HP PageWide Managed Printer P55250dw
Quicklinx: C14MWS00 Mfr#: J6U55B#A81
HP Managed printers are optimized for managed environments. Offering increased monthly page volumes and fewer interventions, this product can help reduce printing and copying costs.
  • Professional color, incredible total cost
    Results you expect and lasting value - incredible total cost of ownership. Print professional-quality color on a variety of papers - perfect for office use. Print more pages than standard cartridges with HP PageWide extra-high-yield cartridges. Spend less time and budget on scheduled maintenance with streamlined HP PageWide technology.
  • Extremely fast
    Wait less, do more with amazing speeds. Grab pages and go - without waiting. Print from your mobile device with Wi-Fi Direct and NFC touch-to-print technology - no network needed.
  • Superior energy efficiency
    Minimize downtime with HP PageWide technology that delivers reliable performance businesses demand. Conserve with HP PageWide technology - designed to use less energy.
  • Great security and management features
    Help protect your investment and extend capabilities as your needs grow, with a portfolio of solutions. Help ensure the security of confidential information. Enter a PIN at the device to retrieve your print job. Add a spot of color to documents without raising costs. Regulate color use with HP color access control. Help keep your printer secure - from boot up to shutdown - with secure boot and secure code integrity validation.
HP PageWide Managed P55250dw - printer - colour - page wide array
Printer Type
Workgroup printer - page wide array - colour
16.8 kg
EMEA (excluding Israel, Saudi Arabia)
Ink Palette Supported (Colours)
4-ink - cyan, magenta, yellow, black
Media Size Class
A4/Legal
Max Media Size
Legal (216 x 356 mm)/A4 (210 x 297 mm)
Min Media Size (Custom)
76 mm x 127 mm
Max Media Size (Custom)
216 mm x 356 mm
Print Speed
Up to 75 ppm - black draft - A4 (210 x 297 mm) , Up to 50 ppm - B/W (ISO/IEC 24734) - A4 (210 x 297 mm) , Up to 75 ppm - colour draft - A4 (210 x 297 mm) , Up to 50 ppm - colour (ISO/IEC 24734) - A4 (210 x 297 mm)
Max Resolution (B&W)
1200 x 1200 dpi
Max Resolution (Colour)
2400 x 1200 dpi
Automatic Duplexing
USB 2.0, LAN, Wi-Fi(n), USB 2.0 host
AirPrint Enabled
Preview Screen Size
4.3"
RAM Installed (Max)
512 MB (512 MB) integrated
Language Simulation
PostScript 3, PCL XL, PDF
Media Type
Envelopes, greeting cards, labels, plain paper, glossy photo paper, heavy-weight paper, matt photo paper, bond paper, recycled paper, tri-fold brochure paper, extra heavy-weight paper, light-weight paper, soft gloss photo paper, punched paper, satin photo paper
Total Media Capacity
500 sheets
Media Handling
500-sheet input tray
Monthly Duty Cycle (max)
80000 pages
Recommended Monthly Volume
1000 - 6000 pages
Radio access point
Printer Features
HP EasyColor
AC 120/230 V
Apple MacOS X 10.6, Microsoft Windows Vista (32-bit versions), Microsoft Windows 7 / 8 / 8.1 / 10 (32/64 bits)
1-year warranty
53 cm x 40.7 cm x 41.95 cm
Printer Type
Printer
Ink Cartridge Configuration
4 cartridges (1 each: cyan, magenta, yellow, black)
Print Speed
Built-in Devices
Touch screen
Preview Screen Size
4.3"
Wireless
AirPrint Enabled
1200 x 1200 dpi
2400 x 1200 dpi
Automatic Duplexing
First Print Out Time B/W
6 sec
First Print Out Time Colour
6.5 sec
Language Simulation
Printer Features
HP EasyColor
Media Handling
RAM
RAM Installed (Max)
512 MB / 512 MB (max)
Technology / Form Factor
Integrated
Media Handling
Media Type
Media Size Class
A4/Legal
Max Media Size
76 mm x 127 mm
216 mm x 356 mm
Media Sizes
A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), 100 x 150 mm, 216 x 297 mm, C5 (162 x 229 mm), JIS B5 (182 x 257 mm), C6 (114 x 162 mm), 76 x 127 mm, Oficio (216 x 343 mm), 216 x 356 mm, JIS B6 (128 x 182 mm), DL (210 x 99 mm), 102 x 210 mm
Media Weight
60 g/m² - 300 g/m²
500 sheets
Media Feeders
1 x automatic - 500 sheets - Legal (216 x 356 mm) , 1 x automatic - 500 sheets - A4 (210 x 297 mm)
Output Trays Capacity
300 sheets
Duty Cycle
80000 pages
1000 - 6000 pages
Radio access point
Security Protocols & Features
Wi-Fi Direct
1 x USB 2.0 - 4 pin USB Type B , 1 x USB 2.0 host - 4 pin USB Type A , 1 x LAN - RJ-45
Consumables Included
1 x ink cartridge (black) - up to 3500 pages - HP 973A , 1 x ink cartridge (cyan) - HP 973A , 1 x ink cartridge (magenta) - HP 973A , 1 x ink cartridge (yellow) - HP 973A
EN 61000-3-3:2008, EN 61000-3-2:2006+A1:2009+A2:2009, CISPR 24:2010, EN 55024:2010, EN 55022:2010 Class B
Power supply - internal
AC 120/230 V
Frequency Required
50/60 Hz
70 Watt
Power Consumption Stand by
9.5 Watt
Power Consumption Sleep
4.5 Watt
Software Included
Drivers & Utilities, HP Web JetAdmin, HP Embedded Web Server, Printer utility for Mac, Bing Toolbar, HP Software Update
System Requirements Details
Windows 7/8/8.1/10 - HD 2 GB , Windows Vista (32/64 bits) - HD 2 GB , MacOS X 10.6 - HD 1 GB
Environmental Standards
ENERGY STAR
Limited warranty - 1 year - on-site , Technical support - phone consulting - 1 year
-40 °C
60 °C
5 - 90%
Sound Emission (Operating)
56 dBA
53 cm
40.7 cm
41.95 cm
16.8 kg
Width (Shipping)
60 cm
Depth (Shipping)
49.5 cm
Height (Shipping)
52.9 cm
Weight (Shipping)
20.75 kg
