HP PageWide Enterprise Colour 556xh
Quicklinx: C15FWS00 Mfr#: G1W47A#B19
Ultimate value for today's enterprise – HP PageWide Technology delivers the fastest speeds and deepest security for the lowest total cost of ownership in its class. Count on productivity and unparalleled multi-level security.
Dynamic security enabled printer
Certain HP printers are intended to work only with cartridges that have a new or reused HP chip or electronic circuitry. These printers use dynamic security measures to block cartridges using a non-HP chip or electronic circuitry. Periodic firmware updates will maintain the effectiveness of these measures and block cartridges that previously worked. Reused HP chips and electronic circuitry enable the use of reused, remanufactured, and refilled cartridges.
  • HP PageWide: Not Laser. Not inkjet. It's the best of both. A new alternative for business printing
    HP PageWide is designed with fewer moving parts. The stationary, page-width print bar enables unmatched speeds, improved reliability, and fewer replacement parts, all with professional print quality at the lowest total cost of operation in its class.
  • Low cost, affordable printing
    Print what you need affordably using low cost Original HP ink cartridges.
  • Fleet management, networking, and security features
    Install, configure, troubleshoot, and upgrade your HP LaserJet printers on your schedule, thanks to HP's comprehensive suite of administrative tools.
  • Professional-quality colour and black text for office use
    Original HP ink and toner cartridges come backed by over 20 years of development, delivering the highest quality prints.
  • Fast FPOT from ready – as fast as 7.1 seconds
    This printer wakes up fast and prints your first page as quickly as 7.1 seconds.
HP PageWide Enterprise Color 556xh - printer - colour - page wide array
Printer Type
Workgroup printer - page wide array - colour
28.8 kg
English, German, French, Italian, Spanish / Europe
Ink Palette Supported (Colours)
4-ink - cyan, magenta, yellow, black
Media Size Class
A4/Legal
Max Media Size
Legal (216 x 356 mm), A4 (210 x 297 mm)
Min Media Size (Custom)
76 mm x 127 mm
Max Media Size (Custom)
216 mm x 356 mm
Print Speed
Up to 75 ppm - black draft - A4 (210 x 297 mm) , Up to 50 ppm - B/W - A4 (210 x 297 mm) , Up to 75 ppm - colour draft - A4 (210 x 297 mm) , Up to 50 ppm - colour - A4 (210 x 297 mm) , Up to 38 ipm - B/W duplex - A4 (210 x 297 mm) , Up to 25 ppm - colour duplex - A4 (210 x 297 mm)
Max Resolution (B&W)
1200 x 1200 dpi
Max Resolution (Colour)
2400 x 1200 dpi
Automatic Duplexing
USB 2.0, Gigabit LAN, Wi-Fi(n), NFC, USB 2.0 host
AirPrint Enabled
Preview Screen Size
4.3"
1.2 GHz
RAM Installed (Max)
1.25 GB (2.25 GB)
Hard Drive
320 GB
Language Simulation
PCL 5, PostScript 3, PCL 6, PDF 1.4
Media Type
Envelopes, greeting cards, labels, plain paper, glossy photo paper, heavy-weight paper, matt photo paper, bond paper, recycled paper, tri-fold brochure paper, extra heavy-weight paper, light-weight paper, soft gloss photo paper, punched paper, satin photo paper
Total Media Capacity
1050 sheets
Media Handling
2x 500-sheet input trays, 50-sheet multipurpose tray
Monthly Duty Cycle (max)
80000 pages
Recommended Monthly Volume
2000 - 7500 pages
Print server
Printer Features
Hard Disk Drive Encryption
UNIX, Android, Ubuntu 10.04, Microsoft Windows XP (32/64 bits) SP3, Apple iOS, Ubuntu 11.10, Ubuntu 12.04, Red Hat Fedora 17, Ubuntu 12.10, Apple OS X 10.9 Mavericks, Red Hat Fedora 18, Linux Mint 13, Microsoft Windows RT 8.1, Ubuntu 13.04, Ubuntu 13.10, Ubuntu 14.04, Red Hat Fedora 19, Microsoft Windows RT 8, Linux Mint 14, Linux Mint 15, Apple MacOS X 10.10, Red Hat Fedora 20, Linux Mint 16, Linux Mint 17, BOSS GNU/Linux 3.0, BOSS GNU/Linux 5.0, Ubuntu 14.10, Debian Linux 6.0.x, Debian Linux 7.x, Apple MacOS X 10.11, SUSE Linux 12.2, SUSE Linux 12.3, SUSE Linux 13.1, Microsoft Windows Vista / 7 / 8 / 8.1 / 10 (32/64 bits), Windows 10 Mobile
1-year warranty
53 cm x 46.3 cm x 59.7 cm
Printer Type
Printer
Ink Cartridge Configuration
4 cartridges (1 each: cyan, magenta, yellow, black)
Print Speed
Built-in Devices
Touch screen
Preview Screen Size
4.3"
Wireless
AirPrint Enabled
1200 x 1200 dpi
2400 x 1200 dpi
Automatic Duplexing
First Print Out Time B/W
7.1 sec
First Print Out Time Colour
7.3 sec
Language Simulation
Fonts Included
105 x TrueType , 92 x PostScript 3
Printer Features
Media Handling
1.2 GHz
RAM
RAM Installed (Max)
1.25 GB / 2.25 GB (max)
Storage
Hard Drive
320 GB
Media Handling
Media Type
Media Size Class
A4/Legal
Max Media Size
76 mm x 127 mm
216 mm x 356 mm
Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), 216 x 297 mm, 101.6 x 152.4 mm, Statement (139.7 x 215.9 mm), 76 x 127 mm, 127 x 177.8 mm, Oficio (216 x 343 mm), 127 x 203.2 mm, 102 x 210 mm
Envelope Sizes
US No 10 (104.7 x 241.3 mm), Monarch (98.4 x 190.5 mm)
1050 sheets
Media Feeders
1 x automatic - 50 sheets - Legal (216 x 356 mm) , 2 x automatic - 500 sheets - Legal (216 x 356 mm)
Output Trays Capacity
300 sheets
Duty Cycle
80000 pages
2000 - 7500 pages
Print server
Remote Management Protocol
Telnet, SNMP 3, IPP, HTTP, HTTPS, TFTP, SLP
Security Protocols & Features
SSL, Apple Bonjour, TLS, IPsec, 802.1x, AES-256, WPA2-Enterprise
1 x USB 2.0 - 4 pin USB Type B , 2 x USB 2.0 host - 4 pin USB Type A , 1 x Gigabit LAN - RJ-45
Consumables Included
1 x ink cartridge (black) , 1 x ink cartridge (cyan) , 1 x ink cartridge (magenta) , 1 x ink cartridge (yellow)
256-bit AES hardware encryption
UL, cUL, GS, Directive 2006/95/EC, EN 62479:2010, IEC 60950-1:2005 + A1:2009 + A2:2013, IEC 62479:2010, EN 60950-1:2006+A11:2009+A1:2010+A12:2011+A2:2013
Power supply - internal
Frequency Required
50/60 Hz
52 Watt
Power Consumption Stand by
12 Watt
Power Consumption Sleep
6.3 Watt
Software Included
Drivers & Utilities, HP Web JetAdmin, HP Software Update
System Requirements Details
HD 200 MB , MacOS - HD 1 GB
Environmental Standards
Blue Angel
ENERGY STAR
Limited warranty - 1 year - on-site - response time: next business day
15 °C
30 °C
20 - 80%
Sound Emission (Operating)
55 dBA
53 cm
46.3 cm
59.7 cm
28.8 kg
Width (Shipping)
60.3 cm
Depth (Shipping)
56.5 cm
Height (Shipping)
79.2 cm
Weight (Shipping)
35.4 kg
Ink (16)
C15F HP Everyday Semi-Gloss Photo Paper-100 sheet/A4/210 x 297 mm In Stock £15.71
C15F HP Advanced Glossy Photo Paper-25 sheet/13 x 18 cm borderless In Stock £5.16
C15F HP Advanced Glossy Photo Paper-25 sheet/A4/210 x 297 mm In Stock £9.87
C15F HP 981A Black original PageWide ink cartridge In Stock £64.58
C15F HP 981A Yellow original PageWide ink cartridge In Stock £94.37
C15F HP 981A Magenta original PageWide ink cartridge In Stock £94.37
C15F HP 981A Cyan original PageWide ink cartridge In Stock £94.37
C15F HP 981X High Yield Magenta Original PageWide In Stock £123.62
C15F HP INK CARTRIDGE 981Y CYAN In Stock £180.29
C15F HP INK CARTRIDGE 981Y MAGENTA In Stock £180.29
C15F HP INK CARTRIDGE 981Y YELLOW In Stock £180.29
C15F HP INK CARTRIDGE 981Y BLACK In Stock £139.08
C15F HP 981X High Yield Yellow Original PageWide In Stock £123.62
C15F HP Waste ink collector - for PageWide Enterprise Color MFP 586 In Stock £46.26
C15F HP 981X High Yield Cyan Original PageWide Cartridge In Stock £123.62
C15F HP 981X High Yield Black Original PageWide Cartridge In Stock £90.66
Other bundles (2)
C15F HP Premium Plus Glossy Photo Paper-20 sheet/A4/210 x 297 mm In Stock £14.24
C15F HP Electronic HP Care Pack Next Business Day Hardware Support In Stock £350.84
