Create a sleek, professional, clutter-free workspace and give yourself room to move around with the HP Wireless Premium Mouse, which integrates seamlessly with your HP notebook.
Enhance your productivity
Easily navigate documents and web pages with the accurate, high-performance laser and hyper-fast scrolling. -
Built-in comfort
Be comfortable with a soft-touch mouse that naturally fits your left or right hand and resists fingerprints. -
Smart, efficient battery
Work without worry with a fast-charging battery that can be conveniently recharged with the included USB cable while you use the mouse. Intelligent standby mode saves battery life and a handy LED indicator alerts you when the battery is low. -
Wireless connectivity
Expand your work area with a mouse that works up to 30 ft (10 m) away from your PC through a USB nano-receiver. 2.4 GHz HP Link-5 technology conserves your PC's USB ports by pairing with and connecting to up to five HP Link-5 compatible devices. -
Rest easy
Get the reassurance of a one-year limited warranty.
- HP Premium - mouse - 2.4 GHz - black
- Mouse
- Connectivity Technology
- Wireless - 2.4 GHz
- Black
- Orientation
- Right and left-handed
- 6.7 cm x 10.7 cm x 3.86 cm
- 115 g
- Wireless Receiver
- USB wireless receiver
- Movement Detection Technology
- Laser
- Buttons Qty
- 3
- Movement Resolution
- 1600 dpi
- Soft-touch surface
- OS Required
- Microsoft Windows 7, Windows 10, Windows 8.x
- Mouse
- Wireless Receiver
- Orientation
- 6.7 cm
- 10.7 cm
- 3.86 cm
- 115 g
- Black
Input Device
- Wireless
- Interface
- 2.4 GHz
- Laser
- Buttons Qty
- 3
- 1600 dpi
- 1 x USB
- CSA, UL, TUV GS, VCCI, BSMI, EN55022, SABS, SASO, EN55024, MIC, MOC, FCC, NTRA, ANATEL, UkrSEPRO, WPC, SRRC, CITC, NCC, iDA, BIS, ICASA, TRA, Subtel, CU-EAC, ACMA, EN 301 489-1-17, SIRIM, CONATEL, SDPPI, NRCS
- Technology
- Lithium Ion
- Capacity
- 400 mAh
- Run Time (Up To)
- 3 months
- OS Required
