Business moves fast, and slowing down means falling behind. It's why HP built the next generation of HP PageWide MFPs – to power productivity with a smart, efficient design that delivers the lowest colour cost, maximum uptime, and strong security.
Dynamic security enabled printer
Certain HP printers are intended to work only with cartridges that have a new or reused HP chip or electronic circuitry. These printers use dynamic security measures to block cartridges using a non-HP chip or electronic circuitry. Periodic firmware updates will maintain the effectiveness of these measures and block cartridges that previously worked. Reused HP chips and electronic circuitry enable the use of reused, remanufactured, and refilled cartridges.
http://www.hp.com/learn/ds.
Low cost for color
Get the quality you expect with HP PageWide Technology that delivers on of the lowest cost per color page. -
Minimal interruptions, maximum uptime
Minimize interruptions with an HP PageWide MFP designed for the least maintenance in its class. Print Microsoft Word and PowerPoint files with a USB port that quickly recognizes, formats, and prints. -
Strong security designed to detect and stop attacks
A suite of embedded security features help protect this MFP from being an entry point for attacks. Help ensure the security of confidential information. Enter a PIN at the device to retrieve your print job. Easily set configuration policies and automatically validate settings for every HP printer in your fleet. Thwart potential attacks and take immediate action with instant notification of security issues. -
Designed with the environment in mind
Conserve resources with HP PageWide - designed to use less energy than any laser MFP in its class. This MFP meets rigorous standards for ISO class 5 cleanrooms - perfect for sensitive environments. Help reduce your impact. Count on easy cartridge recycling at no charge through HP Planet Partners. Keep noise to a minimum with an MFP designed to be quiet. Place it near people without disrupting work.
- HP PageWide Color MFP 774dn - multifunction printer - colour
- Multifunction printer
- Localisation
- English, German, French, Italian, Spanish / Europe
- Printing Technology
- Page wide array (colour)
- Inkjet Technology
- HP PageWide - 4-ink
- Monthly Duty Cycle (max)
- 75000 pages
- Recommended Monthly Volume
- 2500 - 15000 pages
- Max Copying Speed
- Up to 35 ppm (mono) / up to 35 ppm (colour)
- Max Copying Resolution
- Up to 600 dpi (mono) / up to 600 dpi (colour)
- Max Printing Speed
- Max Printing Resolution
- Up to 1200 x 1200 dpi (mono) / up to 2400 x 1200 dpi (colour)
- Scanning
- 600 dpi
- Display
- 4.3"
- Original Size
- 101 x 152 mm (min) - 297 x 864 mm (max)
- Original Type
- Sheets
- Document Feeder Capacity
- 100 sheets
- Media Size
- 99 x 148 mm (min) - A3 (297 x 420 mm)/ANSI B (Ledger) (279 x 432 mm) (max)
- Media Type
- Envelopes, plain paper, cards, labels, recycled paper, photo paper, bond paper, heavy-weight paper, card stock, extra heavy-weight paper, light-weight paper, punched paper, preprinted paper
- Standard Media Capacity
- 650 sheets
- Bypass Feeder Capacity
- 100 sheets
- Output Trays Capacity
- 500 sheets
- Automatic Duplexing
- Yes (copying) Yes (printing) Yes (scanning)
- Connection Availability
- Interface
- USB 2.0, Gigabit LAN, USB 2.0 host
- Office Machine Features
- Print from USB flash drive, save to USB flash drive, scan to e-mail, save to network folder, automatic paper sensor, HP EasyColor, Mobile Printing, scan to FTP, scan to SharePoint, security lock slot
- Power
- AC 120/230 V (50/60Hz)
- 60.4 cm x 60.4 cm x 66.4 cm
- 64.8 kg
- Environmental Standards
- ENERGY STAR Qualified, Blue Angel
- Printer Fonts
- TrueType x 105 , PostScript 3 x 92
- Page wide array - colour
- 75000 pages
- Display Diagonal Size
- 4.3"
- Display Colour Support
- Display Features
- Touch screen
- Interface
- Localisation
- Standard Memory
- 2.75 GB
- Max Supported Memory
- 3.5 GB
Copying
- Max Copying Speed
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 9999
- Copying Features
- Booklet creation, ID Card Copy, collation copy, Job Build, edge-to-edge
Printing
- Inkjet Technology
- HP PageWide
- Nozzle Configuration
- 59136 nozzles
- Ink Cartridge Configuration
- 4 cartridges (1 each: cyan, magenta, yellow, black)
- Ink Palette Supported (Colours)
- Cyan, magenta, yellow, black
- 4-ink
- Printer Drivers / Emulations
- PCL 6, PostScript 3, PCL 6 (XL), PDF, PCL 5, PCLm, JPEG, PJL
- First Print Out Time B/W
- 8.2 sec
- First Print Out Time Colour
- 8.2 sec
Scanning
- Scan Element
- CIS
- Optical Resolution
- 600 dpi
- Grayscale Depth
- 8-bit
- Colour Depth
- 24-bit
Document & Media Handling
- Min Original Size
- 101 x 152 mm
- Max Original Size
- 297 x 864 mm
- Supported Original Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A3 (297 x 420 mm), A6 (105 x 148 mm), JIS B5 (182 x 257 mm), JIS B4 (257 x 364 mm), SRA4 (225 x 320 mm), Statement (139.7 x 215.9 mm), Oficio (216 x 343 mm), 215.9 x 330.2 mm, JIS B6 (128 x 182 mm), RA4 (215 x 305 mm)
- Original Type
- Sheets
- 100 sheets
- Min Media Size
- 99 x 148 mm
- Max Media Size
- A3/Ledger
- Min Media Weight
- 60 g/m²
- Max Media Weight
- 300 g/m²
- Min Media Weight (lb)
- 16 lbs
- Max Media Weight (lb)
- 80 lbs
- Supported Media Type
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), ANSI B (Ledger) (279 x 432 mm), Tabloid Extra (305 x 457 mm), SRA4 (225 x 320 mm), Statement (139.7 x 215.9 mm), RA3 (305 x 430 mm), 99 x 148 mm, Oficio (216 x 343 mm), A3 Plus (305 x 457 mm), RA4 (215 x 305 mm)
- Supported Envelope Sizes
- US No 10 (104.7 x 241.3 mm), International DL (110 x 220 mm), International C6 (114 x 162 mm), International C5 (162 x 229 mm), International B5 (176 x 250 mm), Monarch (98.4 x 190.5 mm), US No 9 (98.6 x 225.6 mm), Japanese Chou No 3 (120 x 235 mm)
- 650 sheets
- 100 sheets
- 500 sheets
- ADF - 100 sheets size: 101 x 152 mm - 297 x 864 mm weight: 60 g/m² - 300 g/m²; weight (lbs): 16 lbs - 80 lbs , Input tray - 550 sheets size: A5 (148 x 210 mm) - A3/Ledger (297 x 432 mm) weight: 60 g/m² - 300 g/m²; weight (lbs): 16 lbs - 80 lbs , Output tray - 500 sheets , Multi-purpose tray - 100 sheets size: 99 x 148 mm - Tabloid Extra (305 x 457 mm) weight: 60 g/m² - 300 g/m²; weight (lbs): 16 lbs - 80 lbs
- Speed Details
- Scanning: up to 60 ipm (Letter A) - B/W normal , Scanning: up to 60 ipm (A4) - B/W normal , Scanning: up to 60 ipm (A4) - colour normal , Scanning: up to 60 ipm (Letter A) - colour normal , Scanning: up to 120 ipm (A4) - B/W duplex normal , Scanning: up to 120 ipm (A4) - colour duplex normal , Scanning: up to 120 ipm (Letter A) - B/W duplex normal , Scanning: up to 120 ipm (Letter A) - colour duplex normal , Printing: up to 55 ppm (Letter A) - B/W draft , Printing: up to 55 ppm (Letter A) - colour draft , Printing: up to 55 ppm 4 sec - B/W draft , Printing: up to 55 ppm (A4) - colour draft , Printing: up to 35 ppm - B/W (ISO) , Printing: up to 35 ppm - B/W (ISO) , Copying: up to 35 ppm - B/W (ISO) , Copying: up to 35 ppm - colour (ISO)
- 1 x Gigabit LAN - RJ-45 , 1 x USB 2.0 - 4 pin USB Type B , 2 x USB 2.0 host - 4 pin USB Type A
- Kerberos, SSL, TLS, EAP-TLS, PEAP
- Operating System Support
- UNIX, Red Hat Enterprise Linux 6, Ubuntu Linux 12.04, MS Windows 7 (32/64 bits), Apple Mac OS X 10.10, MS Windows XP 32-bit Edition SP3 or later, Windows 8 (32/64-bits), Windows 8.1 (32/64-bits), Windows 10 (32/64-bits), Boss 5.0, Debian Linux 7.x, Linux Mint 17, Ubuntu Linux 14.04, Red Hat Enterprise Linux 7, Apple Mac OS X 10.11, MS Windows Vista 32-bit Edition, Debian Linux 8.0, macOS 10.12, Linux Mint 17.1, Linux Mint 17.2, Linux Mint 18, Linux Mint 17.3, SuSe Linux 13.2, SuSe Linux 42.1, Ubuntu Linux 15.10, Ubuntu Linux 16.04, Ubuntu Linux 16.10, Debian Linux 8.1, Debian Linux 8.2, Debian Linux 8.3, Debian Linux 8.4, Debian Linux 8.5, Debian Linux 8.6, Fedora Linux 22, Fedora Linux 23, Fedora Linux 24
- Software Included
- HP Web Jetadmin
- Voltage Required
- 525 Watt
- Power Consumption Standby
- 30 Watt
- Power Consumption Sleep
- 1.22 Watt
- First Copy Out Time B/W
- 10.5 sec
- First Copy Out Time Colour
- 10.3 sec
- FCC Class A certified, BSMI, PSB, FCC CFR47 Part 15, KCC, EN 62479:2010, IEC 62471:2006, EN 62471:2008, EN 61000-3-3:2013, EN 55024:2010, CISPR 22:2008, EN 61000-3-2:2014, IEC 60950-1:2005 + A1:2009 + A2:2013, IEC 62479:2010, AS/NZS 60950-1:2011, ANSI/UL 60950-1 Second Edition, LVD 2014/35/EU, ICES-003 issue 6 Class A, CISPR 32:2012 Class A, EN 55032:2012 Class A, CAN/CSA-C22.2 No. 60950-1-07+A1:2011, EN 60950-1:2006+A11:2009+A1:2010+A12:2011+A2:2013+AC:2011
- Security Slot Type
- Kensington security slot
- ENERGY STAR Certified
- Blue Angel Compliant
- 60.4 cm
- 60.4 cm
- 66.4 cm
- 64.8 kg
- Shipping Width
- 79 cm
- Shipping Depth
- 76 cm
- Shipping Height
- 94.1 cm
- Shipping Weight
- 87.5 kg
- Sound Emission
- 53 dBA (operating)
- 15 °C
- 30 °C
- 10 - 80%
Ink (4)
HP 991X High Yield Black Original PageWide Cartridge | In Stock | £176.81 |
HP 991X High Yield Cyan Original PageWide Cartridge | In Stock | £192.89 |
HP 991X High Yield Yellow Original PageWide Cartridge | In Stock | £192.89 |
HP 991X High Yield Magenta Original PageWide Cartridge | In Stock | £192.89 |
Other bundles (2)
HP Foreign Interface Harness (FIH) | In Stock | £77.37 |
HP Care Pack Next Business Day Hardware Support with Defective Media Retention - 3 years - on-site | In Stock | £1,023.60 |
