Expand your view and your productivity with this 60.5 cm (23.8-inch) diagonal, FHD monitor when you're working from home or at the office. This sleek monitor makes hybrid work easy and complete via a crisp, smooth screen and simple design, so you can do more everyday.
75 Hz Refresh Rate
Experience smooth, life-like video and clear detail with a 75 Hz refresh rate that provides fluid movement from frame to frame. -
3-Sided Micro-Edge Bezel
See and do more on your screen with a 3-sided micro-edge bezel that maximizes your viewing area for a sleek design and seamless dual-monitor setups. -
Easy Joypad OSD Button
It's never been easier to configure your display with the Joypad OSD button to adjust brightness, resolution, and volume. -
Low Blue Light Mode
Keep your eyes comfortable with subtly warmer display colors onscreen. -
With the Environment in Mind
Meeting the latest standards with EPEAT registered, ENERGY STAR and TCO certifications. -
Thoughtful Product Packaging
We use 100% recyclable packaging that meets recycling requirements, so it can stay out of the landfill.
 - HP P24v G5 - P-Series - LED monitor - Full HD (1080p) - 23.8"
 - LED-backlit LCD monitor - 23.8"
- Energy Class
 - Class E
- Power Consumption (On mode)
 - 17.9 W
- Panel Type
 - VA
- Aspect Ratio
 - 16:9
- Native Resolution
 - Full HD (1080p) 1920 x 1080 at 75 Hz
- Pixel Pitch
 - 0.27 mm
- Brightness
 - 250 cd/m²
- Contrast Ratio
 - 3000:1 / 8000000:1 (dynamic)
- Response Time
 - 5 ms (grey-to-grey with overdrive)
- Colour Support
 - 16.7 million colours
- Colour Gamut
 - 72% NTSC
- Input Connectors
 - HDMI, VGA
 - Tilt
- Screen Coating
 - Anti-glare, 3H Hard Coating, Haze 25%
- Voltage
 - AC 100-240 V (50/60 Hz)
 - Black stand, black head
 - 53.89 cm x 18.05 cm x 39.78 cm
 - 3.57 kg
- Localisation
 - English / United Kingdom
- Environmental Standards
 - TCO Certified Edge Displays, TCO Certified Displays 9, ENERGY STAR Qualified
- Carbon Footprint
 - 190 kg carbon emissions
 - CSA, VCCI, BSMI, NOM, WHQL, CB, CCC, PSB, FCC, RoHS, ISO 9241-307, KCC, WEEE, ICES, TUV Bauart, CEC, KC, ERP, CECP, CEL, EAC, ISC, CEL Grade 2, SEPA, BIS, low halogen, TUV Rheinland Flicker Free Certification, Energy-using Products (EuP) Lot 5, ICE, NRCS, UAE, Australian-New Zealand MEPS, Vietnam MEPS, TUV low blue light, WW application
 - 3-year warranty
- Display Type
- Energy Class
 - Class E
- Diagonal Size
 - 23.8"
- Panel Type
 - VA
- Aspect Ratio
 - 16:9
- Native Resolution
- Pixel Pitch
 - 0.27 mm
- Pixel Per Inch
 - 93
- Brightness
 - 250 cd/m²
- Contrast Ratio
- Colour Support
- Colour Gamut
 - 72% NTSC
- Response Time
- Vertical Refresh Rate
 - 48 - 75 Hz
- Horizontal Refresh Rate
 - 55.6 - 90.8 kHz
- Horizontal Viewing Angle
 - 178
- Vertical Viewing Angle
 - 178
- Screen Coating
- Backlight Technology
 - Edge-lit LED
- Colour Temperature
 - 6500K
- OSD Languages
 - Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Russian, Spanish, Dutch, Japanese
 - HDCP, On-screen Digital Controls, Low Blue Light Mode, 3-sided micro-edge, edge-lit LED backlight, 8-bit(6-bit + FRC) Colour Depth
 - 53.89 cm x 18.05 cm x 39.78 cm - with stand
 - 3.57 kg
 - HDMI (HDCP) , VGA
Mechanical
 - Tilt
- Tilt Angle
 - -5/+23
- VESA Mounting Interface
 - 100 x 100 mm
 - Security lock slot (cable lock sold separately), detachable stand, VESA interface support, HDCP Compliant
- Cables Included
 - 1 x HDMI cable - 1.8 m
- Backlight Life
 - 30,000 hours
- Localisation
- Security Slot Type
 - Kensington security slot
- Input Voltage
 - 17.9 W
- Power Consumption SDR (On mode)
 - 17.9 kWh/1000h
- Power Consumption (Typical)
 - 20 Watt
- Power Consumption (Max)
 - 30 Watt
- Power Consumption Stand by
 - 0.5 Watt
 - 0.3 Watt
- Included Software
 - HP Display Center, HP Display Manager
- OS Required
 - Microsoft Windows 7, Windows 8, Windows 10, Windows 11
- Dimensions & Weight Details
 - With stand - width: 53.89 cm - depth: 18.05 cm - height: 39.7 cm - weight: 3.57 kg , Without stand - width: 53.89 cm - depth: 5.143 cm - height: 32.36 cm - weight: 3.17 kg
- Shipping Width
 - 59.5 cm
- Shipping Depth
 - 12.4 cm
- Shipping Height
 - 39.1 cm
- Shipping Weight
 - 5.49 kg
Sustainability Information
- TCO Certified
- ENERGY STAR Certified
- Carbon Footprint
- Manufacturing (kg CO2e)
 - 109
- Logistics (kg CO2e)
 - 2
- Use (kg CO2e)
 - 81
- EOL (kg CO2e)
 - 3
- Total Carbon w/o Use Phase (kg CO2e)
 - 190
 - Limited warranty - parts and labour - 3 years
 - 5 °C
 - 35 °C
 - 20 - 80% RH (non-condensing)
