Get maximum productivity from your HP Pro Slate 10 EE G1 or HP Pro Tablet 10 EE G1with the HP Pro 10 EE G1 Keyboard Base, a hardwired keyboard with a touchpad for quick and easy data entry and navigation.
Easy to use
Simply set your tablet (in horizontal orientation) into the base and align with the integrated posts. To remove from the base, pull the tablet upward-no sliders or release required. -
Tablet powered
Get right to work with a keyboard that's powered by the connected tablet. -
Help ensure privacy
Avoid wireless interference and help protect your work in class, in the office, and during testing with a hardwired keyboard connection. -
World-class support
Rest easy with a one-year limited warranty.
- HP - keyboard - QWERTY - UK
- Keyboard
- Interface
- Dock
- Localization and Layout
- QWERTY UK
- Integrated touchpad
- 29.2 cm x 21.9 cm x 1.897 cm
- 650 g
- 1-year warranty
- Designed For
- Pro Slate 10 EE G1; Pro Tablet 10 EE G1
- Keyboard
- Interface
- Dock
Input Device
- QWERTY UK
- Region
- United Kingdom
- 29.2 cm
- 21.9 cm
- 1.897 cm
- 650 g
- Limited warranty - 1 year
- Designed For
- HP Pro Slate 10 EE G1 , HP Pro Tablet 10 EE G1
