HP P34hc G4 34" 3440x1440 5ms HDMI DisplayPort USB-C LED Curved Monitor
Quicklinx: GQZWWS00 Mfr#: 21Y56AA#ABU
Diagonal Size: 34in
Max Resolution: 3440 x 1440
Response Time: 5ms
Speakers: Speaker(s)
Interfaces: HDMI, USB-C, DisplayPort
Hurry, only 1 left in stock!
£373.33 ex VAT
£447.99 inc VAT
Express delivery Order within the next 23 hours for delivery on Friday
When it comes to the P34hc WQHD Curved Monitor, bigger really is better. Because its immersive, ultrawide screen keeps you focused, you're likely to be less distracted and up to 33% more productive compared to a smaller screen.
  • Ports For Everything
    Plenty of ports to connect multiple devices.
  • Peace of Mind Included
    3-year limited warranty included.
HP P34hc G4 - P-Series - LED monitor - curved - 34"
LED-backlit LCD monitor - 34"
Energy Label QR Code URL
Https://eprel.ec.europa.eu/qr/391415
Energy Class
Class G
Power Consumption (On mode)
32 W
Curved Screen
USB 3.2 Gen 1 hub
Panel Type
VA
Aspect Ratio
21:9
Native Resolution
WQHD 3440 x 1440 at 60 Hz
Pixel Pitch
0.23175 mm
Brightness
250 cd/m²
Contrast Ratio
3500:1 / 50000000:1 (dynamic)
Response Time
5 ms (grey-to-grey with overdrive)
Colour Gamut
85% NTSC
Input Connectors
HDMI, DisplayPort, USB-C
Display Position Adjustments
Height, tilt
Screen Coating
Anti-glare, 3H Hard Coating, Haze 25%
Voltage
80.94 cm x 23.49 cm x 51.8 cm
10.51 kg
English / United Kingdom
Environmental Standards
TCO Certified Edge Displays, TCO Certified Displays 9, ENERGY STAR Qualified
Carbon Footprint
430 kg carbon emissions
TUV, VCCI, GS, NOM, WHQL, CB, CCC, FCC, ISO 9241-307, KCC, WEEE, cTUVus, KC, CEL, EPA, EAC, RCM, BIS, low halogen, DisplayPort 1.2, ICE, CEL Grade 3, Mercury-free, KES, WW application, Arsenic-free
3-year warranty
Display Type
Energy Class
Class G
Diagonal Size
34"
Curved Screen
Yes (1500R)
Built-in Devices
USB 3.2 Gen 1 hub
Panel Type
VA
Aspect Ratio
21:9
Native Resolution
Pixel Pitch
0.23175 mm
Pixel Per Inch
110
Brightness
250 cd/m²
Contrast Ratio
Colour Gamut
85% NTSC
Response Time
Vertical Refresh Rate
48 - 100 Hz
Horizontal Refresh Rate
30 - 160 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
LED backlight
Colour Temperature
6500K
OSD Languages
Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Spanish, Dutch, Japanese
Low Blue Light Mode, Flicker Free technology, Mercury free, arsenic free, 3-sided micro-edge, 8-bit Colour Depth, edge-lit LED backlight
80.94 cm x 23.49 cm x 51.8 cm - with stand
10.51 kg
Audio
Speakers - stereo
Output Power / Channel
3 Watt
HDMI (HDCP) , DisplayPort 1.2 (HDCP) , Audio line-out , USB-C upstream/DisplayPort Alt Mode with Power Delivery (HDCP) , 4 x USB 3.2 Gen 1 , USB (Type B) , KVM
Mechanical
Height, tilt
Tilt Angle
-5/+21
Height Adjustment
100 mm
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), detachable stand, VESA interface support
1 x HDMI cable - 1.8 m , 1 x DisplayPort cable - 1.8 m , 1 x USB-C to USB-C cable - 1.8 m
Mounting Kit
Included
Backlight Life
30,000 hours
Security Slot Type
Kensington security slot
Input Voltage
32 W
32 kWh/1000h
Power Consumption (Typical)
48 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption (Off Mode)
0.3 Watt
Included Software
HP Display Center
Dimensions & Weight Details
With stand - width: 80.94 cm - depth: 23.49 cm - height: 51.8 cm - weight: 10.51 kg , Without stand - width: 80.94 cm - depth: 11.21 cm - height: 36.69 cm - weight: 7.85 kg
Shipping Width
95 cm
Shipping Depth
22.5 cm
Shipping Height
48 cm
Shipping Weight
16.7 kg
Sustainability Information
TCO Certified
ENERGY STAR Certified
Carbon Footprint
Manufacturing (kg CO2e)
232
Logistics (kg CO2e)
5
Use (kg CO2e)
185
EOL (kg CO2e)
7
Total Carbon w/o Use Phase (kg CO2e)
430
Limited warranty - parts and labour - 3 years
5 °C
35 °C
20 - 80% (non-condensing)
GQZW HP B250 Mounting Kit for LCD Display/Thin Client In Stock £20.08
Diagonal Size: 34in
Response Time: 5ms
Interfaces: HDMI
Interfaces: USB-C
Interfaces: DisplayPort
Brand: HP
