HP P27h G4 27" 1920x1080 5ms VGA HDMI DisplayPort IPS LED Monitor
Quicklinx: FRP9WS00 Mfr#: 7VH95AT#ABU
Diagonal Size: 27in
Max Resolution: 1920 x 1080
Response Time: 5ms
Speakers: Speaker(s)
Interfaces: DisplayPort, HDMI, VGA (HD-15)
More than 50 in stock
£154.93 ex VAT
£185.91 inc VAT
Give your content room to roam on the HP P27h G4 FHD Height Adjust Monitor. It combines business-class presentation features, comfort adjustability, stereo audio, and advanced connectivity in an affordable, contemporary design that's a standout on any desk.
  • Crisp images and clear sound for all your content
    Navigate documents and large spreadsheets and work in applications side by side on the 27-inch diagonal Full HD IPS screen with 1920 x 1080 resolution. Get convenient stereo audio at the display.
  • A beauty at any price
    Set a new style standard with a 3-sided micro-edge bezel for unlimited sightlines and virtually seamless multi-display1 setups. See the screen clearly from almost anywhere with 178° viewing angles.
HP P27h G4 - LED monitor - Full HD (1080p) - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class A+
Energy Consumption per Year
24 kWh
Power Consumption (On mode)
16.45 W
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080 at 75 Hz
Pixel Pitch
0.311 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 8000000:1 (dynamic)
Response Time
5 ms (grey-to-grey)
Input Connectors
HDMI, VGA, DisplayPort
Display Position Adjustments
Screen Coating
Anti-glare
62.01 cm x 21.16 cm x 49.86 cm
5.22 kg
English / United Kingdom
Environmental Standards
ENERGY STAR Qualified
Plug and Play, CSA, UL, VCCI, BSMI, NOM, TUV S, WHQL, CB, CCC, PSB, FCC, RoHS, ISO 9241-307, KCC, WEEE, ICES, MEPS, KC, CEL, EAC, CEL Grade 1, ISC, CP65, low halogen, DisplayPort 1.2, IEEE 1680, ISO 11469, ISO 1043
Display Type
Energy Class
Class A+
24 kWh
16.45 W
Diagonal Size
27"
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.311 mm
Pixel Per Inch
82
Brightness
250 cd/m²
Contrast Ratio
Response Time
5 ms (grey-to-grey)
Vertical Refresh Rate
48 - 75 Hz
Horizontal Refresh Rate
30 - 86 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Anti-glare
Backlight Technology
LED backlight
Colour Temperature
9300K, 5000K, 6500K
OSD Languages
Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Spanish, Dutch, Japanese
HDCP, 72% NTSC colour gamut, Low Blue Light Mode, Flicker Free technology, Color Calibrated, 3-sided micro-edge, 6-bit + A-FRC Color Depth
62.01 cm x 21.16 cm x 49.86 cm - with stand
5.22 kg
Audio
Speakers - stereo
Output Power / Channel
2 Watt
DisplayPort (HDCP) , HDMI (HDCP) , VGA , Audio line-in (mini-jack)
Mechanical
Tilt Angle
-5/+23
Swivel Angle
360
Rotation Angle
180
Height Adjustment
100 mm
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), arsenic free, mercury free
1 x VGA cable - 1.8 m , 1 x audio cable - 1.8 m
Backlight Life
30,000 hours
Security Slot Type
Kensington security slot
24 Watt
Power Consumption Stand by
0.3 Watt
Included Software
HP Display Assistant
Dimensions & Weight Details
With stand - width: 62.01 cm - depth: 21.16 cm - height: 49.86 cm - weight: 5.12 kg , Without stand - width: 62.01 cm - height: 37.14 cm - weight: 3.1 kg
Shipping Width
69.6 cm
Shipping Depth
19 cm
Shipping Height
45 cm
Shipping Weight
7.17 kg
ENERGY STAR Certified
ENERGY STAR Version
8.0
5 °C
35 °C
20 - 80% (non-condensing)
HP P27h G4 27 Bundle deal on HP P27h G4 27" 1920x1080 5ms VGA HDMI DisplayPort IPS LED Monitor
£254.10
Diagonal Size: 27in
Response Time: 5ms
Interfaces: HDMI
Interfaces: VGA (HD-15)
Brand: HP
Price Range Ex VAT: 150 - 300
