When it comes to the P34hc WQHD Curved Monitor, bigger really is better. Because its immersive, ultrawide screen keeps you focused, you're likely to be less distracted and up to 33% more productive compared to a smaller screen.
Ports For Everything
Plenty of ports to connect multiple devices. -
Peace of Mind Included
3-year limited warranty included.
- HP P34hc G4 - P-Series - LED monitor - curved - 34"
- LED-backlit LCD monitor - 34"
- Energy Class
- Class G
- Power Consumption (On mode)
- 32 W
- Curved Screen
- USB 3.2 Gen 1 hub
- Panel Type
- VA
- Aspect Ratio
- 21:9
- Native Resolution
- WQHD 3440 x 1440 at 60 Hz
- Pixel Pitch
- 0.23175 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 3500:1 / 50000000:1 (dynamic)
- Response Time
- 5 ms (grey-to-grey with overdrive)
- Colour Gamut
- 85% NTSC
- Input Connectors
- HDMI, DisplayPort, USB-C
- Height, tilt
- Screen Coating
- Anti-glare, 3H Hard Coating, Haze 25%
- Voltage
- AC 120/230 V (50/60 Hz)
- Black
- 80.94 cm x 23.49 cm x 51.8 cm
- 10.51 kg
- Localisation
- English / United Kingdom
- Environmental Standards
- TCO Certified Displays 8, TCO Certified Edge Displays, ENERGY STAR Qualified
- TUV, VCCI, GS, NOM, WHQL, CB, CCC, FCC, ISO 9241-307, KCC, WEEE, cTUVus, KC, CEL, EPA, EAC, RCM, BIS, low halogen, DisplayPort 1.2, ICE, KES
- 3-year warranty
- Display Type
- Energy Class
- Class G
- Diagonal Size
- 34"
- Curved Screen
- Yes (1500R)
- Built-in Devices
- USB 3.2 Gen 1 hub
- Panel Type
- VA
- Aspect Ratio
- 21:9
- Native Resolution
- Pixel Pitch
- 0.23175 mm
- Pixel Per Inch
- 110
- Brightness
- 250 cd/m²
- Contrast Ratio
- Colour Gamut
- 85% NTSC
- Response Time
- Vertical Refresh Rate
- 48 - 100 Hz
- Horizontal Refresh Rate
- 30 - 160 kHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Backlight Technology
- LED backlight
- Colour Temperature
- 6500K
- OSD Languages
- Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Spanish, Dutch, Japanese
- Low Blue Light Mode, Flicker Free technology, Mercury free, arsenic free, 3-sided micro-edge, 8-bit Colour Depth, edge-lit LED backlight
- Black
- 80.94 cm x 23.49 cm x 51.8 cm - with stand
- 10.51 kg
Audio
- Speakers - stereo
- Output Power / Channel
- 3 Watt
- HDMI (HDCP) , DisplayPort 1.2 (HDCP) , Audio line-out , USB-C upstream/DisplayPort Alt Mode with Power Delivery (HDCP) , 4 x USB 3.2 Gen 1 , USB (Type B) , KVM
Mechanical
- Height, tilt
- Tilt Angle
- -5/+21
- Height Adjustment
- 100 mm
- VESA Mounting Interface
- 100 x 100 mm
- Security lock slot (cable lock sold separately), detachable stand, VESA interface support
- Cables Included
- 1 x HDMI cable - 1.8 m , 1 x DisplayPort cable - 1.8 m , 1 x USB-C to USB-C cable - 1.8 m
- Mounting Kit
- Included
- Backlight Life
- 30,000 hours
- Localisation
- Security Slot Type
- Kensington security slot
- Input Voltage
- 32 W
- Power Consumption SDR (On mode)
- 32 kWh/1000h
- Power Consumption (Typical)
- 48 Watt
- Power Consumption Stand by
- 0.5 Watt
- 0.3 Watt
- Included Software
- HP Display Center
- Dimensions & Weight Details
- With stand - width: 80.94 cm - depth: 23.49 cm - height: 51.8 cm - weight: 10.51 kg , Without stand - width: 80.94 cm - depth: 11.21 cm - height: 36.69 cm - weight: 7.85 kg
- Shipping Width
- 95 cm
- Shipping Depth
- 22.5 cm
- Shipping Height
- 48 cm
- Shipping Weight
- 16.7 kg
Sustainability Information
- TCO Certified
- ENERGY STAR Certified
- Limited warranty - parts and labour - 3 years
- 5 °C
- 35 °C
- 20 - 80% (non-condensing)
