HP P27h G5 27" 1920x1080 5ms VGA HDMI DisplayPort IPS LED Monitor
Quicklinx: HB9FWS00 Mfr#: 64W41AA#ABU
Diagonal Size: 27in
Max Resolution: 1920 x 1080
Response Time: 5ms
Speakers: Speaker(s)
Interfaces: DisplayPort, VGA (HD-15), HDMI
More than 50 In Stock
£117.36 ex VAT
£140.83 inc VAT
Expand your view and your productivity with this 68.6 cm (27-inch) diagonal, FHD monitor when you're working from home or at the office. This sleek, sizeable monitor makes hybrid work easy and complete via a crisp, smooth screen, built-in audio, and simple design, so you can do more everyday.
  • 75 Hz Refresh Rate
    Experience smooth, life-like video and clear detail with a 75 Hz refresh rate that provides fluid movement from frame to frame.
  • Adjustable Tilt and Height
    The tilt and 100 mm height-adjustable stand helps deliver the perfect view to maximize productivity.
  • Built-In Dual 2W Speakers
    Listen to music, meetings and more with the built-in, dual 2W speakers.
  • 3-Sided Micro-Edge Bezel
    See and do more on your screen with a 3-sided micro-edge bezel that maximizes your viewing area for a sleek design and seamless dual-monitor setups.
  • Easy Joypad OSD Button
    It's never been easier to configure your display with Joypad OSD button to adjust brightness, resolution, and volume.
  • Low-Blue Light Mode
    Keep your eyes comfortable with subtly warmer display colors onscreen.
HP P27h G5 - P-Series - LED monitor - Full HD (1080p) - 27"
LED-backlit LCD monitor - 27"
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080 at 75 Hz
Pixel Pitch
0.311 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 8000000:1 (dynamic)
Response Time
5 ms (grey-to-grey with overdrive)
Colour Support
16.7 million colours (8-bit)
Colour Gamut
72% NTSC
Input Connectors
HDMI, VGA, DisplayPort
Display Position Adjustments
Height, tilt
Screen Coating
Anti-glare, 3H Hard Coating, Haze 25%
Voltage
AC 100-240 V (50/60 Hz)
61.1 cm x 20.23 cm x 50.97 cm
5.75 kg
English / United Kingdom
Environmental Standards
TCO Certified Edge Displays, TCO Certified Displays 9, ENERGY STAR Qualified EPEAT Gold
Carbon Footprint
190 kg carbon emissions
CSA, UL, VCCI, BSMI, NOM, TUV S, WHQL, CB, CCC, PSB, FCC, RoHS, ISO 9241-307, KCC, WEEE, ICES, cTUVus, Energy-Related Products (ErP) Lot 6, TUV Bauart, CEC, KC, CECP, CEL, EAC, CEL Grade 1, ISC, RCM, SEPA, BIS, low halogen, TUV Rheinland Flicker Free Certification, DisplayPort 1.2, NRCS, EU RoHS, Mexico Energy label, Taiwan BSMI RoHS, Mexico NOM, Australian-New Zealand MEPS, Vietnam MEPS, South Africa Energy Label, Ukraine Energy Label, TUV low blue light, WW application, Argentina S-Mark, EuP Lot 26
3-year warranty
Display Type
Diagonal Size
27"
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.311 mm
Pixel Per Inch
82
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Colour Gamut
72% NTSC
Response Time
Vertical Refresh Rate
48 - 75 Hz
Horizontal Refresh Rate
30 - 86 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
Edge-lit LED
Colour Temperature
6500K
OSD Languages
Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Spanish, Dutch, Japanese
Low Blue Light Mode, Flicker Free technology, Color Calibrated, 3-sided micro-edge, 8-bit(6-bit + FRC) Colour Depth
61.1 cm x 20.23 cm x 50.97 cm - with stand
5.75 kg
Audio
Speakers - stereo
Output Power / Channel
2 Watt
DisplayPort (HDCP) ¦ HDMI (HDCP) ¦ VGA
Mechanical
Height, tilt
Tilt Angle
-5/+20
Height Adjustment
100 mm
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), detachable stand, VESA interface support, HDCP Compliant, arsenic free, mercury free
1 x HDMI cable - 1.8 m
Backlight Life
30,000 hours
Security Slot Type
Kensington security slot
Input Voltage
Power Consumption (Typical)
21 Watt
Power Consumption (Max)
35 Watt
Power Consumption Stand by
0.5 Watt
Included Software
HP Display Center, HP Display Manager
Dimensions & Weight Details
With stand - width: 61.1 cm - depth: 20.23 cm - height: 50.97 cm - weight: 5.75 kg ¦ Without stand - width: 61.1 cm - depth: 5.71 cm - height: 36.56 cm - weight: 4.49 kg
Shipping Width
68.5 cm
Shipping Depth
14.1 cm
Shipping Height
42.5 cm
Shipping Weight
8.03 kg
Sustainability Information
TCO Certified
EPEAT Compliant
EPEAT Gold
ENERGY STAR Certified
Carbon Footprint
Manufacturing (kg CO2e)
111
Logistics (kg CO2e)
3
Use (kg CO2e)
76
EOL (kg CO2e)
3
Total Carbon w/o Use Phase (kg CO2e)
190
Limited warranty - parts and labour - 3 years
5 °C
35 °C
20 - 80% (non-condensing)
Diagonal Size: 27in
Response Time: 5ms
Interfaces: VGA (HD-15)
Interfaces: HDMI
Brand: HP
