HP P3405 MT E2-3200, 2GB, 500GB, DVD±RW, Windows 7 Professional 64-bit
Quicklinx: 7SV6WS00 Mfr#: LH132EA#ABU
  • Microsoft Windows 7 Professional 64-bit Edition
Powerful enough to handle your workplace computing tasks with convenient expandability options, it's the versatile PC that will grow as your needs do. You get a full-function PC with a heritage of quality and reliability; you've found your ideal PC.
  • The perfect fit
    With its space-efficient industrial design, this PC is sophistication personified and includes configurability as well. You get a powerful workhorse ready to meet your needs now and grow with your business later.Smaller than our average HP desktop tower, the space-saving HP Pro 3405 Microtower fits neatly on a desk, counter, or shelf.
  • Room to grow
    Flexible so you get a PC that best fits your small business needs; the Microtower can be configured to support high-speed memory and AMD next generation Fusion processors for the latest in performance.Choose from a range of standard hard drive up to 2 TB or optical drive options including the latest 16X Max DVD-ROM or SuperMulti DVD Writer so you can meet your business data storage and replication needs today and tomorrow.Whether you're editing photos, creating multimedia presentations, or designing web content you'll see enhanced image clarity and detail with integrated AMD Radeon HD graphics.
  • Flexibility comes standard
    The HP Pro 3405 Microtower is ready to configure with extra memory slots, PCI Express (PCIe) slots, and 8,9/13,3 cm (3.5"/5.25") bays. Choose the Windows 7 Professional. Other Windows editions available.The integrated 6-in-1Media Card Reader lets you conveniently read, write, copy, and store files from your computer to different types of media.
  • Fits in with style
    The new design features conveniently placed ports and integrated options so your PC works with you for productivity and performance.
  • More than what is in the box
    Our business-focused innovations, included in every HP Pro 3405 Microtower PC, help you increase productivity, reduce your environmental footprint, and improve your overall computing experience.
HP Pro 3405 - micro tower - E2 3200 2.4 GHz - 2 GB - HDD 500 GB
Personal computer - micro tower
AMD E2 3200 / 2.4 GHz (Dual-Core)
Cache Memory
1 MB L2 Cache
Cache Per Processor
1 MB
RAM
2 GB (installed) / 8 GB (max) - DDR3 SDRAM - PC3-10600
Storage Controller
SATA (SATA 3Gb/s)
Hard Drive
HDD 500 GB - SATA 3Gb/s - 7200 rpm
Optical Storage
DVD SuperMulti
Card Reader
6 in 1
Graphics Controller
AMD Radeon HD 6379D Shared Video Memory (UMA)
Audio Output
7.1 channel surround - integrated
GigE
AC 120/230 V
OS Provided
Microsoft Office Preloaded
Includes a pre-loaded image of select Microsoft Office 2010 suites. Purchase an Office 2010 Product Key Card or disc to activate preloaded software on this PC.
Software Included
Cyberlink PowerDVD, Zinio Reader, CyberLink Power2Go, Windows XP Mode, PDF Complete Special Edition, CyberLink Label Print, HP Recovery Manager, HP Support Assistant, HP Vision Diagnostics, Windows Virtual PC, Blio e-Reader, Norton Internet Security (60 days trial), HP ProtectTools Security Software Suite SMB, Xobni, HP SimplePass PE 2011, Kobo eReader
16.5 cm x 38.9 cm x 36.8 cm
6.9 kg
Limited warranty - parts and labour - 1 year - on-site
Personal computer
Recommended Use
Small business, corporate business
Product Form Factor
Micro tower
Processor / Chipset
CPU
AMD E2 3200
Clock Speed
2.4 GHz
Number of Cores
Dual-Core
64-bit Computing
CPU Qty
1
Max CPU Qty
1
CPU Upgradability
Upgradable
Chipset Type
AMD A55
Cache Memory
Installed Size
L2 Cache - 1 MB
Cache Per Processor
1 MB
RAM
Installed Size
2 GB / 8 GB (max)
DDR3 SDRAM
Effective Memory Speed
1333 MHz
Rated Memory Speed
1333 MHz
Memory Specification Compliance
PC3-10600
DIMM 240-pin
Slots
2 (Total)
Unbuffered
Hard Drive
HDD
1 x 500 GB
Interface Type
SATA 3Gb/s
Spindle Speed
7200 rpm
Native Command Queuing (NCQ)
Storage Controller
1 x SATA - integrated
Controller Interface Type
SATA 3Gb/s
Optical Storage
DVD±RW / DVD-RAM DVD SuperMulti - SATA
Card Reader
6 in 1 card reader
Monitor
Monitor Type
None.
Graphics Controller
Integrated
Graphics Processor
Video Interfaces
VGA, DVI
Audio Output
Integrated
Sound Output Mode
Integrated
Ethernet Controller
Realtek RTL8111E
Bays
1 (total) / 0 (free) x external 5.25" , 1 (total) / 0 (free) x internal 3.5"
Slots
2 DIMM 240-pin , 1 (total) / 0 (free) x CPU , 1 (total) / 1 (free) x PCIe x16 , 3 (total) / 3 (free) x PCIe x1 , 1 (total) / 1 (free) x PCIe Mini Card
6 x USB 2.0 (2 front, 4 rear) , 1 x DVI-D , 1 x VGA , 1 x LAN (Gigabit Ethernet) , 2 x microphone (1 front, 1 rear) , 1 x audio line-in , 1 x audio line-out , 1 x headphones
RoHS, WEEE
Power supply
AC 120/230 V
Power Provided
300 Watt
Operating System / Software
OS Provided
Software
16.5 cm
38.9 cm
36.8 cm
6.9 kg
5 °C
35 °C
8 - 90% (non-condensing)
