Combining concentrated 1U compute power, HP Insight Control, and essential fault tolerance, the HP ProLiant DL360 G7 is optimized for space constrained installations. Latest Intel Xeon 5600 Series Processors (6 and 4 core), with choice of DDR3 Registered or Unbuffered DIMMs, integrated Smart Array with support up to eight SAS/SATA/SSD drives and dual PCI Express Gen2 technology provide a high performance system, ideal for the full range of scale out applications.
More Performance, Capacity and Efficiency in Less Space
With the addition of two Intel Xeon Processors X5687, X5690 via CTO, the DL360 G7 offers a new level of high performance, power efficiency, and adaptability with Intel QuickPath, Integrated Memory Controller, Turbo Boost, Intelligent Power Technologies and Trusted Execution Technology.Up to 384 GB Registered Memory DIMMS (up to 48 GB Unbuffered). Memory intensive applications benefit from memory buffers, faster memory speeds, 4:1 memory interleaving, online spares and larger memory capacity.The DL360 G7 continues to provide the best in efficiency with Data Center Smart Grid Technologies like the Sea of Sensors, Dynamic Power Capping and High Efficiency/Right-Sized power supplies.More performance/efficiency in the 1U space and more performance in the constrained environment. -
Smart, Flexible Systems Ready for Complex, Dynamic Environments
Insight Control - essential infrastructure management that speeds server deployment, proactively manages health, optimizes power management, and offers control from anywhere – available standard on Performance models.iLO 3 allows powerful, hardware-based remote administration and control from a standard web browser to conserve valuable IT staff resources.Server configuration and deployment is simplified with tools like SmartStart, Rapid Deployment Pack, PXE, and ROM-Based Setup Utility (RBSU).Options for integrated VMware, MS HyperV or Citrix XenServer virtualization technologies, through internal USB and SD slot.System Insight Display: A rugged slide-out system diagnostics display saves administrators time with easy to find trouble shooting information at the front of the server. -
Energy Efficiency Leadership
HPE unique Data Center Smart Grid Technologies provide intelligent automatic power and cooling with "Sea of Sensors" that manage and adjust power and cooling throughout the server to provide continuous peak performance and efficient cooling throughout the data center.Right-sized HPE ProLiant power supplies deliver 460 Watts at 92% or 94% efficiency, 750 Watts at 92% or 94% efficiency, to 1200 Watts at 90% efficiency. Be sure to use the HPE Power Advisor program for selecting the power supply that best meets your needs.Reduce, Reclaim, Recover. Improve your capacity up to 3X with HPE Dynamic Power Capping and Insight Control. Dynamic Power Capping allows you to cap the servers power use level, without impacting performance and still fully protecting the system Circuit Breakers.Delivering Common Slot/Right-Sized Gold and Platinum power supplies for your needs with the highest efficiency in the industry, as seen by meeting Climate Savers Computing Gold, 80PLUS Gold and Platinum, and setting the standards for Energy Star for Servers compliance. -
Simplified Server Management
Clean, tool-free, mechanical design enhances reliability and simplifies configuration and maintenance with tool-free, modular components, hot plug redundancy features for fast maintenance, and minimal cables for easy access to components.With universal tool-free sliding rails the DL360 G7 is quick to install and quick release levers allow for fast server access. An ambidextrous cable management arm option provides cabling flexibility and management for quick access to the server.The focus on Server Commonality increases IT productivity and manageability with universal drives, Smart Array Controllers, and common power supplies and components to simplify spare parts inventories.ROM based configuration and management features increase uptime and simplify configuration and independent health monitoring.
- HPE ProLiant DL360 G7 Base - rack-mountable Xeon E5649 2.53 GHz - 6 GB - no HDD
- Server - rack-mountable - administrator password, power-on password, keyboard password, serial port I/O control, quick lock
- Height (Rack Units)
- 1U
- Localisation
- Region: Europe
- Server Scalability
- 2-way
- Processor
- 1 x Intel Xeon E5649 / 2.53 GHz (up to 2.93 GHz, (6-core)
- Processor Socket
- LGA1366 Socket
- Processor Main Features
- Hyper-Threading Technology, Intel Turbo Boost Technology, Intel Smart Cache
- Cache Memory
- 12 MB L3 Cache
- Cache Per Processor
- 12 MB
- RAM
- 6 GB (installed) / 384 GB (max) - DDR3 SDRAM - Advanced ECC - PC3-10600
- Storage Controller
- RAID (SATA 3Gb/s / SAS 6Gb/s) - PCIe x8 (Smart Array P410i)
- Server Storage Bays
- Hot-swap 2.5"
- Hard Drive
- No HDD
- Graphics Controller
- ATI ES1000
- Video Memory
- 32 MB
- Networking
- 1GbE
- Power
- AC 120/230 V (50/60 Hz)
- Power Redundancy
- Optional
- 42.6 cm x 69.2 cm x 4.3 cm
- 14.5 kg
- Limited warranty - parts and labour - 3 years - on-site
- Server
- Recommended Use
- Small business, corporate business
- Product Form Factor
- Rack-mountable - 1U
- 2-way
- Front Accessible Bays Qty
- 1
- Hot-Swap Bays Qty
- 4
- Localisation
- Region: Europe
Processor / Chipset
- CPU
- Intel Xeon E5649
- Clock Speed
- 2.53 GHz
- Max Turbo Speed
- 2.93 GHz
- Number of Cores
- 6-core
- 64-bit Computing
- CPU Qty
- 1
- Max CPU Qty
- 2
- CPU Upgradability
- Upgradable
- CPU Socket
- LGA1366 Socket
- Chipset Type
- Intel 5520
Cache Memory
- Installed Size
- L3 Cache - 12 MB
- 12 MB
RAM
- Installed Size
- Technology
- Effective Memory Speed
- 1333 MHz
- Rated Memory Speed
- 1333 MHz
- Memory Specification Compliance
- PC3-10600
- Form Factor
- DIMM 240-pin
- Slots
- 18 (Total) / 15 (empty)
- Registered
- Configuration Features
- 3 x 2 GB
- RAM Supported
- 384 GB registered - Advanced ECC , 48 GB unbuffered - Advanced ECC
Hard Drive
- No HDD
Storage Controller
- 1 x RAID - plug-in card - PCIe x8
- Controller Interface Type
- SATA 3Gb/s / SAS 6Gb/s
- Storage Controller Name
- Smart Array P410i
- RAID Level
- RAID 0, RAID 1, RAID 5, RAID 10, RAID 50
- Buffer Size
- 256 MB
Monitor
- Monitor Type
- None.
Graphics Controller
- Integrated
- Graphics Processor
- ATI ES1000
- Video Memory
- 32 MB
- Video Interfaces
- VGA
- Integrated
- Interface (Bus) Type
- PCI Express x4
- Ethernet Ports
- 4 x Gigabit Ethernet
- Ethernet Controller
- 2 x HP NC382i
- Data Link Protocol
- Remote Management Controller
- Integrated Lights-Out 3
- Wake on LAN (WoL), ACPI support, PXE support
- IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3ad (LACP)
- Bays
- 4 (total) / 4 (free) x hot-swap 2.5" SFF , 1 (total) / 1 (free) x external 5.25" Slim Line
- Slots
- 1 (total) / 1 (free) x PCIe 2.0 x16 - full-length, full-height , 1 (total) / 0 (free) x PCIe 2.0 x8 - low-profile
- 1 x serial , 2 x VGA (1 front, 1 rear) , 3 x USB (1 front, 2 rear) , 4 x LAN (Gigabit Ethernet) , 1 x HPE iLO
- Administrator password, power-on password, keyboard password, serial port I/O control, quick lock
- ACPI 2.0b, FCC Class A certified, EN 61000-3-2, EN55022, ICES-003, EN 61000-3-3, EN55024, CISPR 22, FCC CFR47 Part 15, IEC 60950-1, EN 60950-1, BSMI CNS 13438
- Power supply - hot-plug
- Power Redundancy
- Optional
- Power Redundancy Scheme
- 1+1 (with optional power supply)
- Installed Qty
- 1
- Max Supported Qty
- 2
- Voltage Required
- Power Provided
- 460 Watt
Operating System / Software
- OS Certified
- SUSE Linux Enterprise Server, Microsoft Windows Server, Red Hat Enterprise Linux, Oracle Enterprise Linux
- 42.6 cm
- 69.2 cm
- 4.3 cm
- 14.5 kg
- 10 °C
- 35 °C
- 10 - 90%
