Expand your view and your productivity with this 60.5 cm (23.8-inch) diagonal, FHD monitor when you're working from home or at the office. This sleek monitor makes hybrid work easy and complete via a crisp, smooth screen and simple design, so you can do more everyday.
75 Hz Refresh Rate
Experience smooth, life-like video and clear detail with a 75 Hz refresh rate that provides fluid movement from frame to frame. -
3-Sided Micro-Edge Bezel
See and do more on your screen with a 3-sided micro-edge bezel that maximizes your viewing area for a sleek design and seamless dual-monitor setups. -
Easy Joypad OSD Button
It's never been easier to configure your display with the Joypad OSD button to adjust brightness, resolution, and volume. -
Low Blue Light Mode
Keep your eyes comfortable with subtly warmer display colors onscreen. -
With the Environment in Mind
Meeting the latest standards with EPEAT registered, ENERGY STAR and TCO certifications. -
Thoughtful Product Packaging
We use 100% recyclable packaging that meets recycling requirements, so it can stay out of the landfill.
- HP P24v G5 - P-Series - LED monitor - Full HD (1080p) - 23.8"
- LED-backlit LCD monitor - 23.8"
- Energy Class
- Class E
- Power Consumption (On mode)
- 17.9 W
- Panel Type
- VA
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 75 Hz
- Pixel Pitch
- 0.27 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 3000:1 / 8000000:1 (dynamic)
- Response Time
- 5 ms (grey-to-grey with overdrive)
- Colour Support
- 16.7 million colours
- Colour Gamut
- 72% NTSC
- Input Connectors
- HDMI, VGA
- Tilt
- Screen Coating
- Anti-glare, 3H Hard Coating, Haze 25%
- Voltage
- AC 100-240 V (50/60 Hz)
- Black stand, black head
- 53.89 cm x 18.05 cm x 39.78 cm
- 3.57 kg
- Localisation
- English / United Kingdom
- Environmental Standards
- TCO Certified Edge Displays, TCO Certified Displays 9, ENERGY STAR Qualified
- CSA, VCCI, BSMI, NOM, WHQL, CB, CCC, PSB, FCC, RoHS, ISO 9241-307, KCC, ICES, CEC, KC, ERP, CECP, CEL, EAC, ISC, CEL Grade 2, SEPA, low halogen, TUV Rheinland Flicker Free Certification, Energy-using Products (EuP) Lot 5, UAE, Australian-New Zealand MEPS, Vietnam MEPS
- 3-year warranty
- Display Type
- Energy Class
- Class E
- Diagonal Size
- 23.8"
- Panel Type
- VA
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.27 mm
- Pixel Per Inch
- 93
- Brightness
- 250 cd/m²
- Contrast Ratio
- Colour Support
- Colour Gamut
- 72% NTSC
- Response Time
- Vertical Refresh Rate
- 48 - 75 Hz
- Horizontal Refresh Rate
- 55.6 - 90.8 kHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Backlight Technology
- Edge-lit LED
- Colour Temperature
- 6500K
- OSD Languages
- Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Russian, Spanish, Dutch, Japanese
- HDCP, On-screen Digital Controls, Low Blue Light Mode, 3-sided micro-edge, edge-lit LED backlight, 8-bit(6-bit + FRC) Colour Depth
- 53.89 cm x 18.05 cm x 39.78 cm - with stand
- 3.57 kg
- HDMI (HDCP) , VGA
Mechanical
- Tilt
- Tilt Angle
- -5/+23
- VESA Mounting Interface
- 100 x 100 mm
- Security lock slot (cable lock sold separately), detachable stand, VESA interface support, HDCP Compliant
- Cables Included
- 1 x HDMI cable - 1.8 m
- Backlight Life
- 30,000 hours
- Localisation
- Security Slot Type
- Kensington security slot
- Input Voltage
- 17.9 W
- Power Consumption SDR (On mode)
- 17.9 kWh/1000h
- Power Consumption (Typical)
- 20 Watt
- Power Consumption (Max)
- 30 Watt
- Power Consumption Stand by
- 0.5 Watt
- 0.3 Watt
- Included Software
- HP Display Center, HP Display Manager
- OS Required
- Microsoft Windows 7, Windows 8, Windows 10, Windows 11
- Dimensions & Weight Details
- With stand - width: 53.89 cm - depth: 18.05 cm - height: 39.7 cm - weight: 3.57 kg , Without stand - width: 53.89 cm - depth: 5.143 cm - height: 32.36 cm - weight: 3.17 kg
- Shipping Width
- 59.5 cm
- Shipping Depth
- 12.4 cm
- Shipping Height
- 39.1 cm
- Shipping Weight
- 5.49 kg
Sustainability Information
- TCO Certified
- ENERGY STAR Certified
- Limited warranty - parts and labour - 3 years
- 5 °C
- 35 °C
- 20 - 80% RH (non-condensing)
HP Care Pack Next Business Day Hardware Support Extended Service Agreement 4 Years On-Site | In Stock | £22.87 |
HP Care Pack Next Business Day Hardware Support Extended Service Agreement 5 Years On-Site | In Stock | £33.70 |
HP Care Pack Next Business Day Hardware Support Extended Service Agreement 1 Year On-Site | In Stock | £6.01 |
HP Care Pack Next Business Day Hardware Support Extended Service Agreement 3 Yrs On-Site for Monitor | In Stock | £10.83 |
