Brand
HP Pagewide Pro 777z Multifunction Printer
Quicklinx: CW3VWS00 Mfr#: Y3Z55B#B19
£2,885.32 ex VAT
£3,462.38 inc VAT
Annoying interruptions and complex maintenance slow down printing and ultimately, the pace of business. Avoid pauses in productivity with an HP PageWide Pro designed for maximum uptime, and count on reliable results day in and day out.
  • The lowest cost for colour
    Get the quality you expect with HP PageWide Technology that delivers the lowest cost per colour page.Print more pages and replace cartridges less often with optional high-yield cartridges.Print even faster – and save even more per page – by setting this printer to General Office mode.Help keep energy costs down with the most efficient MFP in its class.
  • Minimal interruptions
    Minimise interruptions with an HP PageWide Pro designed for the least maintenance in its class.Print speeds up to 50% faster than competitors – as fast as 65 ppm in colour and black-and-white.Print Microsoft Word and PowerPoint files with a USB port that quickly recognises, formats, and prints.Organise, staple, and collate documents with in-line finishing that helps you save time and look professional.
  • Strong security designed to detect and stop attacks
    A suite of embedded security features help protect your printer from being an entry point for attacks.Help ensure the security of confidential information. Enter a PIN at the device to retrieve your print job.Easily set configuration policies and automatically validate settings for every HP printer in your fleet.Prevent potential attacks and take immediate action with instant notification of security issues.
  • Designed with the environment in mind
    Conserve resources with an HP PageWide Pro designed to use less energy than any laser MFP in its class.This MFP meets rigorous standards for ISO class 5 cleanrooms – perfect for sensitive environments.Help reduce your impact. Count on easy cartridge recycling at no charge through HP Planet Partners.Keep noise to a minimum with an MFP designed to be quiet. Place it near people without disrupting work.
HP PageWide Pro 777z - multifunction printer - colour
Multifunction printer
Fax Type
Plain paper
English, German, French, Italian, Spanish / Europe
Printing Technology
Page wide array (colour)
Inkjet Technology
HP PageWide - 4-ink
Monthly Duty Cycle (max)
100000 pages
Recommended Monthly Volume
2500 - 35000 pages
Max Copying Speed
Up to 45 ppm (mono) / up to 45 ppm (colour)
Max Copying Resolution
Up to 600 dpi (mono) / up to 600 dpi (colour)
Max Printing Speed
Max Printing Resolution
Up to 1200 x 1200 dpi (mono) / up to 2400 x 1200 dpi (colour)
Max Fax Transmission Speed
33.6 Kbps
Fax Resolutions
203 x 98 dpi, 203 x 196 dpi, 300 x 300 dpi, 200 x 200 dpi
Scanning
600 x 600 dpi
Display
8"
Original Size
A4 (210 x 297 mm), A3 (297 x 420 mm) (max)
Original Type
Sheets
Document Feeder Capacity
50 sheets
Media Size
76.2 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm), A3 (297 x 420 mm) (max)
Media Type
Envelopes, plain paper, cards, labels, recycled paper, greeting cards, photo paper, bond paper, heavy-weight paper, extra heavy-weight paper, light-weight paper, glossy photo paper, matte photo paper, glossy paper, tri-fold paper, matte paper, punched paper
Standard Media Capacity
650 sheets
Max Media Capacity
4650 sheets
Output Trays Capacity
500 sheets
Automatic Duplexing
Yes (copying) Yes (printing) Yes (scanning)
Connection Availability
USB 2.0, LAN, Wi-Fi(n), NFC, USB 2.0 host
AirPrint Enabled
Office Machine Features
Print from USB flash drive, save to USB flash drive, scan to e-mail, scan to folder, scan to network, HP EasyColor, Mobile Printing, access point mode, scan to SharePoint, scan to PC, scan to OCR
AC 120/230 V (50/60Hz)
59.8 cm x 57.6 cm x 72.8 cm
69.5 kg
Environmental Standards
ENERGY STAR Qualified, Blue Angel
1-year warranty
Fax Type
Plain paper
Printing Technology
Page wide array - colour
100000 pages
2500 - 35000 pages
Display Diagonal Size
8"
Display Features
Touch screen
AirPrint Enabled
Standard Memory
1.5 GB
Max Supported Memory
1.5 GB
Hard Disk Drive
16 GB
Copying
Max Copying Speed
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
999
Automatic Duplexing
Copying Features
ID Card Copy, collation copy, Auto Color Selection (ACS)
Printing
Inkjet Technology
HP PageWide
Max Printing Speed
Ink Cartridge Configuration
4 cartridges (1 each: cyan, magenta, yellow, black)
Ink Palette Supported (Colours)
Cyan, magenta, yellow, black
4-ink
Printer Drivers / Emulations
PCL 6, PostScript 3, PCL 6 (XL), PDF
Automatic Duplexing
First Print Out Time B/W
7.75 sec
First Print Out Time Colour
7.75 sec
Scanning
Scan Element
CIS
Automatic Duplexing
Optical Resolution
600 x 600 dpi
Grayscale Depth
8-bit
Colour Depth
24-bit
Fax Machine
Max Transmission Speed
33.6 Kbps
Fax Resolutions
Total Memory Capacity
Up to 500 pages
Fax Printing Resolution
300 x 300 dpi
PC Faxing
Fax Machine Features
Broadcast Transmission
20 stations
Delayed Transmission
Remote Fax Retrieval (Polling)
Fax forwarding, automatic redialing, colour faxing, junk fax barrier, auto reduction, Distinctive Ring Detection (DRD), delayed sending, fax polling, TAM Interface
Document & Media Handling
Max Original Size
Original Type
Sheets
50 sheets
Min Media Size
76.2 x 127 mm
Max Media Size
A3
Min Media Weight
60 g/m²
Max Media Weight
300 g/m²
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A3 (297 x 420 mm), 101.6 x 152.4 mm, Statement (139.7 x 215.9 mm), 127 x 178 mm, 76.2 x 127 mm, Oficio (216 x 343 mm)
Supported Envelope Sizes
US No 10 (104.7 x 241.3 mm)
650 sheets
Max Media Capacity
4650 sheets
500 sheets
ADF - 100 sheets size: 101.6 x 210.8 mm - 215.9 x 297.2 mm , Input tray - 500 sheets size: 76.2 x 127 mm - 215.9 x 355.6 mm , Output tray - 500 sheets
Speed Details
Printing: up to 65 ppm (A4) - B/W draft , Printing: up to 65 ppm (A4) - colour draft , Printing: up to 45 ppm (A4) - B/W normal , Printing: up to 45 ppm (A4) - colour normal , Printing: up to 45 ppm (A4) - B/W (ISO) , Printing: up to 45 ppm (A4) - colour (ISO) , Copying: up to 65 ppm (A4) - B/W draft , Copying: up to 65 ppm (A4) - colour draft , Copying: up to 45 ppm - B/W (ISO) , Copying: up to 45 ppm - colour (ISO) , Scanning: up to 50 ipm (A4) - B/W normal , Scanning: up to 50 ipm (A4) - colour normal , Scanning: up to 35 ipm (A4) - B/W duplex , Scanning: up to 35 ipm (A4) - colour duplex
2 x modem - RJ-11 , 1 x LAN - RJ-45 , 1 x USB 2.0 - 4 pin USB Type B , 2 x USB 2.0 host - 4 pin USB Type A
Security Protocols & Features
LDAP, SSL, LEAP, TLS, WPA2, 802.1x, WPA2-PSK, EAP-TLS, PEAP
Operating System Support
UNIX, Novell NetWare 6, Linux, MS Windows 7, Novell NetWare 6.5, Apple Mac OS X 10.6, MS Windows Server 2008 R2, MS Windows Server 2012, Windows 8, Novell Open Enterprise Server, MS Windows Server 2003 (32/64-bits), MS Windows Server 2003 R2 (32/64-bits), MS Windows Small Business Server 2003 (32/64 bits), MS Windows Server 2008 (32/64-bits), MS Windows Small Business Server 2008 x64 Edition, MS Windows XP 32-bit Edition SP3 or later, Windows 10, MS Windows Vista 32-bit Edition
Software Included
Drivers & Utilities, I.R.I.S. OCR, HP Web Jetadmin, HP Participation Study
75.2 Watt
Power Consumption Sleep
3.13 Watt
First Copy Out Time B/W
7.25 sec
First Copy Out Time Colour
7.25 sec
Consumables Included
1 x ink cartridge (black) - up to 10000 pages - HP 993 , 1 x ink cartridge (cyan) - HP 993 , 1 x ink cartridge (magenta) - HP 993 , 1 x ink cartridge (yellow) - HP 993
GS, CCC, EMC, RoHS, REACH, EN 60825-1, EN 62479:2010, IEC 62471:2006, EN 62471:2008, 21 CFR 1040.10, EN 301 489-1 V1.9.2, EN 301 489-17 V2.2.1, EN 61000-3-3:2013, EN 55024:2010, CISPR 22:2008, EN 62311:2008, EN 61000-3-2:2014, IEC 60950-1:2005 + A1:2009 + A2:2013, IEC 62479:2010, IEC 62311:2007, LVD 2014/35/EU, EN60950-1:2006 + A11:2009 + A1:2010 + A12:2011 + A2:2013, ICES-003 issue 6 Class A, Directive 2014/30/UE, CISPR 32, ES 203 021-3 V2.1.2, ES 203 021-1 V2.1.1
ENERGY STAR Certified
Blue Angel Compliant
Limited warranty - parts and labour - 1 year - on-site
59.8 cm
57.6 cm
72.8 cm
69.5 kg
Sound Emission
55 dBA (operating)
15 °C
30 °C
20 - 80%
CW3V HP Iron-on Transfers-12 sheet/A4/210 x 297 mm In Stock £13.92
CW3V HP 991X High Yield Black Original PageWide Cartridge In Stock £171.30
CW3V HP 991X High Yield Cyan Original PageWide Cartridge In Stock £186.88
CW3V HP 991X High Yield Yellow Original PageWide Cartridge In Stock £186.88
CW3V HP 991X High Yield Magenta Original PageWide Cartridge In Stock £186.88
Functionality: Printer
Functionality: Fax
Functionality: Scanner
Functionality: Copier
Max Paper Size: A3 (297 x 420 mm)
Max Paper Size: A4 (210 x 297 mm)
Brand: HP
Price Range Ex VAT: £1500+
