HP P27q G4 27" 2560x1440 5ms VGA HDMI IPS LED Monitor
Quicklinx: G28YWS00 Mfr#: 8MB11AT#ABU
Diagonal Size: 27in
Max Resolution: 2560 x 1440
Response Time: 5ms
Speakers: None
Interfaces: HDMI, VGA (HD-15)
£243.00 ex VAT
£291.60 inc VAT
Enjoy a stylish, height-adjustable display with sharp QHD resolution and ultra-wide viewing angles on the HP P27q 27" monitor. This ultra-slim, 3-sided micro-edge display comes at a great value with convenient HDMI and VGA connectivity.
  • Find your sweet spot
    Filter blue light emission and shift colors to a warmer spectrum for more comfortable viewing with HP Low Blue Light mode. Adjust tilt for your best view.
  • Divide and conquer
    Manage your display and make it work for you. HP Display Assistant allows you to quickly resize screen partitions so you can work in separate regions of the screen and helps deter theft by dimming a display that's disconnected without approval.
  • We have your back
    We're just a call or click away. Rest assured that your IT investment is supported with our three-year standard limited warranty. To extend your protection, select an optional HP Care service.
HP P27q G4 - P-Series - LED monitor - 27" - Smart Buy
LED-backlit LCD monitor - 27"
Energy Class
Class F
Power Consumption (On mode)
26 W
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
QHD 2560 x 1440 at 60 Hz
Pixel Pitch
0.2331 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 10000000:1 (dynamic)
Response Time
5 ms (grey-to-grey)
Colour Gamut
99% sRGB
Input Connectors
HDMI, VGA
Display Position Adjustments
Screen Coating
Anti-glare
Voltage
61.42 cm x 21.16 cm x 50.49 cm
6.84 kg
English / United Kingdom
Manufacturer Selling Program
HP Smart Buy
Plug and Play, BSMI, NOM, WHQL, CB, CCC, FCC, ISO 9241-307, ICES, S Mark, cTUVus, TUV Bauart, China Energy Label Level 2, CEC, ERP, CECP, CEL, EAC, UAE, Ukraine Energy Label
Display Type
Energy Class
Class F
Diagonal Size
27"
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2331 mm
Pixel Per Inch
109
Brightness
250 cd/m²
Contrast Ratio
Colour Gamut
99% sRGB
Response Time
5 ms (grey-to-grey)
Vertical Refresh Rate
50 - 60 Hz
Horizontal Refresh Rate
30 - 80 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Anti-glare
Backlight Technology
LED backlight
Colour Temperature
6500K
OSD Languages
Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Spanish, Dutch, Japanese
Flicker Free technology, 8-bit gamma, 3-sided micro-edge
61.42 cm x 21.16 cm x 50.49 cm - with stand
6.84 kg
HDMI , VGA
Mechanical
Tilt Angle
-5/+23
Swivel Angle
360
Rotation Angle
90
Height Adjustment
100 mm
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), detachable stand, VESA interface support, HDCP Compliant, arsenic free, mercury free
1 x HDMI cable - 1.8 m
Backlight Life
30,000 hours
HP Smart Buy
Security Slot Type
Kensington security slot
Input Voltage
26 W
26 kWh/1000h
Power Consumption (Typical)
32 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption (Off Mode)
0.3 Watt
Dimensions & Weight Details
With stand - width: 61.42 cm - depth: 21.16 cm - height: 50.49 cm - weight: 6.84 kg , Without stand - width: 61.42 cm - depth: 5.05 cm - height: 36.79 cm - weight: 4.64 kg
Shipping Width
70.5 cm
Shipping Depth
23.4 cm
Shipping Height
47.8 cm
Shipping Weight
9.27 kg
5 °C
35 °C
20 - 80% (non-condensing)
Accessories (1)
G28Y HP B250 Mounting Kit for LCD Display/Thin Client In Stock £33.61
Warranties (4)
G28Y HP Care Pack Next Business Day Hardware Support Extended Service Agreement 4 Years On-Site In Stock £22.36
G28Y HP Care Pack Next Business Day Hardware Support Extended Service Agreement 5 Years On-Site In Stock £32.96
G28Y HP Care Pack Next Business Day Hardware Support Extended Service Agreement 1 Year On-Site In Stock £5.93
G28Y HP Care Pack Next Business Day Hardware Support Extended Service Agreement 3 Yrs On-Site for Monitor In Stock £10.59
Diagonal Size: 27in
Response Time: 5ms
Speakers: None
Interfaces: HDMI
Interfaces: VGA (HD-15)
Brand: HP
