HP Managed printers are optimized for managed environments. Offering increased monthly page volumes and fewer interventions, this product can help reduce printing and copying costs.
Professional color, incredible total cost
Results you expect and lasting value - incredible total cost of ownership. Print professional-quality color on a variety of papers - perfect for office use. Print more pages than standard cartridges with HP PageWide extra-high-yield cartridges. Spend less time and budget on scheduled maintenance with streamlined HP PageWide technology. -
Extremely fast
Wait less, do more with amazing speeds. Grab pages and go - without waiting. Print from your mobile device with Wi-Fi Direct and NFC touch-to-print technology - no network needed. -
Superior energy efficiency
Minimize downtime with HP PageWide technology that delivers reliable performance businesses demand. Conserve with HP PageWide technology - designed to use less energy. -
Great security and management features
Help protect your investment and extend capabilities as your needs grow, with a portfolio of solutions. Help ensure the security of confidential information. Enter a PIN at the device to retrieve your print job. Add a spot of color to documents without raising costs. Regulate color use with HP color access control. Help keep your printer secure - from boot up to shutdown - with secure boot and secure code integrity validation.
- HP PageWide Managed P55250dw - printer - colour - page wide array
- Printer Type
- Workgroup printer - page wide array - colour
- 16.8 kg
- Localisation
- EMEA (excluding Israel, Saudi Arabia)
- Ink Palette Supported (Colours)
- 4-ink - cyan, magenta, yellow, black
- Media Size Class
- A4/Legal
- Max Media Size
- Legal (216 x 356 mm)/A4 (210 x 297 mm)
- Min Media Size (Custom)
- 76 mm x 127 mm
- Max Media Size (Custom)
- 216 mm x 356 mm
- Print Speed
- Up to 75 ppm - black draft - A4 (210 x 297 mm) , Up to 50 ppm - B/W (ISO/IEC 24734) - A4 (210 x 297 mm) , Up to 75 ppm - colour draft - A4 (210 x 297 mm) , Up to 50 ppm - colour (ISO/IEC 24734) - A4 (210 x 297 mm)
- Max Resolution (B&W)
- 1200 x 1200 dpi
- Max Resolution (Colour)
- 2400 x 1200 dpi
- Automatic Duplexing
- Interface
- USB 2.0, LAN, Wi-Fi(n), USB 2.0 host
- AirPrint Enabled
- Preview Screen Size
- 4.3"
- RAM Installed (Max)
- 512 MB (512 MB) integrated
- Language Simulation
- PostScript 3, PCL XL, PDF
- Media Type
- Envelopes, greeting cards, labels, plain paper, glossy photo paper, heavy-weight paper, matt photo paper, bond paper, recycled paper, tri-fold brochure paper, extra heavy-weight paper, light-weight paper, soft gloss photo paper, punched paper, satin photo paper
- Total Media Capacity
- 500 sheets
- Media Handling
- 500-sheet input tray
- Monthly Duty Cycle (max)
- 80000 pages
- Recommended Monthly Volume
- 1000 - 6000 pages
- Networking
- Radio access point
- Printer Features
- HP EasyColor
- Power
- AC 120/230 V
- System Requirements
- Apple MacOS X 10.6, Microsoft Windows Vista (32-bit versions), Microsoft Windows 7 / 8 / 8.1 / 10 (32/64 bits)
- 1-year warranty
- 53 cm x 40.7 cm x 41.95 cm
- Printer Type
- Localisation
Printer
- Ink Cartridge Configuration
- 4 cartridges (1 each: cyan, magenta, yellow, black)
- Print Speed
- Built-in Devices
- Touch screen
- 4.3"
- Connectivity Technology
- Wireless
- Interface
- AirPrint Enabled
- 1200 x 1200 dpi
- 2400 x 1200 dpi
- First Print Out Time B/W
- 6 sec
- First Print Out Time Colour
- 6.5 sec
- Printer Features
- HP EasyColor
- Media Handling
RAM
- 512 MB / 512 MB (max)
- Technology / Form Factor
- Integrated
Media Handling
- Media Type
- Media Size Class
- A4/Legal
- Max Media Size
- 76 mm x 127 mm
- 216 mm x 356 mm
- Media Sizes
- A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), 100 x 150 mm, 216 x 297 mm, C5 (162 x 229 mm), JIS B5 (182 x 257 mm), C6 (114 x 162 mm), 76 x 127 mm, Oficio (216 x 343 mm), 216 x 356 mm, JIS B6 (128 x 182 mm), DL (210 x 99 mm), 102 x 210 mm
- Media Weight
- 60 g/m² - 300 g/m²
- 500 sheets
- Media Feeders
- 1 x automatic - 500 sheets - Legal (216 x 356 mm) , 1 x automatic - 500 sheets - A4 (210 x 297 mm)
- Output Trays Capacity
- 300 sheets
Duty Cycle
- 80000 pages
- 1000 - 6000 pages
- Networking
- Wi-Fi Direct
- Connections
- 1 x USB 2.0 - 4 pin USB Type B , 1 x USB 2.0 host - 4 pin USB Type A , 1 x LAN - RJ-45
- Consumables Included
- 1 x ink cartridge (black) - up to 3500 pages - HP 973A , 1 x ink cartridge (cyan) - HP 973A , 1 x ink cartridge (magenta) - HP 973A , 1 x ink cartridge (yellow) - HP 973A
- EN 61000-3-3:2008, EN 61000-3-2:2006+A1:2009+A2:2009, CISPR 24:2010, EN 55024:2010, EN 55022:2010 Class B
- Power Device
- Power supply - internal
- Voltage Required
- AC 120/230 V
- Frequency Required
- 50/60 Hz
- 70 Watt
- Power Consumption Stand by
- 9.5 Watt
- Power Consumption Sleep
- 4.5 Watt
- Software Included
- Drivers & Utilities, HP Web JetAdmin, HP Embedded Web Server, Printer utility for Mac, Bing Toolbar, HP Software Update
- OS Required
- System Requirements Details
- Windows 7/8/8.1/10 - HD 2 GB , Windows Vista (32/64 bits) - HD 2 GB , MacOS X 10.6 - HD 1 GB
Environmental Standards
- ENERGY STAR
- Limited warranty - 1 year - on-site , Technical support - phone consulting - 1 year
- -40 °C
- 60 °C
- 5 - 90%
- Sound Emission (Operating)
- 56 dBA
- 53 cm
- 40.7 cm
- 41.95 cm
- 16.8 kg
- Width (Shipping)
- 60 cm
- Depth (Shipping)
- 49.5 cm
- Height (Shipping)
- 52.9 cm
- Weight (Shipping)
- 20.75 kg
