Run presentations and guide onscreen content with a virtual laser from the palm of your hand, anywhere in the room, or navigate your PC's applications at your desk, with the sophisticated HP Elite Presenter Mouse. It's an ultra-modern, multi-functional accessory that's a pointer and mouse in one.
Work the room
Control and point to presentations from the front or back of the room-without rushing to your PC to change slides-or seated alongside your colleagues, with a wireless range up to 30 ft (10 m) from your Bluetooth -paired PC. -
Make your point
Use the real-time virtual laser pointer to highlight Adobe PDF or PowerPoint content onscreen in a conference room and on remote viewer screens when you share your presentation through your collaboration application. -
Give your mouse a style upgrade
Turn the mouse and turn heads. Get complete functionality without compromising elegance with a sleek metal-accented device that converts from a flat pointer with basic mouse functions to a comfortable, full-featured mouse with one quick flip. -
Travel light and in style
Pop the super-compact presenter into its pouch and your device's bag so it's ready to go anytime you present. Never worry about changing batteries with a design that's rechargeable through a micro USB port and goes to standby when not in use. -
Built by HP
Trust your investment in the latest technology with a device that's designed and tested for HP quality and reliability and to complement your HP PCs and mobile devices.
- HP Elite Presenter Mouse presentation remote control
- Presentation remote control
- 4.4 cm x 12.5 cm x 1.38 cm
- 70 g
- Connectivity Technology
- Radio
- Supported Devices
- PC multimedia
- Wireless Technology
- Bluetooth 4.0 LE
- Max Operating Distance
- 9.4 m
- Battery
- Rechargeable
- 4.4 cm
- 12.5 cm
- 1.38 cm
- 70 g
- Radio
- Bluetooth 4.0 LE
- Supported Devices
- PC multimedia
- 9.4 m
- Built-in laser pointer, mouse emulation, power on/off, scrolling, 1200 DPI
- Connector Type
- 1 x USB
- UL, VCCI, BSMI, GS, NOM, IC, MIC, MOC, FCC, ANATEL, UkrSEPRO, WPC, KC, SRRC, EAC, CITC, RATEL, NCC, RCM, ICASA, TRA, Subtel, NTC, SIRIM, CNC, SDPPI, IMDA
- Battery
- Rechargeable
- Run Time (Up To)
- 2 months
- Recharge Time
- 2 hours
