Annoying interruptions and complex maintenance slow down printing and ultimately, the pace of business. Avoid pauses in productivity with an HP PageWide Pro designed for maximum uptime, and count on reliable results day in and day out.
The lowest cost for colour
Get the quality you expect with HP PageWide Technology that delivers the lowest cost per colour page.Print more pages and replace cartridges less often with optional high-yield cartridges.Print even faster – and save even more per page – by setting this printer to General Office mode.Help keep costs down – this HP PageWide Pro uses less energy than any laser competitor in its class. -
Minimal interruptions
Minimise interruptions with an HP PageWide Pro designed for the least maintenance in its class.Wait less, do more with best-in-class speeds – as fast as 55 ppm in colour and black-and-white.Print Microsoft Word and PowerPoint files with a USB port that quickly recognises, formats, and prints.Equip this HP PageWide Pro with a variety of accessories to meet the needs of your office. -
Strong security designed to detect and stop attacks
A suite of embedded security features help protect your printer from being an entry point for attacks.Help ensure the security of confidential information. Enter a PIN at the device to retrieve your print job.Easily set configuration policies and automatically validate settings for every HP printer in your fleet.Prevent potential attacks and take immediate action with instant notification of security issues. -
Designed with the environment in mind
Conserve resources with an HP PageWide Pro designed to use less energy than any laser printer in its class.Certified for ISO class 5 cleanrooms – perfect for sensitive environments.Help reduce your impact. Count on easy cartridge recycling at no charge through HP Planet Partners.Keep noise to a minimum with a printer designed to be quiet. Place it near people without disrupting work.
- HP PageWide Pro 750dw - printer - colour - page wide array
- Printer Type
- Workgroup printer - page wide array - colour
- 50.2 kg
- Localisation
- Danish / Denmark
- Inkjet Technology
- HP PageWide
- Ink Palette Supported (Colours)
- 4-ink - cyan, magenta, yellow, black
- Media Size Class
- A3
- Max Media Size
- A3 (297 x 420 mm)
- Min Media Size (Custom)
- 76 mm x 127 mm
- Max Media Size (Custom)
- 216 mm x 457.2 mm
- Print Speed
- Up to 55 ppm - black draft - A4 (210 x 297 mm) , Up to 55 ppm - colour draft - A4 (210 x 297 mm) , Up to 35 ppm - B/W (ISO/IEC 24734) , Up to 35 ppm - colour (ISO/IEC 24734) , Up to 35 ppm - black normal - A4 (210 x 297 mm) , Up to 35 ppm - colour normal - A4 (210 x 297 mm) , Up to 24 ipm - B/W duplex - A4 (210 x 297 mm) , Up to 24 ipm - colour duplex - A4 (210 x 297 mm)
- Max Resolution (B&W)
- 1200 x 1200 dpi
- Max Resolution (Colour)
- 2400 x 1200 dpi
- Automatic Duplexing
- Interface
- USB 2.0, LAN, Bluetooth, Wi-Fi(n), NFC, USB 2.0 host
- AirPrint Enabled
- Preview Screen Size
- 4.3"
- Processor
- 1.5 GHz
- RAM Installed (Max)
- 1.5 GB (1.5 GB)
- Language Simulation
- PostScript 3, PCL 6, PCL XL, PDF
- Media Type
- Envelopes, greeting cards, labels, plain paper, photo paper, cards, bond paper, recycled paper, brochure paper, tri-fold brochure paper, extra heavy-weight paper, light-weight paper, punched paper
- Total Media Capacity
- 650 sheets
- Media Handling
- 100-sheet multipurpose tray, 550-sheet input tray
- Monthly Duty Cycle (max)
- 75000 pages
- Recommended Monthly Volume
- 2500 - 15000 pages
- Networking
- Radio access point
- Printer Features
- HP EasyColor
- System Requirements
- UNIX, Linux, Novell NetWare 6, Novell NetWare 6.5, Microsoft Windows Server 2003 Standard x64 Edition, Microsoft Windows Server 2003 Enterprise x64 Edition, Microsoft Windows Server 2003 R2 Enterprise x64 Edition, Microsoft Windows Server 2003 R2 Standard x64 Edition, Microsoft Windows Server 2008 R2, Apple MacOS X 10.6, Microsoft Windows Vista (32-bit versions), Microsoft Windows Compute Cluster Server, Citrix Presentation Server 4.5, Microsoft Windows Server 2008 Enterprise x64 Edition, Microsoft Windows Server 2008 Standard x64 Edition, Citrix Presentation Server 4.0, Microsoft Windows 7 (32/64 bits), Microsoft Windows Small Business Server 2008 x64 Edition, Microsoft Windows Small Business Server 2011, Citrix XenApp 6.0 64-bit, Citrix XenServer 5.6, Citrix XenDesktop 5.5, Microsoft Windows Server 2012, Apple OS X 10.8 Mountain Lion, Windows 8 (32/64 bits), Citrix XenApp, Microsoft Windows Small Business Server 2003 (32/64 bits), Citrix XenApp 6.5, Microsoft Windows XP SP2 (32 bit) or later, Windows 8.1 (32/64 bits), Apple OS X 10.9 Mavericks, Microsoft Windows Server 2008 R2 Enterprise (64-bit), Microsoft Windows Server 2008 R2 Standard (64-bit), Microsoft Windows XP SP3 (32 bit) or later, Apple OS X 10.10 Yosemite, Microsoft Windows Server 2003 R2 Standard Edition (32-bit), Windows 10 (32/64 bits), Microsoft Windows Server 2003 Standard Edition (32-bit), Microsoft Windows Server 2003 Enterprise Edition (32-bit)
- Environmental Standards
- EPEAT Silver
- 1-year warranty
- 59.8 cm x 53.1 cm x 45.7 cm
- Printer Type
- Localisation
- Danish / Denmark
Printer
- Inkjet Technology
- HP PageWide
- Ink Cartridge Configuration
- 4 cartridges (1 each: cyan, magenta, yellow, black)
- Print Speed
- Built-in Devices
- Touch screen
- 4.3"
- Connectivity Technology
- Wireless
- Interface
- AirPrint Enabled
- 1200 x 1200 dpi
- 2400 x 1200 dpi
- PostScript Support
- Standard
- First Print Out Time B/W
- 8.25 sec
- First Print Out Time Colour
- 8.25 sec
- Fonts Included
- 1
- Printer Features
- HP EasyColor
- Media Handling
- Processor
- 1.5 GHz
RAM
- 1.5 GB / 1.5 GB (max)
Media Handling
- Media Type
- Media Size Class
- A3
- Max Media Size
- A3 (297 x 420 mm)
- 76 mm x 127 mm
- 216 mm x 457.2 mm
- Media Sizes
- A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A3 (297 x 420 mm), A6 (105 x 148 mm), 100 x 150 mm, 216 x 297 mm, C5 (162 x 229 mm), JIS B5 (182 x 257 mm), C6 (114 x 162 mm), 76 x 127 mm, Oficio (216 x 343 mm), 216 x 356 mm, JIS B6 (128 x 182 mm), DL (210 x 99 mm), 102 x 210 mm
- Envelope Sizes
- US No 10 (104.7 x 241.3 mm)
- Media Weight
- 60 g/m² - 300 g/m²
- 650 sheets
- Media Feeders
- 1 x automatic - 100 sheets - A3 (297 x 420 mm) , 1 x automatic - 550 sheets - A3 (297 x 420 mm)
- Output Trays Capacity
- 500 sheets
Duty Cycle
- 75000 pages
- Networking
- Remote Management Protocol
- SNMP 1, SNMP 2, SNMP 3, IPP, HTTP, HTTPS, IPPS, SLP
- LDAP, LEAP, WPA, 802.1x, PING, ARP, Wi-Fi Direct, PEAP
- Connections
- 1 x USB 2.0 - 4 pin USB Type B , 2 x USB 2.0 host - 4 pin USB Type A , 1 x LAN - RJ-45 , 2 x modem - RJ-11
- Consumables Included
- 1 x ink cartridge (black) , 1 x ink cartridge (cyan) , 1 x ink cartridge (magenta) , 1 x ink cartridge (yellow)
- RoHS, REACH, CECP, EN 61000-3-3:2008, EN 61000-3-2:2006+A1:2009+A2:2009, EN 62479:2010, EN 301 489-17 V2.2.1 (2012-09), IEC 61000-4-11:2004, EN 301 489-1 V1.9.2, EN 301 489-17 V2.2.1, EN 61000-3-3:2013, CISPR 24:2010, EN 55024:2010, EN 301 489-1 V1.9.2:2011, EN 301 489-17 V2.2.1:2012, EN 301 489-1 V1.9.2 (2011-09), EMC 2014/30/EU, EN 62311:2008, FCC Part 15 Class B, EN 61000-3-2:2014, IEC 60950-1:2005 + A1:2009 + A2:2013, IEC 62479:2010, IEC 62311:2007, LVD 2014/35/EU, EN 300 893, EN 300 328 V1.9.1, ICES-003:2004 Class B, VCCI V-3/2015.04 Class B, CISPR 32 Class B, EN 60950-1:2006+A11:2009+A1:2010+A12:2011+A2:2013, EN 55022:2010 Class B
- Power Device
- Power supply - internal
- Frequency Required
- 50/60 Hz
- 63.4 Watt
- Power Consumption Sleep
- 1.87 Watt
- Software Included
- Drivers & Utilities, HP Web JetAdmin, HP Embedded Web Server, Printer utility for Mac, Bing Toolbar, HP Software Update
- OS Required
- System Requirements Details
- Windows 7/8/8.1/10 - HD 2 GB , Windows XP SP3 - 233 MHz HD 850 MB , MacOS 8.6 or later - HD 1 GB
- EPEAT Compliant
- EPEAT Silver
- Blue Angel
- ENERGY STAR
- Limited warranty - parts and labour - 1 year - on-site , Technical support - phone consulting - 1 year , Technical support - e-mail consulting - 1 year
- 15 °C
- 30 °C
- 20 - 80%
- Sound Emission (Operating)
- 51 dBA
- 59.8 cm
- 53.1 cm
- 45.7 cm
- 50.2 kg
- Width (Shipping)
- 79 cm
- Depth (Shipping)
- 76 cm
- Height (Shipping)
- 61.9 cm
HP Iron-on Transfers-12 sheet/A4/210 x 297 mm | In Stock | £13.72 |
