HP P24v G4 23.8" 1920x1080 5ms VGA HDMI LED Monitor
Quicklinx: H1FSWS00 Mfr#: 64W18AA#ABU
Expand your view and your productivity with this 60.5 cm (23.8-inch) diagonal, FHD monitor when you're working from home or at the office. This sleek monitor makes hybrid work easy and complete via a crisp, smooth screen and simple design, so you can do more everyday.
  • 75 Hz Refresh Rate
    Experience smooth, life-like video and clear detail with a 75 Hz refresh rate that provides fluid movement from frame to frame.
  • 3-Sided Micro-Edge Bezel
    See and do more on your screen with a 3-sided micro-edge bezel that maximizes your viewing area for a sleek design and seamless dual-monitor setups.
  • Easy Joypad OSD Button
    It's never been easier to configure your display with the Joypad OSD button to adjust brightness, resolution, and volume.
  • Low Blue Light Mode
    Keep your eyes comfortable with subtly warmer display colors onscreen.
  • With the Environment in Mind
    Meeting the latest standards with EPEAT registered, ENERGY STAR and TCO certifications.
  • Thoughtful Product Packaging
    We use 100% recyclable packaging that meets recycling requirements, so it can stay out of the landfill.
HP P24v G5 - P-Series - LED monitor - Full HD (1080p) - 23.8"
LED-backlit LCD monitor - 23.8"
Energy Class
Class E
Power Consumption (On mode)
17.9 W
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080 at 75 Hz
Pixel Pitch
0.27 mm
Brightness
250 cd/m²
Contrast Ratio
3000:1 / 8000000:1 (dynamic)
Response Time
5 ms (grey-to-grey with overdrive)
Colour Support
16.7 million colours
Colour Gamut
72% NTSC
Input Connectors
HDMI, VGA
Display Position Adjustments
Tilt
Screen Coating
Anti-glare, 3H Hard Coating, Haze 25%
Voltage
AC 100-240 V (50/60 Hz)
Black stand, black head
53.89 cm x 18.05 cm x 39.78 cm
3.57 kg
English / United Kingdom
Environmental Standards
TCO Certified Edge Displays, TCO Certified Displays 9, ENERGY STAR Qualified
Carbon Footprint
190 kg carbon emissions
CSA, VCCI, BSMI, NOM, WHQL, CB, CCC, PSB, FCC, RoHS, ISO 9241-307, KCC, ICES, CEC, KC, ERP, CECP, CEL, EAC, ISC, CEL Grade 2, SEPA, low halogen, TUV Rheinland Flicker Free Certification, Energy-using Products (EuP) Lot 5, UAE, Australian-New Zealand MEPS, Vietnam MEPS
3-year warranty
Display Type
Energy Class
Class E
Diagonal Size
23.8"
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.27 mm
Pixel Per Inch
93
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Colour Gamut
72% NTSC
Response Time
Vertical Refresh Rate
48 - 75 Hz
Horizontal Refresh Rate
55.6 - 90.8 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
Edge-lit LED
Colour Temperature
6500K
OSD Languages
Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Russian, Spanish, Dutch, Japanese
HDCP, On-screen Digital Controls, Low Blue Light Mode, 3-sided micro-edge, edge-lit LED backlight, 8-bit(6-bit + FRC) Colour Depth
53.89 cm x 18.05 cm x 39.78 cm - with stand
3.57 kg
HDMI (HDCP) , VGA
Mechanical
Tilt
Tilt Angle
-5/+23
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), detachable stand, VESA interface support, HDCP Compliant
1 x HDMI cable - 1.8 m
Backlight Life
30,000 hours
Security Slot Type
Kensington security slot
Input Voltage
17.9 W
17.9 kWh/1000h
Power Consumption (Typical)
20 Watt
Power Consumption (Max)
30 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption (Off Mode)
0.3 Watt
Included Software
HP Display Center, HP Display Manager
Microsoft Windows 7, Windows 8, Windows 10, Windows 11
Dimensions & Weight Details
With stand - width: 53.89 cm - depth: 18.05 cm - height: 39.7 cm - weight: 3.57 kg , Without stand - width: 53.89 cm - depth: 5.143 cm - height: 32.36 cm - weight: 3.17 kg
Shipping Width
59.5 cm
Shipping Depth
12.4 cm
Shipping Height
39.1 cm
Shipping Weight
5.49 kg
Sustainability Information
TCO Certified
ENERGY STAR Certified
Carbon Footprint
Manufacturing (kg CO2e)
109
Logistics (kg CO2e)
2
Use (kg CO2e)
81
EOL (kg CO2e)
3
Limited warranty - parts and labour - 3 years
5 °C
35 °C
20 - 80% RH (non-condensing)
H1FS HP Care Pack Next Business Day Hardware Support Extended Service Agreement 4 Years On-Site In Stock £22.36
H1FS HP Care Pack Next Business Day Hardware Support Extended Service Agreement 5 Years On-Site In Stock £32.96
H1FS HP Care Pack Next Business Day Hardware Support Extended Service Agreement 1 Year On-Site In Stock £5.89
H1FS HP Care Pack Next Business Day Hardware Support Extended Service Agreement 3 Yrs On-Site for Monitor In Stock £10.59
