The ruggedly built HP ProBook Fortis provides reliability and performance for workers and students who need a PC they can work with throughout the day-wherever the day takes them. The large 14-inch diagonal screen, robust connectivity options, and collaboration tools enhance productivity and engagement from almost anywhere.
Windows 11
Work anywhere without compromising on performance or security with Windows 11 powered by HP's collaboration and connectivity technology. -
Fast and efficient wireless LAN
The portability of your PC and the reliability of a fast connection determines where you can work. Get a fast and reliable connection in dense wireless environments with gigabit-speed Wi-Fi 6. -
Preserve your privacy
Never wonder if someone is watching you with the added peace-of-mind that comes from the integrated HP Privacy Camera, with a physical shutter to protect from malicious surveillance. -
HP Sure Sense
Malware is evolving rapidly and traditional antivirus can't always recognize new attacks. Protect your PC against never-before-seen attacks with HP Sure Sense, which uses deep learning AI to provide exceptional protection against advanced malware. -
Work without interruption
Keep productivity high and downtime low with the fully integrated and automated features of the HP BIOSphere Gen6 firmware ecosystem. Your PCs have extra protection thanks to automatic updates and security checks. -
Speed up the basics of IT management
The HP Manageability Integration Kit helps speed up image creation and management of hardware, BIOS, and security through Microsoft System Center Configuration Manager.
- HP ProBook Fortis 14 G9 Notebook - 14" - Intel Celeron - N5100 - 4 GB RAM - 128 GB SSD - UK
- Product Type
- Notebook
- Operating System
- Win 11 SE - English
- Processor
- Intel Celeron N5100 / 1.1 GHz, up to 2.8 GHz / 4 MB Cache
- Memory
- 4 GB DDR4 (provided memory is soldered)
- Storage
- 128 GB SSD - NVMe, HP Value
- Display
- 14" WLED 1366 x 768 / HD @ 60 Hz
- Graphics
- Intel UHD Graphics
- Input Device
- ClickPad
- Keyboard
- UK
- Integrated Webcam
- Networking
- Bluetooth 5.0, 802.11a/b/g/n/ac/ax, Gigabit Ethernet
- Battery
- 3-cell
- Security
- Trusted Platform Module (TPM 2.0) Security Chip
- Jack black
- 33.6 cm x 23 cm x 2.19 cm
- 1.66 kg
- Localisation
- Environmental Standards
- TCO Certified Notebooks 9, ENERGY STAR Qualified
- Carbon Footprint
- 150 kg carbon emissions
- Limited warranty - parts and labour - 1 year
- Product Type
- Notebook
- Operating System
- Windows 11 SE - English
Processor / Chipset
- CPU
- Max Turbo Speed
- 2.8 GHz
- Number of Cores
- Quad-Core
- Cache
- L3 - 4 MB
- Intel Burst Technology
- RAM
- 4 GB (provided memory is soldered)
- Technology
- DDR4 SDRAM - non-ECC
- Speed
- 2933 MHz
- Rated Speed
- 3200 MHz
Storage
- Main Storage
- 128 GB SSD M.2 2230 PCIe - NVM Express (NVMe), HP Value
Display
- 14"
- LCD Backlight Technology
- WLED backlight
- Resolution
- 1366 x 768 (HD)
- V-Sync Rate at Max Res.
- 60 Hz
- Widescreen
- Image Brightness
- 250 cd/m²
- Colour Gamut
- 45% NTSC
- Ultra Slim Design, HD standard-viewing angle (SVA) eDP anti-glare, Micro Edge, narrow bezel bent
Audio & Video
- Graphics Processor
- Camera
- Yes - HD
- Video Resolutions
- 720p
- Camera Features
- Privacy shutter
- Sound
- Stereo speakers, dual array microphone
Input
- Keyboard, ClickPad
- Keyboard Layout
- UK
- Multi-touch clickpad, gesture function, pick resistant, spill-resistant
Communications
- Wireless
- Wireless Controller
- Intel Wi-Fi 6 AX 201
- Network Interface
- Gigabit Ethernet
- Ethernet Controller
- Realtek RTL8111HSH-CG
- Wake-on-LAN (WOL), dual stream (2x2), MU-MIMO
- Technology
- 3-cell lithium polymer
- Capacity
- 42 Wh
AC Adapter
- Input
- AC 90-265 V (50/60 Hz)
- Output
- 45 Watt, 19.5 V
Connections & Expansion
- Interfaces Details
- 2 x USB 3.2 Gen 1 , USB-C 3.2 Gen 1 (supports DisplayPort 1.2 Alt Mode) (Power Delivery) , LAN , Headphone/microphone combo jack , HDMI
Software
- Software Included
- HP Support Assistant, HP Hotkey Support, HP Client Catalogue (free download), HP Driver Packs, HP PC Hardware Diagnostics, HP MAC Address Manager, HP Notifications, HP Connection Optimizer, HP Classroom Manager, HP Privacy Settings, HP QuickDrop, HP Client Management Script Library (free download), HP Image Assistant Gen5, HP Wake on WLAN, myHP, Touchpoint Customiser for Commercial, HSA Fusion for Commercial, HSA Telemetry for Commercial, HP Easy Clean, HP Smart Support, HP Connect for Microsoft Endpoint Manager, HP Patch Assistant (free download), HP Manageability Integration Kit Gen4 (free download)
- Jack black
- Security
- BIOS Absolute Persistence, HP Automatic Drive Lock, HP DriveLock, BIOS Update via Network, HP Sure Sense, HP Secure Erase, HP BIOSphere Gen 6, HP Sure Start Gen 7
- Theft/Intrusion Protection
- Security Slot Type
- Kensington nano security slot
- Included Accessories
- HP 45 Watt Smart nPFC AC Adapter
- CSA, UL, VCCI, BSMI, GOST, SABS, CCC, FIPS 140-2 Level 2, FCC, A-Tick, ICES, Common Criteria EAL4+, KC, CIT, low halogen, ICCP, BNCI
- Localization
- 1.66 kg
Sustainability Information
- TCO Certified
- - TCO Certified Notebooks 9
- ENERGY STAR Certified
- Carbon Footprint
- Manufacturing (kg CO2e)
- 123
- Use (kg CO2e)
- 19
- EOL (kg CO2e)
- 0.8
- 0 °C
- 35 °C
- 10 - 90% (non-condensing)
- Shock Tolerance (operating)
- 40 g @ 2 ms half-sine
- Shock Tolerance (non-operating)
- 240 g @ 2 ms half-sine
- Vibration Tolerance (operating)
- 0.75 g @ RMS (random)
- Vibration Tolerance (non-operating)
- 1.5 g @ RMS (random)
Essential Accessories (3)
Get more from your purchase from one of our essential accessories
HP 65W Smart AC Adapter | In Stock | £17.92 |
HP USB-C Dock G5 Docking Station USB-C GigE 100 Watt | In Stock | £119.67 |
HP USB-C/A Universal Dock G2 - Docking station - USB-C HDMI DP GigE 100 Watt | In Stock | £177.69 |
Other bundles (5)
HP USB-C To VGA Adapter | In Stock | £22.09 |
HP USB Travel Mouse | In Stock | £9.25 |
HP USB-C to HDMI 2.0 Adapter | In Stock | £46.71 |
HP E 24" G4 WUXGA 1920 x 1200 LED Backlit Monitor | In Stock | £138.54 |
HP P34hc G4 34" 3440x1440 5ms HDMI DisplayPort USB-C LED Curved Monitor | In Stock | £373.33 |
