Wireless all-in-one for photo or everyday printing
Print Speed1: Up to 29 ppm black, up to 23 ppm color and color photos as fast as 29 sec
Scan: Up to 1200 x 2400 dpi; Scan Type: Flatbed scanner
Copy: Up to 1200 x 1200 dpi resolution; Maximum Number of Copies: Up to 30 copies
Paper Handling: 80-sheet input tray, 15-sheet photo tray
Connectivity: 1 USB 2.0, Wireless 802.11g
Monthly Volume (duty cycle): Up to 1,000 pages
Features: 1.45" LCD (color graphics) with HP TouchSmart frame, borderless printing up to 8.5 x 11 in
Easy wireless printing from a leader--HP
- Easiest wireless set-up--simply touch one button4.
- More people have chosen HP wireless printers over other leading brands--HP knows wireless printing.
- Enjoy the freedom of printing from virtually anywhere in your home, while sharing the printer with other Wi-Fi-enabled PCs5.
Photo and everyday printing made easy
- Save time, avoid printing errors and get consistent results drag and drop photos to HP Photo Print Gadget2.
- Get great results for Web prints with HP Smart Web
Printing--simply clip and print only the content you want3.
- Easily print, copy, scan and get lab-quality photos all from one compact machine.
- Edit, store and print photos, and make cards, calendars and more with your PC and Windows Live Photo Gallery.
Enjoy the simplicity of the HP TouchSmart frame
- Easily view and print photos without a PC using the color display with HP TouchSmart frame.
- Copy or scan documents and photos easily using the color display with HP TouchSmart frame and simple menus.
- Quickly and easily make lab-quality photo reprints with consistently accurate color reproduction--all without a PC.
Helping conserve resources has never been easier
- Save money and energy with this efficient ENERGY STAR® qualified all-in-one.
- Use paper more efficiently by printing multiple pages onto each side of the paper using the Paper-saving Printing option.
- Save ink and paper by combining content from multiple Web pages onto one page with HP Smart Web Printing3.
- Enjoy free, easy recycling--ink cartridges returned via HP Planet
Eco-highlights
Uses less than one watt of energy while in off mode.
Prints great on 100% recycled paper.
Original HP 60 cartridge bodies contain at least 50% recycled plastic.
1.After first page; see www.hp.com/go/inkjetprinter for details. Print speed may vary depending on the type of output.
2. Requires Windows Vista®.
3. For Windows only. Requires Internet Explorer 6.0 or Mozilla Firefox 2.0 or higher.
4. Requires a WPS router with an integrated push-button. Wireless performance depends on physical environment and distance from access point.
5. Wireless performance is dependent upon physical environment and distance from access point.
Go wireless and enjoy the freedom to print from virtually anywhere in the home
Give yourself the freedom to print from virtually anywhere in the home with this versatile wireless all-in-one. Simply touch one button to connect to your wireless network and share fast, reliable printing between multiple notebooks or PCs. -
Get great results with web pages, documents, photos and more using easy HP tools
Use the colour display with HP TouchSmart frame to print photos, make quick colour copies or scan everyday documents and photos. Get more done with easy, intuitive tools for drag-and-drop photo printing and efficient web page printing. -
Control costs – and save energy – with affordable, efficient printing
Control costs with affordable, efficient printing. Get up to 3x more black/2.5x more colour printed pages with optional XL ink cartridges. Reduce your environmental impact – and save energy costs too – with this ENERGY STAR qualified all-in-one.
- HP Photosmart C4780 All-in-One - multifunction printer - colour
- Multifunction printer
- Printing Technology
- Ink-jet (colour)
- Inkjet Technology
- HP Thermal Inkjet
- Monthly Duty Cycle (max)
- 1000 impressions
- Max Copying Speed
- Up to 9 ppm (mono) / up to 6.5 ppm (colour)
- Max Copying Resolution
- Up to 1200 x 1200 dpi (mono) / up to 1200 x 1200 dpi (colour)
- Max Printing Speed
- Up to 29 ppm (mono) / up to 23 ppm (colour)
- Max Printing Resolution
- Up to 4800 x 1200 dpi (mono) / up to 4800 x 1200 dpi (colour)
- Scanning
- 1200 x 2400 dpi
- Display
- 1.5"
- Original Size
- 216 x 297 mm (max)
- Original Type
- Sheets
- Media Size
- 77 x 127 mm (min) - ANSI A (Letter) (216 x 279 mm), A4 (210 x 297 mm) (max)
- Media Type
- Transparencies, envelopes, plain paper, cards, labels, photo paper
- Standard Media Capacity
- 80 sheets
- Output Trays Capacity
- 80 sheets
- Connection Availability
- Interface
- USB 2.0, Wi-Fi
- Office Machine Features
- Print from memory card
- Power
- AC 110/230 V (50/60Hz)
- 44.2 cm x 42.1 cm x 16.9 cm
- 4.8 kg
- Microsoft Certification
- Works with Windows Vista
- Environmental Standards
- ENERGY STAR Qualified
- 1-year warranty
- Ink-jet - colour
- 1000 impressions
- Display Diagonal Size
- 1.5"
- Interface
- USB 2.0, Wi-Fi
- Standard Memory
- 64 MB 64 MB
- Max Supported Memory
- 64 MB 64 MB
- Supported Flash Memory
- Memory Stick, SD Memory Card, MultiMediaCard, xD-Picture Card, Memory Stick Duo, SDHC Memory Card
Copying
- Max Copying Speed
- Maximum Copies
- 30
Printing
- Inkjet Technology
- HP Thermal Inkjet
- Printer Drivers / Emulations
- PCL 3
Scanning
- Scan Element
- CIS
- Optical Resolution
- 1200 x 2400 dpi
- Grayscale Depth
- 8-bit
- Colour Depth
- 48-bit
Document & Media Handling
- Max Original Size
- 216 x 297 mm
- Original Type
- Sheets
- Min Media Size
- 77 x 127 mm
- Max Media Size
- Other
- Min Media Weight
- 75 g/m²
- Max Media Weight
- 280 g/m²
- Supported Media Type
- 80 sheets
- 80 sheets
- Input tray - 80 sheets , Output tray - 80 sheets
- Speed Details
- Copying: up to 9 ppm (A4) - B/W , Copying: up to 6.5 ppm (A4) - colour , Printing: up to 29 ppm (A4) - B/W draft , Printing: up to 23 ppm (A4) - colour draft , Printing: up to 9 ppm (A4) - B/W normal , Printing: up to 6.5 ppm - colour normal , Printing: up to 5.5 ppm (A4) - B/W best , Printing: up to 2.5 ppm (A4) - colour best , Printing: 29 sec (10 x 15 cm (4"x6")) - photo draft , Printing: 59 sec (10 x 15 cm (4"x6")) - photo normal , Printing: 71 sec (10 x 15 cm (4"x6")) - photo best
- 1 x USB 2.0
- Operating System Support
- MS Windows XP, Apple Mac OS X 10.4, Apple Mac OS X 10.5, MS Windows Vista, MS Windows Vista (64-bit versions)
- Voltage Required
- 20 Watt
- Power Consumption Standby
- 4.8 Watt
- Power Consumption Sleep
- 2.6 Watt
- Software and devices that carry the Works with Windows Vista logo have been tested for baseline compatibility with PC's running.
- ENERGY STAR Certified
- Limited warranty - parts and labour - 1 year
- 44.2 cm
- 42.1 cm
- 16.9 cm
- 4.8 kg
- Sound Emission
- 57 dBA (operating)
HP Everyday Semi-Gloss Photo Paper-100 sheet/A4/210 x 297 mm | In Stock | £16.36 |
