HP PageWide Pro 452dw Printer
Quicklinx: C14KWS00 Mfr#: D3Q16B#A81
  • Windows 8 (32/64 bits)
  • Windows 8.1 (32/64 bits)
Ultimate value and speed - HP PageWide Pro delivers the ultra-low total cost of ownership and incredibly fast speeds. Get professional-quality color plus ultimate security features and energy efficiency.
Count on exceptional value and the results businesses need – print professional-quality colour documents for the lowest total cost of ownership in its class.
Results you expect and lasting value – breakthrough total cost of ownership, the lowest in its class. Print professional-quality colour on a variety of papers – perfect for office use. Print more pages and replace cartridges less often, using Original HP PageWide high-yield cartridges. Spend less time and budget on scheduled maintenance with streamlined HP PageWide Technology. Keep productivity on track with best-in-class speeds and fast printing from sleep mode. Documents are ready fast, so there’s less waiting.
Wait less, do more with best-in-class speeds – as fast as 55 ppm in colour and black-and-white. Grab pages and go – without waiting. This device wakes up and prints fastest in its class. Print directly from your mobile device to your Wi-Fi Direct® printer – without accessing the company network. Minimise interruptions and downtime with efficient, reliable performance. Conserve resources and use less energy than laser printers, with HP PageWide Technology designed for today’s busy office.
Minimise downtime with HP PageWide Technology that delivers reliable performance businesses demand. Conserve with HP PageWide Technology – designed to use less energy than any printer in its class. Get professional-quality colour documents and the performance you expect with Original HP PageWide cartridges. Help protect your fleet, data, and documents with best-in-class security and fleet management features. Help secure important information and get the tools you need to work efficiently and confidently.
Help protect your investment and extend capabilities as your needs grow, with a portfolio of solutions. Help keep your printer secure – from boot up to shutdown – with secure boot and secure code integrity validation.
  • HP PageWide: Not Laser. Not inkjet. It's the best of both. A new alternative for business printing
    HP PageWide is designed with fewer moving parts. The stationary, page-width print bar enables unmatched speeds, improved reliability, and fewer replacement parts, all with professional print quality at the lowest total cost of operation in its class.
  • On-the-go printing with HP ePrint
    Print photos, documents, and more when you're on the go, using HP ePrint.
  • 2-sided printing
    Easily print from your smartphone, tablet, and notebook at work, home, or on the go.
HP PageWide Pro 452dw - printer - colour - page wide array
Printer Type
Workgroup printer - page wide array - colour
16.4 kg
EMEA (excluding Israel, Saudi Arabia)
Ink Palette Supported (Colours)
4-ink
Media Size Class
A4/Legal
Max Media Size
Legal (216 x 356 mm)/A4 (210 x 297 mm)
Min Media Size (Custom)
76 mm x 127 mm
Max Media Size (Custom)
216 mm x 356 mm
Print Speed
Up to 40 ppm - B/W , Up to 40 ppm - colour , Up to 55 ppm - black draft , Up to 55 ppm - colour draft
Max Resolution (B&W)
1200 x 1200 dpi
Max Resolution (Colour)
2400 x 1200 dpi
Automatic Duplexing
USB 2.0, LAN, Wi-Fi(n), USB 2.0 host
AirPrint Enabled
Preview Screen Size
2"
RAM Installed (Max)
512 MB (512 MB) integrated
Language Simulation
PostScript 3, PCL 6, PCL XL, PDF
Media Type
Envelopes, greeting cards, labels, plain paper, photo paper, glossy photo paper, heavy-weight paper, cards, matt photo paper, bond paper, glossy/satin photo paper, recycled paper, tri-fold brochure paper, extra heavy-weight paper, light-weight paper, soft gloss photo paper, punched paper
Total Media Capacity
500 sheets
Media Handling
500-sheet input tray, 50-sheet multipurpose tray
Monthly Duty Cycle (max)
50000 pages
Recommended Monthly Volume
750 - 4500 pages
Radio access point
Printer Features
HP EasyColor
UNIX, Linux, Novell NetWare 6, Novell NetWare 6.5, Microsoft Windows Server 2003 Standard x64 Edition, Microsoft Windows Server 2003 Enterprise x64 Edition, Microsoft Windows Server 2003 R2 Enterprise x64 Edition, Microsoft Windows Server 2003 R2 Standard x64 Edition, Microsoft Windows Server 2008 R2, Apple MacOS X 10.6, Microsoft Windows Vista (32-bit versions), Microsoft Windows Compute Cluster Server, Citrix Presentation Server 4.5, Microsoft Windows Server 2008 Enterprise x64 Edition, Microsoft Windows Server 2008 Standard x64 Edition, Citrix Presentation Server 4.0, Microsoft Windows 7 (32/64 bits), Microsoft Windows Small Business Server 2008 x64 Edition, Microsoft Windows Small Business Server 2011, Citrix XenApp 6.0 64-bit, Citrix XenServer 5.6, Citrix XenDesktop 5.5, Microsoft Windows Server 2012, Apple OS X 10.8 Mountain Lion, Windows 8 (32/64 bits), Citrix XenApp, Microsoft Windows Small Business Server 2003 (32/64 bits), Citrix XenApp 6.5, Microsoft Windows XP SP2 (32 bit) or later, Windows 8.1 (32/64 bits), Apple OS X 10.9 Mavericks, Microsoft Windows Server 2008 R2 Enterprise (64-bit), Microsoft Windows Server 2008 R2 Standard (64-bit), Microsoft Windows XP SP3 (32 bit) or later, Apple OS X 10.10 Yosemite, Microsoft Windows Server 2003 R2 Standard Edition (32-bit), Windows 10 (32/64 bits), Microsoft Windows Server 2003 Standard Edition (32-bit), Microsoft Windows Server 2003 Enterprise Edition (32-bit)
1-year warranty
53.1 cm x 40.1 cm x 37.8 cm
Printer Type
Printer
4-ink
Ink Cartridge Configuration
4 cartridges (1 each: cyan, magenta, yellow, black)
Print Speed
Built-in Devices
2 inch (5.08 cm) monochrome graphics display
Preview Screen Size
2"
Wired
AirPrint Enabled
1200 x 1200 dpi
2400 x 1200 dpi
Automatic Duplexing
PostScript Support
Standard
First Print Out Time B/W
6.5 sec
First Print Out Time Colour
7 sec
Language Simulation
Fonts Included
1
Printer Features
HP EasyColor
Media Handling
RAM
RAM Installed (Max)
512 MB / 512 MB (max)
Technology / Form Factor
Integrated
Media Handling
Media Type
Media Size Class
A4/Legal
Max Media Size
76 mm x 127 mm
216 mm x 356 mm
Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), 101.6 x 152.4 mm, Statement (139.7 x 215.9 mm), 127 x 178 mm, 215.9 x 355.6 mm, Oficio (216 x 343 mm), 127 x 203.2 mm, 102 x 210 mm
Envelope Sizes
US No 10 (104.7 x 241.3 mm)
500 sheets
Media Feeders
1 x automatic - 50 sheets - Legal (216 x 356 mm) , 1 x automatic - 500 sheets - Legal (216 x 356 mm)
Output Trays Capacity
300 sheets
Duty Cycle
50000 pages
750 - 4500 pages
Radio access point
1 x USB 2.0 - 4 pin USB Type B , 1 x USB 2.0 host - 4 pin USB Type A , 1 x LAN - RJ-45
Consumables Included
1 x ink cartridge (black) - up to 3000 pages - HP 973A , 1 x ink cartridge (cyan) - HP 973A , 1 x ink cartridge (magenta) - HP 973A , 1 x ink cartridge (yellow) - HP 973A
Power supply - internal
Frequency Required
50/60 Hz
100 watt
Power Consumption Stand by
9.5 watt
Power Consumption Sleep
4.5 watt
Software Included
Drivers & Utilities, HP Web JetAdmin, HP Embedded Web Server, Printer utility for Mac, Bing Toolbar, HP Software Update
System Requirements Details
Windows 7/8/8.1/10 - HD 2 GB , Windows XP SP3 - 233 MHz HD 850 MB , MacOS 8.6 or later - HD 1 GB
Environmental Standards
ENERGY STAR
Limited warranty - 1 year - on-site , Technical support - e-mail consulting - 1 year
15 °C
30 °C
20 - 80%
Sound Emission (Operating)
56 dBA
53.1 cm
40.1 cm
37.8 cm
16.4 kg
Width (Shipping)
60 cm
Depth (Shipping)
49.5 cm
Height (Shipping)
47.7 cm
Weight (Shipping)
20.2 kg
Ink (13)
C14K HP Everyday Semi-Gloss Photo Paper-100 sheet/A4/210 x 297 mm In Stock £16.53
C14K HP Advanced Glossy Photo Paper-25 sheet/13 x 18 cm borderless In Stock £5.10
C14K HP Advanced Glossy Photo Paper-25 sheet/A4/210 x 297 mm In Stock £9.82
C14K HP 973X High Yield Black Original PA In Stock £116.12
C14K HP 973X High Yield Cyan Original PAG In Stock £110.18
C14K HP 973X High Yield Yellow Original P In Stock £110.18
C14K HP 913A Black Original PageWide Cartridge In Stock £65.20
C14K HP 913A Cyan Original PageWide Cartridge In Stock £69.08
C14K HP 913A Magenta Original PageWide Cartridge In Stock £69.08
C14K HP 913A Yellow Original PageWide Cartridge In Stock £69.42
C14K HP 973X High Yield Black Original PageWide Cartridge In Stock £116.12
C14K HP 973X High Yield Cyan Original PageWide Cartridge In Stock £110.18
C14K HP 973X High Yield Magenta Original PageWide Cartridge In Stock £110.18
Other bundles (1)
C14K HP Premium Plus Glossy Photo Paper-20 sheet/A4/210 x 297 mm In Stock £14.16
