 4310 UC V4310 C USB-A CS WW | In Stock | £111.00 |
Poly EncorePro HW710 Mono Headset (Noise Cancelling) | In Stock | £105.12 |
Poly Sync 10 SY10-M USB-A/C WW | In Stock | £53.41 |
Poly EncorePro 525 USB EP525 USB-A Headset | In Stock | £87.21 |
Poly Voyager Focus 2 UC-M USB-C Headset with Stand | In Stock | £141.12 |
Poly Sync 40 SY40-M WW | In Stock | £123.47 |
Poly Blackwire 8225 Stereo Microsoft Teams Certified USB-C | In Stock | £109.27 |
Poly Blackwire 3320 on-ear - wired - USB-C - black - Certified for Microsoft Teams, UC certified | In Stock | £32.44 |
Poly Poly Blackwire 3320 Stereo USB-C/A Adapter | In Stock | £35.37 |
Poly Blackwire 5220 Stereo USB-C Headset + 3.5mm Plug + USB-C | In Stock | £67.04 |
Poly Savi 8220 headset - on-ear - DECT / Bluetooth - wireless - USB-A via Bluetooth adapter - black | In Stock | £131.51 |
Poly Blackwire 3315 headset - on-ear - wired - 3.5 mm jack, USB-C - black - UC certified | In Stock | £45.04 |
Poly Savi 8420 Office headset - on-ear - DECT / Bluetooth - wireless - active noise cancelling | In Stock | £164.89 |
Poly Wireless Headset System Base for Bluetooth headset - for Poly Voyager | In Stock | £89.69 |
HyperX Pulsefire Core Gaming Mouse | In Stock | £27.43 |
HyperX Wrist Rest | In Stock | £20.11 |
Poly Savi 8410 Office headset - on-ear - DECT / Bluetooth - wireless - black | In Stock | £190.01 |
Poly Blackwire 3210 headset - on-ear - wired - USB-C - black | In Stock | £25.87 |
Poly Blackwire 5210 Monaural USB-C Headset +3.5mm Plug +USB-C/A Adapter | In Stock | £61.00 |
Poly Blackwire 3310 headset - on-ear - wired - USB-A - black | In Stock | £25.49 |
Poly Blackwire 3220 headset - on-ear - wired - USB-C - black | In Stock | £25.93 |
Poly Blackwire 3220 headset - on-ear - wired - USB-C - black | In Stock | £25.27 |
Poly Blackwire 3310 Monaural USB-C Headset + USB-C/A Adapter | In Stock | £24.80 |
Poly EncorePro 515-M headset - on-ear - wired - USB-A - black | In Stock | £77.77 |
Poly Voyager 4310 Mono UC V4310 USB-C Microsoft Teams | In Stock | £108.17 |
Poly EncorePro HW520D - headset - Quick Disconnect | In Stock | £105.92 |
Poly HP Poly Blackwire 3325 - headset - 3.5 mm jack, USB-C | In Stock | £48.40 |
Poly HP Poly Blackwire 3325 - headset - 3.5 mm jack, USB-C | In Stock | £48.57 |
Poly Voyager Focus 2 - headset - USB-C via Bluetooth adapter | In Stock | £144.75 |
Poly Blackwire 3215 - headset - 3.5 mm jack, USB-C | In Stock | £46.27 |
Poly Blackwire 5210 - headset - 3.5 mm jack, USB-C | In Stock | £61.00 |
Poly Blackwire 3220 USB-C HS +USB-C/A Headset | In Stock | £26.96 |
Poly Blackwire 5220 USB-C HS +USB-C/A Headset | In Stock | £63.33 |
Poly Poly Voyager Focus 2 - Headset - On-Ear | In Stock | £136.41 |
