Expand your view and your productivity with this 68.6 cm (27-inch) diagonal, FHD monitor when you're working from home or at the office. This sleek, sizeable monitor makes hybrid work easy and complete via a crisp, smooth screen, built-in audio, and simple design, so you can do more everyday.
75 Hz Refresh Rate
Experience smooth, life-like video and clear detail with a 75 Hz refresh rate that provides fluid movement from frame to frame. -
Adjustable Tilt and Height
The tilt and 100 mm height-adjustable stand helps deliver the perfect view to maximize productivity. -
Built-In Dual 2W Speakers
Listen to music, meetings and more with the built-in, dual 2W speakers. -
3-Sided Micro-Edge Bezel
See and do more on your screen with a 3-sided micro-edge bezel that maximizes your viewing area for a sleek design and seamless dual-monitor setups. -
Easy Joypad OSD Button
It's never been easier to configure your display with Joypad OSD button to adjust brightness, resolution, and volume. -
Low-Blue Light Mode
Keep your eyes comfortable with subtly warmer display colors onscreen.
 - HP P27h G5 - P-Series - LED monitor - Full HD (1080p) - 27"
 - LED-backlit LCD monitor - 27"
- Panel Type
 - IPS
- Aspect Ratio
 - 16:9
- Native Resolution
 - Full HD (1080p) 1920 x 1080 at 75 Hz
- Pixel Pitch
 - 0.311 mm
- Brightness
 - 250 cd/m²
- Contrast Ratio
 - 1000:1 / 8000000:1 (dynamic)
- Response Time
 - 5 ms (grey-to-grey with overdrive)
- Colour Support
 - 16.7 million colours (8-bit)
- Colour Gamut
 - 72% NTSC
- Input Connectors
 - HDMI, VGA, DisplayPort
 - Height, tilt
- Screen Coating
 - Anti-glare, 3H Hard Coating, Haze 25%
- Voltage
 - AC 100-240 V (50/60 Hz)
 - Black
 - 61.1 cm x 20.23 cm x 50.97 cm
 - 5.75 kg
- Localisation
 - English / United Kingdom
- Environmental Standards
 - TCO Certified Edge Displays, TCO Certified Displays 9, ENERGY STAR Qualified EPEAT Gold
- Carbon Footprint
 - 190 kg carbon emissions
 - CSA, UL, VCCI, BSMI, NOM, TUV S, WHQL, CB, CCC, PSB, FCC, RoHS, ISO 9241-307, KCC, WEEE, ICES, cTUVus, Energy-Related Products (ErP) Lot 6, TUV Bauart, CEC, KC, CECP, CEL, EAC, CEL Grade 1, ISC, RCM, SEPA, BIS, low halogen, TUV Rheinland Flicker Free Certification, DisplayPort 1.2, NRCS, EU RoHS, Mexico Energy label, Taiwan BSMI RoHS, Mexico NOM, Australian-New Zealand MEPS, Vietnam MEPS, South Africa Energy Label, Ukraine Energy Label, TUV low blue light, WW application, Argentina S-Mark, EuP Lot 26
 - 3-year warranty
- Display Type
- Diagonal Size
 - 27"
- Panel Type
 - IPS
- Aspect Ratio
 - 16:9
- Native Resolution
- Pixel Pitch
 - 0.311 mm
- Pixel Per Inch
 - 82
- Brightness
 - 250 cd/m²
- Contrast Ratio
- Colour Support
- Colour Gamut
 - 72% NTSC
- Response Time
- Vertical Refresh Rate
 - 48 - 75 Hz
- Horizontal Refresh Rate
 - 30 - 86 kHz
- Horizontal Viewing Angle
 - 178
- Vertical Viewing Angle
 - 178
- Screen Coating
- Backlight Technology
 - Edge-lit LED
- Colour Temperature
 - 6500K
- OSD Languages
 - Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Spanish, Dutch, Japanese
 - Low Blue Light Mode, Flicker Free technology, Color Calibrated, 3-sided micro-edge, 8-bit(6-bit + FRC) Colour Depth
 - Black
 - 61.1 cm x 20.23 cm x 50.97 cm - with stand
 - 5.75 kg
Audio
 - Speakers - stereo
- Output Power / Channel
 - 2 Watt
 - DisplayPort (HDCP) , HDMI (HDCP) , VGA
Mechanical
 - Height, tilt
- Tilt Angle
 - -5/+20
- Height Adjustment
 - 100 mm
- VESA Mounting Interface
 - 100 x 100 mm
 - Security lock slot (cable lock sold separately), detachable stand, VESA interface support, HDCP Compliant, arsenic free, mercury free
- Cables Included
 - 1 x HDMI cable - 1.8 m
- Backlight Life
 - 30,000 hours
- Localisation
- Security Slot Type
 - Kensington security slot
- Input Voltage
- Power Consumption (Typical)
 - 21 Watt
- Power Consumption (Max)
 - 35 Watt
- Power Consumption Stand by
 - 0.5 Watt
- Included Software
 - HP Display Center, HP Display Manager
- Dimensions & Weight Details
 - With stand - width: 61.1 cm - depth: 20.23 cm - height: 50.97 cm - weight: 5.75 kg , Without stand - width: 61.1 cm - depth: 5.71 cm - height: 36.56 cm - weight: 4.49 kg
- Shipping Width
 - 68.5 cm
- Shipping Depth
 - 14.1 cm
- Shipping Height
 - 42.5 cm
- Shipping Weight
 - 8.03 kg
Sustainability Information
- TCO Certified
- EPEAT Compliant
 - EPEAT Gold
- ENERGY STAR Certified
- Carbon Footprint
- Manufacturing (kg CO2e)
 - 111
- Logistics (kg CO2e)
 - 3
- Use (kg CO2e)
 - 76
- EOL (kg CO2e)
 - 3
- Total Carbon w/o Use Phase (kg CO2e)
 - 190
 - Limited warranty - parts and labour - 3 years
 - 5 °C
 - 35 °C
 - 20 - 80% (non-condensing)
