HP PageWide Colour MFP 774dn Multifunction Printer
Quicklinx: FVLSWS00 Mfr#: 4PZ43A#B19
Business moves fast, and slowing down means falling behind. It's why HP built the next generation of HP PageWide MFPs – to power productivity with a smart, efficient design that delivers the lowest colour cost, maximum uptime, and strong security.
Dynamic security enabled printer
Certain HP printers are intended to work only with cartridges that have a new or reused HP chip or electronic circuitry. These printers use dynamic security measures to block cartridges using a non-HP chip or electronic circuitry. Periodic firmware updates will maintain the effectiveness of these measures and block cartridges that previously worked. Reused HP chips and electronic circuitry enable the use of reused, remanufactured, and refilled cartridges.
http://www.hp.com/learn/ds.
  • Low cost for color
    Get the quality you expect with HP PageWide Technology that delivers on of the lowest cost per color page.
  • Minimal interruptions, maximum uptime
    Minimize interruptions with an HP PageWide MFP designed for the least maintenance in its class. Print Microsoft Word and PowerPoint files with a USB port that quickly recognizes, formats, and prints.
  • Strong security designed to detect and stop attacks
    A suite of embedded security features help protect this MFP from being an entry point for attacks. Help ensure the security of confidential information. Enter a PIN at the device to retrieve your print job. Easily set configuration policies and automatically validate settings for every HP printer in your fleet. Thwart potential attacks and take immediate action with instant notification of security issues.
  • Designed with the environment in mind
    Conserve resources with HP PageWide - designed to use less energy than any laser MFP in its class. This MFP meets rigorous standards for ISO class 5 cleanrooms - perfect for sensitive environments. Help reduce your impact. Count on easy cartridge recycling at no charge through HP Planet Partners. Keep noise to a minimum with an MFP designed to be quiet. Place it near people without disrupting work.
HP PageWide Color MFP 774dn - multifunction printer - colour
Multifunction printer
English, German, French, Italian, Spanish / Europe
Printing Technology
Page wide array (colour)
Inkjet Technology
HP PageWide - 4-ink
Monthly Duty Cycle (max)
75000 pages
Recommended Monthly Volume
2500 - 15000 pages
Max Copying Speed
Up to 35 ppm (mono) / up to 35 ppm (colour)
Max Copying Resolution
Up to 600 dpi (mono) / up to 600 dpi (colour)
Max Printing Speed
Max Printing Resolution
Up to 1200 x 1200 dpi (mono) / up to 2400 x 1200 dpi (colour)
Scanning
600 dpi
Display
4.3"
Original Size
101 x 152 mm (min) - 297 x 864 mm (max)
Original Type
Sheets
Document Feeder Capacity
100 sheets
Media Size
99 x 148 mm (min) - A3 (297 x 420 mm)/ANSI B (Ledger) (279 x 432 mm) (max)
Media Type
Envelopes, plain paper, cards, labels, recycled paper, photo paper, bond paper, heavy-weight paper, card stock, extra heavy-weight paper, light-weight paper, punched paper, preprinted paper
Standard Media Capacity
650 sheets
Bypass Feeder Capacity
100 sheets
Output Trays Capacity
500 sheets
Automatic Duplexing
Yes (copying) Yes (printing) Yes (scanning)
Connection Availability
USB 2.0, Gigabit LAN, USB 2.0 host
AirPrint Enabled
Office Machine Features
Print from USB flash drive, save to USB flash drive, scan to e-mail, save to network folder, automatic paper sensor, HP EasyColor, Mobile Printing, scan to FTP, scan to SharePoint, security lock slot
AC 120/230 V (50/60Hz)
60.4 cm x 60.4 cm x 66.4 cm
64.8 kg
Environmental Standards
ENERGY STAR Qualified, Blue Angel
Printer Fonts
TrueType x 105 , PostScript 3 x 92
Printing Technology
Page wide array - colour
75000 pages
2500 - 15000 pages
Display Diagonal Size
4.3"
Display Colour Support
Display Features
Touch screen
AirPrint Enabled
Standard Memory
2.75 GB
Max Supported Memory
3.5 GB
Copying
Max Copying Speed
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
9999
Automatic Duplexing
Copying Features
Booklet creation, ID Card Copy, collation copy, Job Build, edge-to-edge
Printing
Inkjet Technology
HP PageWide
Nozzle Configuration
59136 nozzles
Max Printing Speed
Ink Cartridge Configuration
4 cartridges (1 each: cyan, magenta, yellow, black)
Ink Palette Supported (Colours)
Cyan, magenta, yellow, black
4-ink
Printer Drivers / Emulations
PCL 6, PostScript 3, PCL 6 (XL), PDF, PCL 5, PCLm, JPEG, PJL
Automatic Duplexing
First Print Out Time B/W
8.2 sec
First Print Out Time Colour
8.2 sec
Scanning
Scan Element
CIS
Automatic Duplexing
Optical Resolution
600 dpi
Grayscale Depth
8-bit
Colour Depth
24-bit
Document & Media Handling
Min Original Size
101 x 152 mm
Max Original Size
297 x 864 mm
Supported Original Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A3 (297 x 420 mm), A6 (105 x 148 mm), JIS B5 (182 x 257 mm), JIS B4 (257 x 364 mm), SRA4 (225 x 320 mm), Statement (139.7 x 215.9 mm), Oficio (216 x 343 mm), 215.9 x 330.2 mm, JIS B6 (128 x 182 mm), RA4 (215 x 305 mm)
Original Type
Sheets
100 sheets
Min Media Size
99 x 148 mm
Max Media Size
A3/Ledger
Min Media Weight
60 g/m²
Max Media Weight
300 g/m²
Min Media Weight (lb)
16 lbs
Max Media Weight (lb)
80 lbs
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), ANSI B (Ledger) (279 x 432 mm), Tabloid Extra (305 x 457 mm), SRA4 (225 x 320 mm), Statement (139.7 x 215.9 mm), RA3 (305 x 430 mm), 99 x 148 mm, Oficio (216 x 343 mm), A3 Plus (305 x 457 mm), RA4 (215 x 305 mm)
Supported Envelope Sizes
US No 10 (104.7 x 241.3 mm), International DL (110 x 220 mm), International C6 (114 x 162 mm), International C5 (162 x 229 mm), International B5 (176 x 250 mm), Monarch (98.4 x 190.5 mm), US No 9 (98.6 x 225.6 mm), Japanese Chou No 3 (120 x 235 mm)
650 sheets
100 sheets
500 sheets
ADF - 100 sheets size: 101 x 152 mm - 297 x 864 mm weight: 60 g/m² - 300 g/m²; weight (lbs): 16 lbs - 80 lbs , Input tray - 550 sheets size: A5 (148 x 210 mm) - A3/Ledger (297 x 432 mm) weight: 60 g/m² - 300 g/m²; weight (lbs): 16 lbs - 80 lbs , Output tray - 500 sheets , Multi-purpose tray - 100 sheets size: 99 x 148 mm - Tabloid Extra (305 x 457 mm) weight: 60 g/m² - 300 g/m²; weight (lbs): 16 lbs - 80 lbs
Speed Details
Scanning: up to 60 ipm (Letter A) - B/W normal , Scanning: up to 60 ipm (A4) - B/W normal , Scanning: up to 60 ipm (A4) - colour normal , Scanning: up to 60 ipm (Letter A) - colour normal , Scanning: up to 120 ipm (A4) - B/W duplex normal , Scanning: up to 120 ipm (A4) - colour duplex normal , Scanning: up to 120 ipm (Letter A) - B/W duplex normal , Scanning: up to 120 ipm (Letter A) - colour duplex normal , Printing: up to 55 ppm (Letter A) - B/W draft , Printing: up to 55 ppm (Letter A) - colour draft , Printing: up to 55 ppm 4 sec - B/W draft , Printing: up to 55 ppm (A4) - colour draft , Printing: up to 35 ppm - B/W (ISO) , Printing: up to 35 ppm - B/W (ISO) , Copying: up to 35 ppm - B/W (ISO) , Copying: up to 35 ppm - colour (ISO)
1 x Gigabit LAN - RJ-45 , 1 x USB 2.0 - 4 pin USB Type B , 2 x USB 2.0 host - 4 pin USB Type A
Security Protocols & Features
Kerberos, SSL, TLS, EAP-TLS, PEAP
Operating System Support
UNIX, Red Hat Enterprise Linux 6, Ubuntu Linux 12.04, MS Windows 7 (32/64 bits), Apple Mac OS X 10.10, MS Windows XP 32-bit Edition SP3 or later, Windows 8 (32/64-bits), Windows 8.1 (32/64-bits), Windows 10 (32/64-bits), Boss 5.0, Debian Linux 7.x, Linux Mint 17, Ubuntu Linux 14.04, Red Hat Enterprise Linux 7, Apple Mac OS X 10.11, MS Windows Vista 32-bit Edition, Debian Linux 8.0, macOS 10.12, Linux Mint 17.1, Linux Mint 17.2, Linux Mint 18, Linux Mint 17.3, SuSe Linux 13.2, SuSe Linux 42.1, Ubuntu Linux 15.10, Ubuntu Linux 16.04, Ubuntu Linux 16.10, Debian Linux 8.1, Debian Linux 8.2, Debian Linux 8.3, Debian Linux 8.4, Debian Linux 8.5, Debian Linux 8.6, Fedora Linux 22, Fedora Linux 23, Fedora Linux 24
Software Included
HP Web Jetadmin
525 Watt
Power Consumption Standby
30 Watt
Power Consumption Sleep
1.22 Watt
First Copy Out Time B/W
10.5 sec
First Copy Out Time Colour
10.3 sec
FCC Class A certified, BSMI, PSB, FCC CFR47 Part 15, KCC, EN 62479:2010, IEC 62471:2006, EN 62471:2008, EN 61000-3-3:2013, EN 55024:2010, CISPR 22:2008, EN 61000-3-2:2014, IEC 60950-1:2005 + A1:2009 + A2:2013, IEC 62479:2010, AS/NZS 60950-1:2011, ANSI/UL 60950-1 Second Edition, LVD 2014/35/EU, ICES-003 issue 6 Class A, CISPR 32:2012 Class A, EN 55032:2012 Class A, CAN/CSA-C22.2 No. 60950-1-07+A1:2011, EN 60950-1:2006+A11:2009+A1:2010+A12:2011+A2:2013+AC:2011
Security Slot Type
Kensington security slot
ENERGY STAR Certified
Blue Angel Compliant
60.4 cm
60.4 cm
66.4 cm
64.8 kg
Shipping Width
79 cm
Shipping Depth
76 cm
Shipping Height
94.1 cm
Shipping Weight
87.5 kg
Sound Emission
53 dBA (operating)
15 °C
30 °C
10 - 80%
Ink (4)
FVLS HP 991X High Yield Black Original PageWide Cartridge In Stock £183.81
FVLS HP 991X High Yield Cyan Original PageWide Cartridge In Stock £200.51
FVLS HP 991X High Yield Yellow Original PageWide Cartridge In Stock £200.51
FVLS HP 991X High Yield Magenta Original PageWide Cartridge In Stock £200.51
Other bundles (1)
FVLS HP Care Pack Next Business Day Hardware Support with Defective Media Retention - 3 years - on-site In Stock £1,025.64
