HP Photosmart 5510 e-All-in-One - multifunction ( printer / copier / scanner ) ( colour )
TiskÁrna HP Photosmart 5510 e-All-in-One
Quicklinx: 7KTYWS00 Mfr#: CQ176B#BEV
Print lab-quality photos, everyday documents and web content with this easy-to-use, touchscreen HP e-all-in-one. Enjoy the freedom to print however you choose - via your wireless network or with HP ePrint mobile printing.[1],[2]
Get easy mobile and wireless printing with HP ePrint and HP Auto Wireless Connect.[1],[2],[3]
Enjoy easy printing and sharing - connect to your wireless network with HP Auto Wireless Connect.[1],[3]
Discover the freedom of HP ePrint mobile printing - now you can print from virtually anywhere.[2]
Print e-mails, photos, web pages and more direct from your iPad®, iPhone® or iPod touch® with AirPrint™.[4]
Print wirelessly direct from a smartphone using HP mobile printing applications.[5]
Print web content without a PC[6] using the 6.0 cm colour touchscreen and a selection of apps.
Use the intuitive, easy-to-use colour touchscreen to print, copy and scan - even print web content - without a PC.[6]
Access easy-to-use apps and print Sudoku puzzles, colouring pages and more.[6]
Choose HP Quick Forms and print templates such as calendars, games and notebook pages.[6]
Enjoy fingertip control - print photos and documents, make copies and scan photos, all via the colour touchscreen.
Get great print quality with affordable individual HP inks.
Print using affordable, individually-replaceable ink cartridges; optional XL cartridges for frequent printing.[7]
Sleek and stylish space-saving design - fits on shelves or bookcases.
Print lab-quality borderless photos - perfect for framing, albums or to share as gifts.
Choose Original HP print cartridges for high quality, reliable printing and copying.
[1] Wireless performance is dependent upon physical environment and distance from access point. Wireless operations compatible with 2.4GHz routers only.
[2] Requires an Internet connection to the printer. Feature works with any connected Internet- and e-mail-capable device. Print times may vary. For a list of supported documents and image types, see www.hp.com/go/eprintcenter.
[3] HP Auto Wireless Connect may not be available for all system configurations. For information on compatibility, visit hp.com/go/autowirelessconnect.
[4] Supports iOS 4.2 and later devices (iPad®, iPhone® 4, iPhone® 3GS, and 3rd and 4th generation iPod touch®) that support multitasking. AirPrint™ and iOS 4.2 and later devices require an 802.11 `wireless network' connection to the printer. AirPrint and the AirPrint Logo are trademarks of Apple® Inc. iPad, iPhone, and iPod touch are trademarks of Apple Inc., registered in the U.S. and other countries.
[5] Requires access to third party apps stores. See www.hp.com/go/mobile-printing-solutions for details of compatible devices.
[6] Requires a wireless access point and an Internet connection to the printer. Services may require registration. App availability varies by country, language and agreements. See www.hp.com/go/eprintcenter.
[7] Not included, please purchase separately.
  • Print web content without a PC using the 6.0 cm colour touchscreen and a selection of apps
    Use the intuitive, easy-to-use colour touchscreen to print, copy and scan – even print web content – without a PC.Access easy-to-use apps and print Sudoku puzzles, colouring pages and more.Choose HP Quick Forms and print templates such as calendars, games and notebook pages.Enjoy fingertip control – print photos and documents, make copies and scan photos, all via the colour touchscreen.
  • Get great print quality with affordable individual HP inks
    Print using affordable, individually-replaceable ink cartridges; optional XL cartridges for frequent printing.Sleek and stylish space-saving design – fits on shelves or bookcases.Print lab-quality borderless photos – perfect for framing, albums or to share as gifts.Choose Original HP print cartridges for high quality, reliable printing and copying.
HP Photosmart 5510 e-All-in-One B111a - multifunction printer - colour
Multifunction printer
Copier Type
Digital
Printing Technology
Ink-jet (colour)
Inkjet Technology
HP Thermal Inkjet - 4-ink
Monthly Duty Cycle (max)
2500 impressions
Max Copying Resolution
Up to 600 dpi (mono) / up to 600 dpi (colour)
Max Printing Speed
Up to 22 ppm (mono) / up to 21 ppm (colour)
Max Printing Resolution
Up to 1200 x 600 dpi (mono) / up to 4800 x 1200 dpi (colour)
Scanning
1200 x 1200 dpi
Original Size
216 x 297 mm (max)
Media Size
A4 (210 x 297 mm) (max)
Media Type
Transparencies, envelopes, plain paper, cards, labels, photo paper
Standard Media Capacity
80 sheets
Output Trays Capacity
15 sheets
Connection Availability
USB 2.0, Wi-Fi(n)
AC 110/230 V (50/60Hz)
43.6 cm x 32.5 cm x 14.6 cm
5.1 kg
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified
Copier Type
Digital
Printing Technology
Ink-jet - colour - photo
2500 impressions
Display Features
Touch screen
USB 2.0, Wi-Fi(n)
Standard Memory
64 MB 64 MB
Max Supported Memory
64 MB 64 MB
Supported Flash Memory
SD Memory Card, MultiMediaCard, Memory Stick Duo
Copying
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
30
Printing
Inkjet Technology
HP Thermal Inkjet
Max Printing Speed
Ink Cartridge Configuration
4 cartridges (1 each: cyan, magenta, yellow, black)
Ink Palette Supported (Colours)
Cyan, magenta, yellow, black
4-ink
Printer Drivers / Emulations
PCL 3 GUI
Scanning
Scan Element
CIS
Optical Resolution
1200 x 1200 dpi
Interpolated Resolution
19200 dpi
Colour Depth
24-bit
Document & Media Handling
Max Original Size
216 x 297 mm
Max Media Size
A4
Min Media Weight
75 g/m²
Max Media Weight
300 g/m²
Supported Media Type
Supported Media Sizes
A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), 100 x 150 mm, 130 x 180 mm, C6 (114 x 162 mm), 100 x 300 mm, 110 x 220 mm
Borderless Photo Sizes
ANSI A (Letter) (216 x 279 mm)
80 sheets
15 sheets
Input tray - 80 sheets - A4 (210 x 297 mm) , Output tray - 15 sheets
Speed Details
Printing: up to 22 ppm (A4) - B/W draft , Printing: up to 21 ppm (A4) - colour draft , Copying: up to 4.5 ppm - B/W normal , Copying: up to 5.5 ppm - colour normal
1 x USB 2.0
Operating System Support
MS Windows XP SP2 or later, Apple Mac OS X 10.5, MS Windows 7, MS Windows Vista, Apple Mac OS X 10.6, Apple Mac OS X 10.7
Software Included
HP Photo Creations
13.9 Watt
Power Consumption Standby
4.5 Watt
Power Consumption Sleep
1.9 Watt
Consumables Included
1 x ink cartridge (black) - HP 364 , 1 x ink cartridge (cyan) - HP 364 , 1 x ink cartridge (magenta) - HP 364 , 1 x ink cartridge (yellow) - HP 364
ENERGY STAR Certified
43.6 cm
32.5 cm
14.6 cm
5.1 kg
Sound Emission
50 dBA (operating)
45 °C
7KTY HP Everyday Semi-Gloss Photo Paper-100 sheet/A4/210 x 297 mm In Stock £16.53
7KTY HP 364 Black Original Ink Cartridge In Stock £12.49
7KTY HP 364 Cyan Original Ink Cartridge In Stock £11.39
7KTY HP 364 Magenta Original Ink Cartridge In Stock £11.39
7KTY HP 364XL High Yield Black Original Ink Cartridge In Stock £23.21
