Ultimate value for today's enterprise – HP PageWide Technology delivers the fastest speeds and deepest security for the lowest total cost of ownership in its class. Count on productivity and unparalleled multi-level security.
Dynamic security enabled printer
Certain HP printers are intended to work only with cartridges that have a new or reused HP chip or electronic circuitry. These printers use dynamic security measures to block cartridges using a non-HP chip or electronic circuitry. Periodic firmware updates will maintain the effectiveness of these measures and block cartridges that previously worked. Reused HP chips and electronic circuitry enable the use of reused, remanufactured, and refilled cartridges.
HP PageWide: Not Laser. Not inkjet. It's the best of both. A new alternative for business printing
HP PageWide is designed with fewer moving parts. The stationary, page-width print bar enables unmatched speeds, improved reliability, and fewer replacement parts, all with professional print quality at the lowest total cost of operation in its class. -
Low cost, affordable printing
Print what you need affordably using low cost Original HP ink cartridges. -
Fleet management, networking, and security features
Install, configure, troubleshoot, and upgrade your HP LaserJet printers on your schedule, thanks to HP's comprehensive suite of administrative tools. -
Professional-quality colour and black text for office use
Original HP ink and toner cartridges come backed by over 20 years of development, delivering the highest quality prints. -
Fast FPOT from ready – as fast as 7.1 seconds
This printer wakes up fast and prints your first page as quickly as 7.1 seconds.
- HP PageWide Enterprise Color 556xh - printer - colour - page wide array
- Printer Type
- Workgroup printer - page wide array - colour
- 28.8 kg
- Localisation
- English, German, French, Italian, Spanish / Europe
- Ink Palette Supported (Colours)
- 4-ink - cyan, magenta, yellow, black
- Media Size Class
- A4/Legal
- Max Media Size
- Legal (216 x 356 mm), A4 (210 x 297 mm)
- Min Media Size (Custom)
- 76 mm x 127 mm
- Max Media Size (Custom)
- 216 mm x 356 mm
- Print Speed
- Up to 75 ppm - black draft - A4 (210 x 297 mm) , Up to 50 ppm - B/W - A4 (210 x 297 mm) , Up to 75 ppm - colour draft - A4 (210 x 297 mm) , Up to 50 ppm - colour - A4 (210 x 297 mm) , Up to 38 ipm - B/W duplex - A4 (210 x 297 mm) , Up to 25 ppm - colour duplex - A4 (210 x 297 mm)
- Max Resolution (B&W)
- 1200 x 1200 dpi
- Max Resolution (Colour)
- 2400 x 1200 dpi
- Automatic Duplexing
- Interface
- USB 2.0, Gigabit LAN, Wi-Fi(n), NFC, USB 2.0 host
- AirPrint Enabled
- Preview Screen Size
- 4.3"
- Processor
- 1.2 GHz
- RAM Installed (Max)
- 1.25 GB (2.25 GB)
- Hard Drive
- 320 GB
- Language Simulation
- PCL 5, PostScript 3, PCL 6, PDF 1.4
- Media Type
- Envelopes, greeting cards, labels, plain paper, glossy photo paper, heavy-weight paper, matt photo paper, bond paper, recycled paper, tri-fold brochure paper, extra heavy-weight paper, light-weight paper, soft gloss photo paper, punched paper, satin photo paper
- Total Media Capacity
- 1050 sheets
- Media Handling
- 2x 500-sheet input trays, 50-sheet multipurpose tray
- Monthly Duty Cycle (max)
- 80000 pages
- Recommended Monthly Volume
- 2000 - 7500 pages
- Networking
- Print server
- Printer Features
- Hard Disk Drive Encryption
- System Requirements
- UNIX, Android, Ubuntu 10.04, Microsoft Windows XP (32/64 bits) SP3, Apple iOS, Ubuntu 11.10, Ubuntu 12.04, Red Hat Fedora 17, Ubuntu 12.10, Apple OS X 10.9 Mavericks, Red Hat Fedora 18, Linux Mint 13, Microsoft Windows RT 8.1, Ubuntu 13.04, Ubuntu 13.10, Ubuntu 14.04, Red Hat Fedora 19, Microsoft Windows RT 8, Linux Mint 14, Linux Mint 15, Apple MacOS X 10.10, Red Hat Fedora 20, Linux Mint 16, Linux Mint 17, BOSS GNU/Linux 3.0, BOSS GNU/Linux 5.0, Ubuntu 14.10, Debian Linux 6.0.x, Debian Linux 7.x, Apple MacOS X 10.11, SUSE Linux 12.2, SUSE Linux 12.3, SUSE Linux 13.1, Microsoft Windows Vista / 7 / 8 / 8.1 / 10 (32/64 bits), Windows 10 Mobile
- 1-year warranty
- 53 cm x 46.3 cm x 59.7 cm
- Printer Type
- Localisation
Printer
- Ink Cartridge Configuration
- 4 cartridges (1 each: cyan, magenta, yellow, black)
- Print Speed
- Built-in Devices
- Touch screen
- 4.3"
- Connectivity Technology
- Wireless
- Interface
- AirPrint Enabled
- 1200 x 1200 dpi
- 2400 x 1200 dpi
- First Print Out Time B/W
- 7.1 sec
- First Print Out Time Colour
- 7.3 sec
- Fonts Included
- 105 x TrueType ¦ 92 x PostScript 3
- Printer Features
- Media Handling
- Processor
- 1.2 GHz
RAM
- 1.25 GB / 2.25 GB (max)
Storage
- Hard Drive
- 320 GB
Media Handling
- Media Type
- Media Size Class
- A4/Legal
- Max Media Size
- 76 mm x 127 mm
- 216 mm x 356 mm
- Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), 216 x 297 mm, 101.6 x 152.4 mm, Statement (139.7 x 215.9 mm), 76 x 127 mm, 127 x 177.8 mm, Oficio (216 x 343 mm), 127 x 203.2 mm, 102 x 210 mm
- Envelope Sizes
- US No 10 (104.7 x 241.3 mm), Monarch (98.4 x 190.5 mm)
- 1050 sheets
- Media Feeders
- 1 x automatic - 50 sheets - Legal (216 x 356 mm) , 2 x automatic - 500 sheets - Legal (216 x 356 mm)
- Output Trays Capacity
- 300 sheets
Duty Cycle
- 80000 pages
- 2000 - 7500 pages
- Networking
- Print server
- Remote Management Protocol
- Telnet, SNMP 3, IPP, HTTP, HTTPS, TFTP, SLP
- SSL, Apple Bonjour, TLS, IPsec, 802.1x, AES-256, WPA2-Enterprise
- Connections
- 1 x USB 2.0 - 4 pin USB Type B , 2 x USB 2.0 host - 4 pin USB Type A , 1 x Gigabit LAN - RJ-45
- Consumables Included
- 1 x ink cartridge (black) , 1 x ink cartridge (cyan) , 1 x ink cartridge (magenta) , 1 x ink cartridge (yellow)
- 256-bit AES hardware encryption
- UL, cUL, GS, Directive 2006/95/EC, EN 62479:2010, IEC 60950-1:2005 + A1:2009 + A2:2013, IEC 62479:2010, EN 60950-1:2006+A11:2009+A1:2010+A12:2011+A2:2013
- Power Device
- Power supply - internal
- Frequency Required
- 50/60 Hz
- 52 Watt
- Power Consumption Stand by
- 12 Watt
- Power Consumption Sleep
- 6.3 Watt
- Software Included
- Drivers & Utilities, HP Web JetAdmin, HP Software Update
- OS Required
- System Requirements Details
- HD 200 MB , MacOS - HD 1 GB
Environmental Standards
- Blue Angel
- ENERGY STAR
- Limited warranty - 1 year - on-site - response time: next business day
- 15 °C
- 30 °C
- 20 - 80%
- Sound Emission (Operating)
- 55 dBA
- 53 cm
- 46.3 cm
- 59.7 cm
- 28.8 kg
- Width (Shipping)
- 60.3 cm
- Depth (Shipping)
- 56.5 cm
- Height (Shipping)
- 79.2 cm
- Weight (Shipping)
- 35.4 kg
Ink (16)
HP Everyday Semi-Gloss Photo Paper-100 sheet/A4/210 x 297 mm | In Stock | £15.49 |
HP Advanced Glossy Photo Paper-25 sheet/13 x 18 cm borderless | In Stock | £5.08 |
HP Advanced Glossy Photo Paper-25 sheet/A4/210 x 297 mm | In Stock | £9.73 |
HP 981A Black original PageWide ink cartridge | In Stock | £63.63 |
HP 981A Yellow original PageWide ink cartridge | In Stock | £93.00 |
HP 981A Magenta original PageWide ink cartridge | In Stock | £93.00 |
HP 981A Cyan original PageWide ink cartridge | In Stock | £93.00 |
HP 981X High Yield Magenta Original PageWide | In Stock | £121.82 |
HP INK CARTRIDGE 981Y CYAN | In Stock | £177.66 |
HP INK CARTRIDGE 981Y MAGENTA | In Stock | £177.66 |
HP INK CARTRIDGE 981Y YELLOW | In Stock | £177.66 |
HP INK CARTRIDGE 981Y BLACK | In Stock | £137.04 |
HP 981X High Yield Yellow Original PageWide | In Stock | £121.82 |
HP Waste ink collector - for PageWide Enterprise Color MFP 586 | In Stock | £45.50 |
HP 981X High Yield Cyan Original PageWide Cartridge | In Stock | £121.82 |
HP 981X High Yield Black Original PageWide Cartridge | In Stock | £89.33 |
Other bundles (2)
HP Premium Plus Glossy Photo Paper-20 sheet/A4/210 x 297 mm | In Stock | £14.04 |
HP Electronic HP Care Pack Next Business Day Hardware Support | In Stock | £350.84 |
