HP PageWide 780DN Colour 45ppm Multifunction Printer
Quicklinx: DZY3WS00 Mfr#: J7Z09A#B19
Modern business demands forward-thinking technology – it's why HP engineered the next generation of HP PageWide Enterprise to deliver a competitive edge from every angle: lowest colour cost, maximum uptime and the industry's strongest security.
Dynamic security enabled printer. Only intended to be used with cartridges using an HP original chip. Cartridges using a non-HP chip may not work, and those that work today may not work in the future.
  • Breakthrough value – the lowest cost per colour page
    Get the quality you expect with HP PageWide Technology that delivers the lowest cost per colour page.
  • High-yield cartridges for an even better value
    Print more pages and replace cartridges less often with optional high-yield cartridges.
HP PageWide Enterprise Color MFP 780dn - multifunction printer - colour
Multifunction printer
Fax Type
Plain paper
English, German, French, Italian, Spanish / Europe
Printing Technology
Page wide array (colour)
Inkjet Technology
HP PageWide - 4-ink
Monthly Duty Cycle (max)
100000 pages
Recommended Monthly Volume
2500 - 20000 pages
Max Copying Speed
Up to 45 ppm (mono) / up to 45 ppm (colour)
Max Copying Resolution
Up to 600 x 600 dpi (mono) / up to 600 x 600 dpi (colour)
Max Printing Speed
Up to 65 ppm (mono) / up to 65 ppm (colour)
Max Printing Resolution
Up to 1200 x 1200 dpi (mono) / up to 2400 x 1200 dpi (colour)
Max Fax Transmission Speed
33.6 Kbps
Fax Resolutions
300 x 300 dpi, 204 x 98 dpi, 204 x 196 dpi
Scanning
600 dpi
Display
8"
Original Size
100 x 148 mm (min) - 297 x 432 mm (max)
Original Type
Sheets
Document Feeder Capacity
100 sheets
Media Size
100 x 148 mm (min) - 297 x 432 mm, RA3 (305 x 430 mm) (max)
Media Type
Envelopes, plain paper, cards, labels, photo paper, glossy paper
Standard Media Capacity
650 sheets
Max Media Capacity
4650 sheets
Bypass Feeder Capacity
60 sheets
Output Trays Capacity
500 sheets
Automatic Duplexing
Yes (copying) Yes (printing) Yes (scanning)
Connection Availability
USB 2.0, Gigabit LAN, USB 2.0 host
AirPrint Enabled
Office Machine Features
Save to USB flash drive, scan to e-mail, Hardware Integration Pocket, save to network folder, HP EasyColor, HP Auto-On/Auto-Off Technology, Open Extensibility Platform (OXP)
AC 120/230 V (50/60Hz)
81.3 cm x 59.1 cm x 45.8 cm
68 kg
Environmental Standards
ENERGY STAR Qualified
1-year warranty
Fax Type
Plain paper
Printing Technology
Page wide array - colour
100000 pages
2500 - 20000 pages
Display Diagonal Size
8"
Display Features
Touch screen
AirPrint Enabled
Standard Memory
3.5 GB
Max Supported Memory
4.5 GB
Copying
Max Copying Speed
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
9999
Automatic Duplexing
Copying Features
Collation copy, Job Build
Printing
Inkjet Technology
HP PageWide
Max Printing Speed
Ink Cartridge Configuration
4 cartridges (1 each: cyan, magenta, yellow, black)
Ink Palette Supported (Colours)
Pigment cyan, pigment magenta, pigment yellow, pigment black
4-ink
Printer Drivers / Emulations
PCL 6, PostScript 3, PCL 5c, PDF 1.7
Automatic Duplexing
Scanning
Scan Element
CIS / CCD
Automatic Duplexing
Optical Resolution
600 dpi
Grayscale Depth
8-bit
Colour Depth
24-bit
Fax Machine
Max Transmission Speed
33.6 Kbps
Fax Resolutions
Fax Printing Resolution
400 x 400 dpi
Fax Machine Features
Broadcast Transmission
210 stations
Fax forwarding, automatic redialing, junk fax barrier, auto reduction, poll receive
Document & Media Handling
Min Original Size
100 x 148 mm
Max Original Size
297 x 432 mm
Original Type
Sheets
100 sheets
Min Media Size
100 x 148 mm
Max Media Size
A3/Ledger
Max Media Weight
300 g/m²
Supported Media Type
Supported Media Sizes
Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A3 (297 x 420 mm), A6 (105 x 148 mm), ANSI B (Ledger) (279 x 432 mm), ARCH B (304.8 x 457.2 mm), 100 x 150 mm, 100 x 148 mm, JIS B5 (182 x 257 mm), JIS B4 (257 x 364 mm), SRA4 (225 x 320 mm), 101.6 x 152.4 mm, Statement (139.7 x 215.9 mm), 197 x 273 mm, RA3 (305 x 430 mm), 127 x 177.8 mm, Oficio (216 x 343 mm), 127 x 203.2 mm, JIS B6 (128 x 182 mm), RA4 (215 x 305 mm), 270 x 390 mm, 260 x 368 mm, 273 x 394 mm, 195 x 270 mm, 184 x 260 mm, 148 x 200 mm
Supported Envelope Sizes
US No 10 (104.7 x 241.3 mm), International DL (110 x 220 mm), International C6 (114 x 162 mm), International C5 (162 x 229 mm), International B5 (176 x 250 mm), Monarch (98.4 x 190.5 mm), US No 9 (98.6 x 225.6 mm)
650 sheets
Max Media Capacity
4650 sheets
60 sheets
500 sheets
ADF - 100 sheets weight: 45 g/m² - 199 g/m² , Bypass tray - 60 sheets , Input tray - 550 sheets weight: 60 g/m² - 300 g/m² , Output tray - 500 sheets
Speed Details
Printing: up to 65 ppm (A4) - B/W draft , Printing: up to 45 ppm (A4) - B/W best , Printing: up to 65 ppm (A4) - colour draft , Printing: up to 45 ppm (A4) - colour normal , Scanning: up to 90 ipm (A4) - B/W normal , Copying: up to 45 ppm (A4) - B/W , Copying: up to 45 ppm (A4) - colour
1 x USB 2.0 - 4 pin USB Type B , 1 x Gigabit LAN - RJ-45 , 2 x USB 2.0 host - 4 pin USB Type A
Security Protocols & Features
Kerberos, SSL, Apple Bonjour, TLS, IPsec, 802.1x, EAP-TLS, PEAP
Operating System Support
MS Windows XP SP3, Novell NetWare 6.5, MS Windows Server 2008 R2, Red Hat Enterprise Linux 6, Ubuntu Linux 12.04, MS Windows Server 2012 x64 Edition, Android, MS Windows Server 2008 R2 x64 Edition SP1, MS Windows Server 2003 (32/64-bits), MS Windows Server 2003 R2 (32/64-bits), MS Windows Server 2008 (32/64-bits), MS Windows Server 2012 R2 x64 Edition, MS Windows 7 (32/64 bits), Debian Linux 7.0, Apple Mac OS X 10.10, Windows 8 (32/64-bits), Windows 8.1 (32/64-bits), Windows 10 (32/64-bits), Linux Mint 17, Ubuntu Linux 14.04, Red Hat Enterprise Linux 7, Apple Mac OS X 10.11, MS Windows Vista 32-bit Edition, Novell Open Enterprise Server 11 SP1, Novell Open Enterprise Server 11, macOS 10.12, Linux Mint 17.1, Linux Mint 17.2, Linux Mint 18, Linux Mint 17.3, SuSe Linux 13.2, SuSe Linux 42.1, Ubuntu Linux 15.10, Ubuntu Linux 16.04, Ubuntu Linux 16.10, Debian Linux 8.6, Fedora Linux 22, Fedora Linux 23, Fedora Linux 24
Software Included
Drivers & Utilities, HP Device Experience (DXP), HP Connected
EN 62479:2010, EN 62471:2008, IEC 62471, EN 61000-3-3:2013, CISPR 22:2008, EN 61000-3-2:2014, IEC 60950-1:2005 + A1:2009 + A2:2013, IEC 62479:2010, ES 203 021-3 V2.1.2, ES 203 021-1 V2.1.1, CISPR 32:2012 Class A, EN 55032:2012 Class A, ES 203 021-2 V2.1.2, EN 60950-1:2006+A11:2009+A1:2010+A12:2011+A2:2013
ENERGY STAR Certified
Limited warranty - 1 year - on-site - response time: next business day
81.3 cm
59.1 cm
45.8 cm
68 kg
Shipping Width
79 cm
Shipping Depth
76 cm
Shipping Height
93.3 cm
Shipping Weight
85 kg
Sound Emission
53 dBA (operating)
15 °C
30 °C
10 - 80%
Ink (8)
DZY3 HP Everyday Semi-Gloss Photo Paper-100 sheet/A4/210 x 297 mm In Stock £16.48
DZY3 HP Advanced Glossy Photo Paper-25 sheet/13 x 18 cm borderless In Stock £5.11
DZY3 HP Advanced Glossy Photo Paper-25 sheet/A4/210 x 297 mm In Stock £9.80
DZY3 HP Advanced Photo Paper - Glossy photo paper - A3 (297x420mm) In Stock £21.17
DZY3 HP 982X High Yield Black Original PageWide Cartridge In Stock £129.12
DZY3 HP 982X High Yield Cyan Original PageWide Cartridge In Stock £141.38
DZY3 HP 982X High Yield Magenta Original PageWide Cartridge In Stock £141.38
DZY3 HP 982X High Yield Yellow Original PageWide Cartridge In Stock £141.38
Other bundles (1)
DZY3 HP Foreign Interface Harness (FIH) In Stock £77.76
