HP Photosmart 7510 e-All-in-One - multifunction ( printer / copier / scanner ) ( colour )
Quicklinx: 7XZBWS00 Mfr#: CQ877B#BEV
Make the most of your time, wherever you are, with this web-connected e-all-in-one. Print lab-quality photos, copy, scan and fax via the large touchscreen, connect wirelessly or print on the go with a host of mobile printing solutions..
  • Bring the versatility of lab-quality photo printing and touchscreen control into your home
    Produce beautiful, lab-quality photos, reprints and other photo projects with five individual HP inks.Take control using the intuitive, large colour touchscreen – complete with gesturing.Send faxes without a phone line using eFax ; fax unattended – copy and scan multipage documents too – using the automatic document feeder.Do more directly from your e-all-in-one – print photos, make copies and send faxes, all without your PC.
  • Do it all and do it easily – print everything from photos to two-sided documents
    Switch between everyday and photo paper or other media using the auto-engaging photo paper tray.Connect to online photo libraries without a PC or print direct from memory card.Save time and consume up to 50% less paper by printing on both sides with automatic two-sided printing.Print everyday projects easily and affordably – documents, web pages, email, work/school projects and more.
HP Photosmart 7510 e-All-in-One C311a - multifunction printer - colour
Multifunction printer
Copier Type
Digital
Printing Technology
Ink-jet (colour)
Inkjet Technology
HP Thermal Inkjet
Monthly Duty Cycle (max)
1250 impressions
Max Copying Resolution
Up to 600 dpi (mono) / up to 600 dpi (colour)
Max Printing Resolution
Up to 600 dpi (mono) / up to 9600 x 2400 dpi (colour)
Scanning
1200 x 2400 dpi
Original Size
216 x 355 mm (max)
Document Feeder Capacity
25 sheets
Media Size
76 x 127 mm (min) - 216 x 762 mm (max)
Media Type
Transparencies, envelopes, plain paper, cards, labels, photo paper
Standard Media Capacity
125 sheets
Output Trays Capacity
50 sheets
Automatic Duplexing
Yes (printing)
Connection Availability
USB 2.0, Wi-Fi(n)
AirPrint Enabled
Office Machine Features
eFax
AC 110/230 V (50/60Hz)
45.5 cm x 45 cm x 22 cm
8.4 kg
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified
Copier Type
Digital
Printing Technology
Ink-jet - colour - photo
1250 impressions
Display Features
Touch screen
USB 2.0, Wi-Fi(n)
AirPrint Enabled
eFax
Standard Memory
64 MB 64 MB
Supported Flash Memory
SD Memory Card, MultiMediaCard, Memory Stick Duo
Copying
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
99
Printing
Inkjet Technology
HP Thermal Inkjet
Printer Drivers / Emulations
PCL 3 GUI
Automatic Duplexing
Scanning
Optical Resolution
1200 x 2400 dpi
Interpolated Resolution
19200 dpi
Colour Depth
48-bit
Document & Media Handling
Max Original Size
216 x 355 mm
25 sheets
Min Media Size
76 x 127 mm
Max Media Size
A4/Legal
Min Media Weight
75 g/m²
Max Media Weight
300 g/m²
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), 216 x 762 mm, 100 x 150 mm, 130 x 180 mm, C6 (114 x 162 mm), 100 x 300 mm, 110 x 220 mm
Borderless Photo Sizes
125 sheets
50 sheets
Input tray - 125 sheets weight: 75 g/m² - 300 g/m² , Output tray - 50 sheets , ADF - 25 sheets - Legal (216 x 356 mm) , Input tray - 20 sheets - 130 x 180 mm - 300 g/m²
Speed Details
Printing: up to 13.5 ppm - B/W best , Printing: up to 9 ppm - colour best , Copying: up to 8 ppm - B/W best , Copying: up to 7.5 ppm - colour best
1 x USB 2.0
Operating System Support
Apple Mac OS X 10.5, MS Windows 7, MS Windows Vista, MS Windows XP SP2, Apple Mac OS X 10.6, Apple Mac OS X 10.7
Software Included
HP Photo Creations
49 Watt
Power Consumption Standby
8 Watt
Power Consumption Sleep
4.5 Watt
Consumables Included
1 x ink cartridge (black) - HP 364 , 1 x ink cartridge (cyan) - HP 364 , 1 x ink cartridge (magenta) - HP 364 , 1 x ink cartridge (yellow) - HP 364 , 1 x ink cartridge (photo) - HP 364
ENERGY STAR Certified
45.5 cm
45 cm
22 cm
8.4 kg
Sound Emission
50 dBA (operating)
15 °C
35 °C
7XZB HP Everyday Semi-Gloss Photo Paper-100 sheet/A4/210 x 297 mm In Stock £16.41
