Take every moment, memory and movie night to amazing heights with this display. The ultra-wide viewing angle and high resolution let you transform your content into a big, bold and beautifully immersive experience the whole family can share.
Unforgettable QHD picture
Brilliant details and captivating definition. Get it all with the unforgettable image quality of a 2560 x 1440 resolution display. -
MVA Panel
The ideal balance of wide-angle viewing, and low pixel latency, the MVA panel is perfect for the everyday use you need from your display. -
Highly accurate color
With the standard 100% Srgb color space, the HP ENVY 32 Media Display provides ideal color reproduction with minimal effort. Perfect for photos, videos-all your creative projects. -
Open and accessible
The display is suspended above a distinctly unique open-wedge designed stand, providing convenient access to rear ports, with your tablet or phone stored underneath. -
Seamless entertainment
How fast your display's pixels respond is crucial for a silky smooth picture. With a 7ms response time, your action-filled content will look crisp and fluid without motion blur.
- HP Pavilion LED monitor - 32"
- LED-backlit LCD monitor - 32"
- Energy Class
- Class A
- Energy Consumption per Year
- 60 kWh
- Power Consumption (On mode)
- 41 W
- USB 2.0 hub
- Panel Type
- MVA
- Aspect Ratio
- 16:9
- Native Resolution
- QHD 2560 x 1440 at 60 Hz
- Pixel Pitch
- 0.276 mm
- Brightness
- 300 cd/m²
- Contrast Ratio
- 3000:1 / 10000000:1 (dynamic)
- Response Time
- 7 ms (grey-to-grey)
- Colour Support
- 16.7 million colours
- Colour Gamut
- 100% sRGB
- Input Connectors
- 2xHDMI, DisplayPort
- Tilt
- Voltage
- AC 100/240 V (50/60 Hz)
- Black
- 73.99 cm x 17.89 cm x 52.23 cm
- 9.8 kg
- Localisation
- English / United Kingdom
- Environmental Standards
- ENERGY STAR Qualified
- Plug and Play, VCCI, BSMI, NOM, TUV S, CB, CCC, FCC, ISO 9241-307, KCC, ICES, CECP, CEL, EPA, ISC, SEPA, CoC
- 1-year warranty
- Display Type
- Energy Class
- Class A
- 60 kWh
- Diagonal Size
- 32"
- Built-in Devices
- USB 2.0 hub
- Panel Type
- MVA
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.276 mm
- Brightness
- 300 cd/m²
- Contrast Ratio
- Colour Support
- Colour Gamut
- 100% sRGB
- Response Time
- Vertical Refresh Rate
- 60 Hz
- Horizontal Refresh Rate
- 90 kHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Backlight Technology
- LED backlight
- HDCP, anti-glare, Frame Rate Control (FRC), On-screen Digital Controls, Mercury free, arsenic-free glass
- Black
- 73.99 cm x 17.89 cm x 52.23 cm - with stand
- 9.8 kg
- 2 x HDMI (HDCP) , DisplayPort (HDCP) , 2 x USB 2.0 downstream , USB 2.0 upstream
Mechanical
- Tilt
- Tilt Angle
- -5/+21
- Security lock slot (cable lock sold separately), detachable stand, VESA interface support
- Included Accessories
- Stand, VESA bracket
- Cables Included
- 1 x power cable , 1 x HDMI cable
- Localisation
- Input Voltage
- 41 W
- Power Consumption (Typical)
- 72 Watt
- Power Consumption Stand by
- 0.5 Watt
- Included Software
- HP MyDisplay
- Dimensions & Weight Details
- With stand - width: 73.99 cm - depth: 17.89 cm - height: 52.23 cm - weight: 9.8 kg , Without stand - width: 73.99 cm - depth: 5.32 cm - height: 43.34 cm - weight: 8.2 kg
Sustainability Information
- ENERGY STAR Certified
- Limited warranty - 1 year
- 5 °C
- 35 °C
- 20 - 70% (non-condensing)
