HP PageWide Enterprise Colour MFP 586xh
Quicklinx: C15GWS00 Mfr#: G1W39A#B19
Ultimate value for today's enterprise – HP PageWide Technology delivers the fastest speeds and deepest security for the lowest total cost of ownership in its class. Power productivity with fast two-sided printing.
  • HP PageWide: Not Laser. Not inkjet. It's the best of both. A new alternative for business printing
    HP PageWide is designed with fewer moving parts. The stationary, page-width print bar enables unmatched speeds, improved reliability, and fewer replacement parts, all with professional print quality at the lowest total cost of operation in its class.
  • Low cost, affordable printing
    Print what you need affordably using low cost Original HP ink cartridges.
  • Fast FPOT from ready – as fast as 7.1 seconds
    This printer wakes up fast and prints your first page as quickly as 7.1 seconds.
  • Fast FPOT from ready-as fast as 7.1 seconds
  • HP Sure Start, intrusion detection, and whitelisting
    Rest assured that your fleet is covered, with award-winning HP Imaging and Printing Security Center.
HP PageWide Enterprise Color MFP 586dn - multifunction printer - colour
Multifunction printer
English, German, French, Italian, Spanish / Europe
Printing Technology
Page wide array (colour)
Inkjet Technology
4-ink
Monthly Duty Cycle (max)
80000 pages
Recommended Monthly Volume
2000 - 7500 pages
Max Copying Speed
Up to 50 ppm (mono) / up to 50 ppm (colour)
Max Copying Resolution
Up to 600 x 600 dpi (mono) / up to 600 x 600 dpi (colour)
Max Printing Speed
Max Printing Resolution
Up to 1200 x 1200 dpi (mono) / up to 2400 x 1200 dpi (colour)
Scanning
600 dpi
Display
8"
Original Size
76 x 127 mm (min) - A4 (210 x 297 mm), Legal (216 x 356 mm) (max)
Original Type
Sheets
Document Feeder Capacity
100 sheets
Media Size
76 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Envelopes, plain paper, cards, labels, recycled paper, greeting cards, photo paper, bond paper, heavy-weight paper, light-weight paper, glossy photo paper, matte photo paper, satin photo paper, tri-fold paper, soft gloss photo paper
Standard Media Capacity
550 sheets
Max Media Capacity
2050 sheets
Bypass Feeder Capacity
50 sheets
Output Trays Capacity
300 sheets
Automatic Duplexing
Yes (copying) Yes (printing) Yes (scanning)
Connection Availability
USB 2.0, Gigabit LAN, USB 2.0 host
AirPrint Enabled
Office Machine Features
Save to USB flash drive, scan to e-mail, save to network folder, HP High-Performance Secure Hard Disk, Mobile Printing
AC 120/230 V (50/60Hz)
53 cm x 56.4 cm x 52.9 cm
32.3 kg
Environmental Standards
ENERGY STAR Qualified, Blue Angel
Printing Technology
Page wide array - colour
80000 pages
2000 - 7500 pages
Display Diagonal Size
8"
Display Features
Touch screen
AirPrint Enabled
Standard Memory
2 GB
Max Supported Memory
2.75 GB
Hard Disk Drive
320 GB
Supported Flash Memory
USB flash drive
Copying
Max Copying Speed
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
9999
Automatic Duplexing
Copying Features
Collation copy
Printing
Max Printing Speed
Ink Palette Supported (Colours)
Cyan, magenta, yellow, black
4-ink
Printer Drivers / Emulations
PCL 6, PostScript 3, PCL 5c, PDF 1.7
Automatic Duplexing
First Print Out Time B/W
7.1 sec
First Print Out Time Colour
7.3 sec
Scanning
Scan Element
CIS
Automatic Duplexing
Optical Resolution
600 dpi
Grayscale Depth
8-bit
Colour Depth
24-bit
Document & Media Handling
Min Original Size
76 x 127 mm
Max Original Size
Original Type
Sheets
100 sheets
Min Media Size
76 x 127 mm
Max Media Size
A4/Legal
Min Media Weight
60 g/m²
Max Media Weight
300 g/m²
Supported Media Type
Supported Media Sizes
A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), 100 x 150 mm, 216 x 297 mm, JIS B5 (182 x 257 mm), 76 x 127 mm, 127 x 127 mm, 216 x 356 mm, JIS B6 (128 x 182 mm), 102 x 210 mm
Supported Envelope Sizes
International DL (110 x 220 mm), International C6 (114 x 162 mm), International C5 (162 x 229 mm), International B5 (176 x 250 mm)
550 sheets
Max Media Capacity
2050 sheets
50 sheets
300 sheets
ADF - 100 sheets size: 76 x 127 mm - 216 x 356 mm weight: 45 g/m² - 199 g/m² , Bypass tray - 50 sheets , Input tray - 500 sheets size: 76 x 127 mm - A4 (210 x 297 mm) weight: 60 g/m² - 300 g/m² , Output tray - 300 sheets
Speed Details
Scanning: up to 46 ppm - B/W , Scanning: up to 42 ppm - colour , Printing: up to 50 ppm - B/W (ISO) , Printing: up to 50 ppm - colour (ISO) , Printing: up to 25 ipm (A4) - colour duplex , Printing: up to 25 ipm (Letter A) - colour duplex , Copying: up to 50 ppm - B/W (ISO) , Copying: up to 50 ppm - colour (ISO) , Printing: up to 38 ipm (A4) - B/W duplex , Printing: up to 38 ipm (Letter A) - B/W duplex , Printing: up to 75 ppm (A4) - B/W draft , Printing: up to 75 ppm (A4) - colour draft , Printing: up to 75 ppm (Letter A) - B/W draft , Printing: up to 75 ppm (Letter A) - colour draft , Copying: up to 25 ppm (A4) - B/W duplex , Copying: up to 25 ppm (A4) - colour duplex , Copying: up to 25 ppm (Letter A) - B/W duplex , Copying: up to 25 ppm (Letter A) - colour duplex
1 x USB 2.0 - 4 pin USB Type B ¦ 1 x Gigabit LAN - RJ-45 ¦ 2 x USB 2.0 host - 4 pin USB Type A
Security Protocols & Features
Kerberos, LDAP, SSL, Apple Bonjour, TLS, IPsec, 802.1x, AES, EAP-TLS, PEAP
Operating System Support
MS Windows Server 2008 R2 x64 Edition, MS Windows Server 2012 x64 Edition, MS Windows XP 64-bit Edition SP3 or later, MS Windows Server 2003 SP2 or later, MS Windows Server 2008 (32/64-bits), MS Windows Vista (32/64 bits), MS Windows 7 (32/64 bits), MS Windows XP 32-bit Edition SP3 or later, Windows 8 (32/64-bits), Ubuntu Linux 10 - 14, Apple Mac OS X 10.9 or later
Software Included
Drivers & Utilities
62 watt
Power Consumption Standby
24 watt
Power Consumption Sleep
8.5 watt
Consumables Included
1 x ink cartridge (black) - up to 6000 pages , 1 x ink cartridge (cyan) - up to 6000 pages , 1 x ink cartridge (magenta) - up to 6000 pages , 1 x ink cartridge (yellow) - up to 6000 pages
EN 61000-3-3:2008, EN 61000-3-2:2006+A1:2009+A2:2009, EMC 2004/108/EC, EN 55024:2010, EN 55022:2010 Class A, CISPR 22:2008
ENERGY STAR Certified
Blue Angel Compliant
53 cm
56.4 cm
52.9 cm
32.3 kg
Shipping Weight
40.4 kg
15 °C
30 °C
20 - 60%
Ink (16)
C15G HP Everyday Semi-Gloss Photo Paper-100 sheet/A4/210 x 297 mm In Stock £16.36
C15G HP Advanced Glossy Photo Paper-25 sheet/13 x 18 cm borderless In Stock £5.18
C15G HP Advanced Glossy Photo Paper-25 sheet/A4/210 x 297 mm In Stock £9.93
C15G HP 981A Black original PageWide ink cartridge In Stock £65.00
C15G HP 981A Yellow original PageWide ink cartridge In Stock £94.98
C15G HP 981A Magenta original PageWide ink cartridge In Stock £94.98
C15G HP 981A Cyan original PageWide ink cartridge In Stock £94.98
C15G HP 981X High Yield Magenta Original PageWide In Stock £124.41
C15G HP INK CARTRIDGE 981Y CYAN In Stock £181.20
C15G HP INK CARTRIDGE 981Y MAGENTA In Stock £181.47
C15G HP INK CARTRIDGE 981Y YELLOW In Stock £181.47
C15G HP INK CARTRIDGE 981Y BLACK In Stock £139.98
C15G HP 981X High Yield Yellow Original PageWide In Stock £124.41
C15G HP Waste ink collector - for PageWide Enterprise Color MFP 586 In Stock £63.63
C15G HP 981X High Yield Cyan Original PageWide Cartridge In Stock £124.41
C15G HP 981X High Yield Black Original PageWide Cartridge In Stock £91.24
Other bundles (2)
C15G HP Premium Plus Glossy Photo Paper-20 sheet/A4/210 x 297 mm In Stock £14.34
C15G HP Foreign Interface Harness (FIH) In Stock £77.37
