HP P24v G4 23.8" 1920x1080 5ms VGA HDMI IPS LED Monitor
Quicklinx: GPFFWS00 Mfr#: 9TT78AA#ABU
Tackle your daily to-do list and multi-task across multiple windows on the on the large-screen HP P24v G4 Monitor that adjusts to your comfort needs and delivers Full HD picture quality with clear 178° sightlines.
  • Make conscientious buying choices
    Choose a monitor that's TCO and ENERGY STAR certified to help meet your environmental buying requirements.
  • Personalize your comfort settings
    See your screen in a whole new light with HP Low Blue Light, which shifts the color spectrum for more comfortable viewing. Tilt the screen up to 5° forward or 20° back to find your best viewing position.
  • We have your back
    Rest assured that your IT investment has a long lifecycle and is supported with our three-year standard limited warranty. To extend your protection, select an optional HP Care Pack service.
HP P24v G4 - P-Series - LED monitor - Full HD (1080p) - 23.8"
LED-backlit LCD monitor - 23.8"
Energy Class
Class D
Energy Consumption per Year
24 kWh
Power Consumption (On mode)
13.2 W
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2745 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 8000000:1 (dynamic)
Response Time
5 ms (grey-to-grey with overdrive)
Colour Gamut
72% NTSC
Input Connectors
HDMI, VGA
Display Position Adjustments
Tilt
Screen Coating
Anti-glare 3H hardness
Voltage
AC 100-240 V (50/60 Hz)
53.96 cm x 18.61 cm x 40.5 cm
3.46 kg
English / United Kingdom
Environmental Standards
ENERGY STAR Qualified
TUV, VCCI, C-Tick, BSMI, WHQL, CB, CCC, PSB, FCC, ISO 9241-307, KCC, Energy-using Products (EuP) Lot 6, WEEE, cTUVus, TUV Bauart, E-Standby, CEC, UkrSEPRO, KC, CECP, CEL, EAC, ISC, CEL Grade 2, SEPA, BIS, Energy-using Products (EuP) Lot 5, NOM-NYCE, ICE, Australian-New Zealand MEPS, Vietnam MEPS, Mexico MEPS, South Africa MEPS, Ukraine Energy Label, TGM, Japan PC Green Label
3-year warranty
Display Type
Energy Class
Class D
24 kWh
Diagonal Size
23.8"
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2745 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Gamut
72% NTSC
Response Time
Vertical Refresh Rate
50 - 60 Hz
Horizontal Refresh Rate
30 - 80 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
LED backlight
Colour Temperature
6500K
OSD Languages
Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Spanish, Dutch, Japanese
Low Blue Light Mode, Flicker Free technology, Mercury free, arsenic-free glass, 3-sided micro-edge, 72% NTSC colour gamut
53.96 cm x 18.61 cm x 40.5 cm - with stand
3.46 kg
HDMI , VGA
Mechanical
Tilt
Tilt Angle
-5/+22
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), detachable stand, VESA interface support
1 x VGA cable - 1.5 m
Backlight Life
30,000 hours
Security Slot Type
Kensington security slot
Input Voltage
13.2 W
13.2 kWh/1000h
Power Consumption (Typical)
26 Watt
Power Consumption Stand by
0.5 Watt
Dimensions & Weight Details
With stand - width: 53.96 cm - depth: 18.61 cm - height: 40.5 cm - weight: 3.46 kg , Without stand - width: 53.96 cm - depth: 4.76 cm - height: 32.5 cm - weight: 3.14 kg
Shipping Width
58.8 cm
Shipping Depth
12.3 cm
Shipping Height
37.3 cm
Shipping Weight
4.7 kg
Sustainability Information
ENERGY STAR Certified
Limited warranty - parts and labour - 3 years
5 °C
35 °C
20 - 80% (non-condensing)
GPFF HP Care Pack Next Business Day Hardware Support Extended Service Agreement 4 Years On-Site In Stock £22.36
GPFF HP Care Pack Next Business Day Hardware Support Extended Service Agreement 5 Years On-Site In Stock £32.96
GPFF HP Care Pack Next Business Day Hardware Support Extended Service Agreement 1 Year On-Site In Stock £5.89
GPFF HP Care Pack Next Business Day Hardware Support Extended Service Agreement 3 Yrs On-Site for Monitor In Stock £10.59
