Modern business demands forward-thinking technology – it's why HP engineered the next generation of HP PageWide Enterprise to deliver a competitive edge from every angle: lowest colour cost, maximum uptime and the industry's strongest security.
Dynamic security enabled printer. Only intended to be used with cartridges using an HP original chip. Cartridges using a non-HP chip may not work, and those that work today may not work in the future.
Breakthrough value – the lowest cost per colour page
Get the quality you expect with HP PageWide Technology that delivers the lowest cost per colour page. -
High-yield cartridges for an even better value
Print more pages and replace cartridges less often with optional high-yield cartridges.
- HP PageWide Enterprise Color MFP 780dn - multifunction printer - colour
- Multifunction printer
- Fax Type
- Plain paper
- Localisation
- English, German, French, Italian, Spanish / Europe
- Printing Technology
- Page wide array (colour)
- Inkjet Technology
- HP PageWide - 4-ink
- Monthly Duty Cycle (max)
- 100000 pages
- Recommended Monthly Volume
- 2500 - 20000 pages
- Max Copying Speed
- Up to 45 ppm (mono) / up to 45 ppm (colour)
- Max Copying Resolution
- Up to 600 x 600 dpi (mono) / up to 600 x 600 dpi (colour)
- Max Printing Speed
- Up to 65 ppm (mono) / up to 65 ppm (colour)
- Max Printing Resolution
- Up to 1200 x 1200 dpi (mono) / up to 2400 x 1200 dpi (colour)
- Max Fax Transmission Speed
- 33.6 Kbps
- Fax Resolutions
- 300 x 300 dpi, 204 x 98 dpi, 204 x 196 dpi
- Scanning
- 600 dpi
- Display
- 8"
- Original Size
- 100 x 148 mm (min) - 297 x 432 mm (max)
- Original Type
- Sheets
- Document Feeder Capacity
- 100 sheets
- Media Size
- 100 x 148 mm (min) - 297 x 432 mm, RA3 (305 x 430 mm) (max)
- Media Type
- Envelopes, plain paper, cards, labels, photo paper, glossy paper
- Standard Media Capacity
- 650 sheets
- Max Media Capacity
- 4650 sheets
- Bypass Feeder Capacity
- 60 sheets
- Output Trays Capacity
- 500 sheets
- Automatic Duplexing
- Yes (copying) Yes (printing) Yes (scanning)
- Connection Availability
- Interface
- USB 2.0, Gigabit LAN, USB 2.0 host
- AirPrint Enabled
- Office Machine Features
- Save to USB flash drive, scan to e-mail, Hardware Integration Pocket, save to network folder, HP EasyColor, HP Auto-On/Auto-Off Technology, Open Extensibility Platform (OXP)
- Power
- AC 120/230 V (50/60Hz)
- 81.3 cm x 59.1 cm x 45.8 cm
- 68 kg
- Environmental Standards
- ENERGY STAR Qualified
- 1-year warranty
- Fax Type
- Plain paper
- Page wide array - colour
- 100000 pages
- Display Diagonal Size
- 8"
- Display Features
- Touch screen
- Interface
- AirPrint Enabled
- Localisation
- Standard Memory
- 3.5 GB
- Max Supported Memory
- 4.5 GB
Copying
- Max Copying Speed
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 9999
- Copying Features
- Collation copy, Job Build
Printing
- Inkjet Technology
- HP PageWide
- Ink Cartridge Configuration
- 4 cartridges (1 each: cyan, magenta, yellow, black)
- Ink Palette Supported (Colours)
- Pigment cyan, pigment magenta, pigment yellow, pigment black
- 4-ink
- Printer Drivers / Emulations
- PCL 6, PostScript 3, PCL 5c, PDF 1.7
Scanning
- Scan Element
- CIS / CCD
- Optical Resolution
- 600 dpi
- Grayscale Depth
- 8-bit
- Colour Depth
- 24-bit
Fax Machine
- Max Transmission Speed
- 33.6 Kbps
- Fax Resolutions
- Fax Printing Resolution
- 400 x 400 dpi
Fax Machine Features
- Broadcast Transmission
- 210 stations
- Fax forwarding, automatic redialing, junk fax barrier, auto reduction, poll receive
Document & Media Handling
- Min Original Size
- 100 x 148 mm
- Max Original Size
- 297 x 432 mm
- Original Type
- Sheets
- 100 sheets
- Min Media Size
- 100 x 148 mm
- Max Media Size
- A3/Ledger
- Max Media Weight
- 300 g/m²
- Supported Media Type
- Supported Media Sizes
- Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A3 (297 x 420 mm), A6 (105 x 148 mm), ANSI B (Ledger) (279 x 432 mm), ARCH B (304.8 x 457.2 mm), 100 x 150 mm, 100 x 148 mm, JIS B5 (182 x 257 mm), JIS B4 (257 x 364 mm), SRA4 (225 x 320 mm), 101.6 x 152.4 mm, Statement (139.7 x 215.9 mm), 197 x 273 mm, RA3 (305 x 430 mm), 127 x 177.8 mm, Oficio (216 x 343 mm), 127 x 203.2 mm, JIS B6 (128 x 182 mm), RA4 (215 x 305 mm), 270 x 390 mm, 260 x 368 mm, 273 x 394 mm, 195 x 270 mm, 184 x 260 mm, 148 x 200 mm
- Supported Envelope Sizes
- US No 10 (104.7 x 241.3 mm), International DL (110 x 220 mm), International C6 (114 x 162 mm), International C5 (162 x 229 mm), International B5 (176 x 250 mm), Monarch (98.4 x 190.5 mm), US No 9 (98.6 x 225.6 mm)
- 650 sheets
- 4650 sheets
- 60 sheets
- 500 sheets
- ADF - 100 sheets weight: 45 g/m² - 199 g/m² , Bypass tray - 60 sheets , Input tray - 550 sheets weight: 60 g/m² - 300 g/m² , Output tray - 500 sheets
- Speed Details
- Printing: up to 65 ppm (A4) - B/W draft , Printing: up to 45 ppm (A4) - B/W best , Printing: up to 65 ppm (A4) - colour draft , Printing: up to 45 ppm (A4) - colour normal , Scanning: up to 90 ipm (A4) - B/W normal , Copying: up to 45 ppm (A4) - B/W , Copying: up to 45 ppm (A4) - colour
- 1 x USB 2.0 - 4 pin USB Type B , 1 x Gigabit LAN - RJ-45 , 2 x USB 2.0 host - 4 pin USB Type A
- Kerberos, SSL, Apple Bonjour, TLS, IPsec, 802.1x, EAP-TLS, PEAP
- Operating System Support
- MS Windows XP SP3, Novell NetWare 6.5, MS Windows Server 2008 R2, Red Hat Enterprise Linux 6, Ubuntu Linux 12.04, MS Windows Server 2012 x64 Edition, Android, MS Windows Server 2008 R2 x64 Edition SP1, MS Windows Server 2003 (32/64-bits), MS Windows Server 2003 R2 (32/64-bits), MS Windows Server 2008 (32/64-bits), MS Windows Server 2012 R2 x64 Edition, MS Windows 7 (32/64 bits), Debian Linux 7.0, Apple Mac OS X 10.10, Windows 8 (32/64-bits), Windows 8.1 (32/64-bits), Windows 10 (32/64-bits), Linux Mint 17, Ubuntu Linux 14.04, Red Hat Enterprise Linux 7, Apple Mac OS X 10.11, MS Windows Vista 32-bit Edition, Novell Open Enterprise Server 11 SP1, Novell Open Enterprise Server 11, macOS 10.12, Linux Mint 17.1, Linux Mint 17.2, Linux Mint 18, Linux Mint 17.3, SuSe Linux 13.2, SuSe Linux 42.1, Ubuntu Linux 15.10, Ubuntu Linux 16.04, Ubuntu Linux 16.10, Debian Linux 8.6, Fedora Linux 22, Fedora Linux 23, Fedora Linux 24
- Software Included
- Drivers & Utilities, HP Device Experience (DXP), HP Connected
- Voltage Required
- EN 62479:2010, EN 62471:2008, IEC 62471, EN 61000-3-3:2013, CISPR 22:2008, EN 61000-3-2:2014, IEC 60950-1:2005 + A1:2009 + A2:2013, IEC 62479:2010, ES 203 021-3 V2.1.2, ES 203 021-1 V2.1.1, CISPR 32:2012 Class A, EN 55032:2012 Class A, ES 203 021-2 V2.1.2, EN 60950-1:2006+A11:2009+A1:2010+A12:2011+A2:2013
- ENERGY STAR Certified
- Limited warranty - 1 year - on-site - response time: next business day
- 81.3 cm
- 59.1 cm
- 45.8 cm
- 68 kg
- Shipping Width
- 79 cm
- Shipping Depth
- 76 cm
- Shipping Height
- 93.3 cm
- Shipping Weight
- 85 kg
- Sound Emission
- 53 dBA (operating)
- 15 °C
- 30 °C
- 10 - 80%
Ink (8)
HP Everyday Semi-Gloss Photo Paper-100 sheet/A4/210 x 297 mm | In Stock | £16.40 |
HP Advanced Glossy Photo Paper-25 sheet/13 x 18 cm borderless | In Stock | £5.10 |
HP Advanced Glossy Photo Paper-25 sheet/A4/210 x 297 mm | In Stock | £9.77 |
HP Advanced Photo Paper - Glossy photo paper - A3 (297x420mm) | In Stock | £21.10 |
HP 982X High Yield Black Original PageWide Cartridge | In Stock | £128.68 |
HP 982X High Yield Cyan Original PageWide Cartridge | In Stock | £139.78 |
HP 982X High Yield Magenta Original PageWide Cartridge | In Stock | £140.89 |
HP 982X High Yield Yellow Original PageWide Cartridge | In Stock | £140.89 |
Other bundles (1)
HP Foreign Interface Harness (FIH) | In Stock | £77.76 |
