Ultimate value for today's enterprise – HP PageWide Technology delivers the fastest speeds and deepest security for the lowest total cost of ownership in its class. Count on productivity and unparalleled multi-level security.
Dynamic security enabled printer
Certain HP printers are intended to work only with cartridges that have a new or reused HP chip or electronic circuitry. These printers use dynamic security measures to block cartridges using a non-HP chip or electronic circuitry. Periodic firmware updates will maintain the effectiveness of these measures and block cartridges that previously worked. Reused HP chips and electronic circuitry enable the use of reused, remanufactured, and refilled cartridges.
http://www.hp.com/learn/ds.
Professional colour, breakthrough total cost
Results you expect and lasting value – breakthrough total cost of ownership, the lowest in its class.Print professional-quality colour on a variety of papers – perfect for office use.Print up to 2.5x more pages and replace less often than standard cartridges with high-yield options.Spend less time and budget on scheduled maintenance with streamlined HP PageWide Technology. -
Enterprise productivity at unmatched speeds
Wait less and do more with best-in-class speeds – as fast as 75 ppm in colour and black-and-white.Grab the documents you need and go. This device prints first pages in as fast as 7.1 seconds.Optional NFC touch-to-print and encrypted wireless direct help keep mobile printing easy and protected.Equip employees to breeze through tasks with the adjustable 10.9 cm (4.3-inch) colour touchscreen. -
Unparalleled fleet security and management
Embedded features detect security threats and heal your printer, protecting it from boot up to shutdown.Help protect data on the printer and in transit, using more than 100 embedded security features.Help build business efficiency with HP Web Jetadmin, plus deploy over HP and 175 third-party solutions.Employ policy-based, fleet-wide protection features, using optional HP JetAdvantage Security Manager. -
Proven technology
Minimise downtime with HP PageWide Technology that delivers reliable performance businesses demand.Print up to 16,000 colour pages and up to 20,000 black-and-white pages – and go longer between replacements.Conserve with HP PageWide Technology – designed to use less energy than any printer in its class.Get professional-quality colour documents and the performance you expect with Original HP PageWide cartridges.
- HP PageWide Enterprise Color 556dn - printer - colour - page wide array
- Printer Type
- Workgroup printer - page wide array - colour
- 22.2 kg
- Localisation
- English, German, French, Italian, Spanish / Europe
- Ink Palette Supported (Colours)
- 4-ink - cyan, magenta, yellow, black
- Media Size Class
- A4/Legal
- Max Media Size
- Legal (216 x 356 mm), A4 (210 x 297 mm)
- Min Media Size (Custom)
- 76 mm x 127 mm
- Max Media Size (Custom)
- 216 mm x 356 mm
- Print Speed
- Up to 75 ppm - black draft - A4 (210 x 297 mm) , Up to 50 ppm - B/W - A4 (210 x 297 mm) , Up to 75 ppm - colour draft - A4 (210 x 297 mm) , Up to 50 ppm - colour - A4 (210 x 297 mm) , Up to 38 ipm - B/W duplex - A4 (210 x 297 mm) , Up to 25 ppm - colour duplex - A4 (210 x 297 mm)
- Max Resolution (B&W)
- 1200 x 1200 dpi
- Max Resolution (Colour)
- 2400 x 1200 dpi
- Automatic Duplexing
- Interface
- USB 2.0, Gigabit LAN, USB 2.0 host
- AirPrint Enabled
- Preview Screen Size
- 4.3"
- Processor
- 1.2 GHz
- RAM Installed (Max)
- 1280 MB ( 2304 MB )
- Language Simulation
- PostScript 3, PCL 6, PDF 1.4
- Media Type
- Envelopes, greeting cards, labels, plain paper, glossy photo paper, heavy-weight paper, matt photo paper, bond paper, recycled paper, satin photo paper, glossy brochure paper, tri-fold brochure paper, extra heavy-weight paper, light-weight paper, soft gloss photo paper, punched paper
- Total Media Capacity
- 550 sheets
- Media Handling
- 500-sheet input tray, 50-sheet multipurpose tray
- Monthly Duty Cycle (max)
- 80000 pages
- Recommended Monthly Volume
- 2000 - 7500 pages
- Networking
- Print server
- Printer Features
- HP ePrint, Mopria certified
- Power
- AC 120/230 V
- System Requirements
- UNIX, Android, Ubuntu 10.04, Microsoft Windows XP (32/64 bits) SP3, Apple iOS, Ubuntu 11.10, Ubuntu 12.04, Red Hat Fedora 17, Ubuntu 12.10, Apple MacOS X 10.9, Red Hat Fedora 18, Linux Mint 13, Microsoft Windows RT 8.1, Ubuntu 13.04, Ubuntu 13.10, Ubuntu 14.04, Red Hat Fedora 19, Microsoft Windows RT 8, Linux Mint 14, Linux Mint 15, Apple MacOS X 10.10, Red Hat Fedora 20, Linux Mint 16, Linux Mint 17, BOSS GNU/Linux 3.0, BOSS GNU/Linux 5.0, Ubuntu 14.10, Debian Linux 6.0.x, Debian Linux 7.x, Microsoft Vista / 7 / 8 / 8.1 / 10 (32/64 bits), Apple MacOS X 10.11, SUSE Linux 12.2, SUSE Linux 12.3, SUSE Linux 13.1, Windows 10 Mobile
- 1 year warranty
- 53 cm x 46.3 cm x 45.7 cm
- Printer Type
- Localisation
Printer
- Ink Cartridge Configuration
- 4 cartridges (1 each: cyan, magenta, yellow, black)
- Print Speed
- Built-in Devices
- Touch screen
- 4.3"
- Connectivity Technology
- Wired
- Interface
- AirPrint Enabled
- 1200 x 1200 dpi
- 2400 x 1200 dpi
- First Print Out Time B/W
- 7.1 sec
- First Print Out Time Colour
- 7.3 sec
- Fonts Included
- 105 x TrueType , 92 x PostScript 3
- Printer Features
- Media Handling
- Processor
- 1.2 GHz
RAM
- 1280 MB / 2304 MB (max)
Media Handling
- Media Type
- Envelopes, greeting cards, labels, plain paper, heavy-weight paper, matt photo paper, bond paper, recycled paper, satin photo paper, glossy brochure paper, tri-fold brochure paper, extra heavy-weight paper, light-weight paper, soft gloss photo paper, punched paper
- Media Size Class
- A4/Legal
- Max Media Size
- 76 mm x 127 mm
- 216 mm x 356 mm
- Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), 216 x 297 mm, 101.6 x 152.4 mm, Statement (139.7 x 215.9 mm), 76 x 127 mm, 127 x 177.8 mm, Oficio (216 x 343 mm), 127 x 203.2 mm, 102 x 210 mm
- Envelope Sizes
- US No 10 (104.7 x 241.3 mm), Monarch (98.4 x 190.5 mm)
- 550 sheets
- Media Feeders
- 1 x automatic - 50 sheets - Legal (216 x 356 mm) , 1 x automatic - 500 sheets - Legal (216 x 356 mm)
- Output Trays Capacity
- 300 sheets
Duty Cycle
- 80000 pages
- 2000 - 7500 pages
- Networking
- Print server
- Remote Management Protocol
- Telnet, SNMP 3, IPP, HTTP, HTTPS, TFTP, SLP
- SSL, Apple Bonjour, TLS, IPsec, 802.1x, WPA2-Enterprise
- Connections
- 1 x USB 2.0 - 4 pin USB Type B , 2 x USB 2.0 host - 4 pin USB Type A , 1 x Gigabit LAN - RJ-45
- Consumables Included
- 1 x ink cartridge ( black ) , 1 x ink cartridge ( cyan ) , 1 x ink cartridge ( magenta ) , 1 x ink cartridge ( yellow )
- AirPrint, Google Cloud Print 2.0
- UL, cUL, GS, Directive 2006/95/EC, EN 62479:2010, IEC 60950-1:2005 + A1:2009 + A2:2013, IEC 62479:2010, EN 60950-1:2006+A11:2009+A1:2010+A12:2011+A2:2013
- Power Device
- Power supply - internal
- Voltage Required
- AC 120/230 V
- Frequency Required
- 50/60 Hz
- 52 Watt
- Power Consumption Stand by
- 12 Watt
- Power Consumption Sleep
- 6.3 Watt
- Software Included
- Drivers & Utilities, HP Web JetAdmin, HP Software Update
- OS Required
- System Requirements Details
- HD 200 MB , MacOS - HD 1 GB
Environmental Standards
- Blue Angel
- ENERGY STAR
- Limited warranty - 1 year - on-site - response time: next business day
- 15 °C
- 30 °C
- 20 - 80%
- Sound Emission (Operating)
- 55 dBA
- 53 cm
- 46.3 cm
- 45.7 cm
- 22.2 kg
- Width (Shipping)
- 60.3 cm
- Depth (Shipping)
- 56.5 cm
- Height (Shipping)
- 55.3 cm
- Weight (Shipping)
- 27.5 kg
Ink (16)
HP Everyday Semi-Gloss Photo Paper-100 sheet/A4/210 x 297 mm | In Stock | £12.83 |
HP Advanced Glossy Photo Paper-25 sheet/A4/210 x 297 mm | In Stock | £9.21 |
HP 981A Black original PageWide ink cartridge | In Stock | £57.51 |
HP 981A Yellow original PageWide ink cartridge | In Stock | £84.06 |
HP 981A Magenta original PageWide ink cartridge | In Stock | £84.06 |
HP 981A Cyan original PageWide ink cartridge | In Stock | £84.06 |
HP 981X High Yield Magenta Original PageWide | In Stock | £110.11 |
HP INK CARTRIDGE 981Y CYAN | In Stock | £97.59 |
HP INK CARTRIDGE 981Y MAGENTA | In Stock | £155.88 |
HP INK CARTRIDGE 981Y YELLOW | In Stock | £155.88 |
HP INK CARTRIDGE 981Y BLACK | In Stock | £123.89 |
HP 981X High Yield Yellow Original PageWide | In Stock | £110.11 |
HP Iron-on Transfers-12 sheet/A4/210 x 297 mm | In Stock | £13.04 |
HP Waste ink collector - for PageWide Enterprise Color MFP 586 | In Stock | £45.27 |
HP 981X High Yield Cyan Original PageWide Cartridge | In Stock | £110.11 |
HP 981X High Yield Black Original PageWide Cartridge | In Stock | £80.74 |
Other bundles (5)
HP Care Pack Installation/Configuration 1 Incident On-Site | In Stock | £282.81 |
HP Premium Plus Glossy Photo Paper-20 sheet/A4/210 x 297 mm | In Stock | £13.27 |
HP Foreign Interface Harness (FIH) | In Stock | £77.37 |
HP Paper Feeder And Stand Media Tray Feeder 500 Sheets | In Stock | £775.78 |
HP Electronic HP Care Pack Next Business Day Hardware Support | In Stock | £349.09 |
