HP P27 G5 27" 1920x1080 5ms VGA HDMI DisplayPort IPS LED Monitor
Quicklinx: H9YKWS00 Mfr#: 64X69AA#ABU
Diagonal Size: 27in
Max Resolution: 1920 x 1080
Response Time: 5ms
Interfaces: DisplayPort, VGA (HD-15), HDMI
25 In Stock
£112.49 ex VAT
£134.98 inc VAT
Expand your view and your productivity with this 27-inch diagonal, FHD monitor when you're working from home or at the office. This sleek, sizeable monitor makes hybrid work easy and complete via a crisp, smooth screen and simple design, so you can do more everyday.
  • 75 Hz Refresh Rate
    Experience smooth, life-like video and clear detail with a 75hz refresh rate that provides fluid movement from frame to frame.
  • IPS Panel
    No matter where you stand, IPS technology ensures image accuracy and consistency across wide 178-degrees horizontal and vertical viewing angles.
  • Easy Joypad OSD Button
    It's never been easier to configure your display with Joypad OSD button to adjust brightness, resolution, and volume.
  • Low-Blue Light Mode
    Keep your eyes comfortable with subtly warmer display colors onscreen.
  • With the Environment in Mind
    Meeting the latest standards with EPEAT registered, ENERGY STAR and TCO certifications.
  • Thoughtful Product Packaging
    We use 100% recyclable packaging that meets recycling requirements, so it can stay out of the landfill.
HP P27 G5 - P-Series - LED monitor - Full HD (1080p) - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class E
Energy Consumption per Year
20 kWh
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080 at 75 Hz
Pixel Pitch
0.31 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 8000000:1 (dynamic)
Response Time
5 ms (grey-to-grey with overdrive)
Colour Support
16.7 million colours (8-bit)
Colour Gamut
72% NTSC
Input Connectors
HDMI, VGA, DisplayPort
Display Position Adjustments
Tilt
Screen Coating
Anti-glare, 3H Hard Coating, Haze 25%
Voltage
AC 100-240 V (50/60 Hz)
Black stand, black head
61.1 cm x 19.03 cm x 43.84 cm
5.08 kg
English / United Kingdom
Environmental Standards
TCO Certified Edge Displays, TCO Certified Displays 9, ENERGY STAR Qualified
Carbon Footprint
190 kg carbon emissions
CSA, UL, VCCI, C-Tick, BSMI, NOM, TUV S, CB, CCC, PSB, FCC, ISO 9241-307, KCC, WEEE, ICES, cTUVus, Energy-Related Products (ErP) Lot 6, TUV Bauart, CEC, KC, CECP, CEL, EAC, ISC, RCM, CEL Grade 2, BIS, Energy-Related Products (ErP) Lot 5, low halogen, DisplayPort 1.2, NRCS, Mexico Energy label, Taiwan BSMI RoHS, UAE, Mexico NOM, TÜV safety certification, Australian-New Zealand MEPS, Vietnam MEPS, South Africa Energy Label, Ukraine Energy Label, WW application, Argentina S-Mark, EuP Lot 26
3-year warranty
Display Type
Energy Class
Class E
20 kWh
Diagonal Size
27"
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.31 mm
Pixel Per Inch
82
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Colour Gamut
72% NTSC
Response Time
Vertical Refresh Rate
48 - 75 Hz
Horizontal Refresh Rate
30 - 86 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
Edge-lit LED
Colour Temperature
6500K
OSD Languages
Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Spanish, Dutch, Japanese
HDCP, Flicker Free technology, 3-sided micro-edge, Low Blue Light technology, edge-lit LED backlight, 8-bit(6-bit + FRC) Colour Depth
61.1 cm x 19.03 cm x 43.84 cm - with stand
5.08 kg
DisplayPort 1.2 (HDCP) , HDMI (HDCP) , VGA
Mechanical
Tilt
Tilt Angle
-5/+20
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), detachable stand, VESA interface support, HDCP Compliant
1 x HDMI cable - 1.8 m
Backlight Life
30,000 hours
Security Slot Type
Kensington security slot
Input Voltage
20 kWh/1000h
Power Consumption (Typical)
25 Watt
Power Consumption (Max)
35 Watt
Power Consumption Stand by
0.5 Watt
Included Software
HP Display Center, HP Display Manager
Microsoft Windows 7, Windows 8, Windows 10, Windows 11
Dimensions & Weight Details
With stand - width: 61.1 cm - depth: 19.03 cm - height: 43.84 cm - weight: 5.08 kg , Without stand - width: 61.1 cm - depth: 5.71 cm - height: 36.55 cm - weight: 4.43 kg
Shipping Width
68.5 cm
Shipping Depth
13.7 cm
Shipping Height
42.5 cm
Shipping Weight
7.64 kg
Sustainability Information
TCO Certified
ENERGY STAR Certified
Carbon Footprint
Manufacturing (kg CO2e)
108
Logistics (kg CO2e)
2
Use (kg CO2e)
81
EOL (kg CO2e)
3
Total Carbon w/o Use Phase (kg CO2e)
190
Limited warranty - parts and labour - 3 years
5 °C
35 °C
20 - 80% (non-condensing)
Diagonal Size: 27in
Response Time: 5ms
Interfaces: VGA (HD-15)
Interfaces: HDMI
Brand: HP
