HP P24h G5 23.8" 1920x1080 5ms VGA HDMI DisplayPort IPS LED Monitor
Quicklinx: HB7RWS00 Mfr#: 64W34AA#ABU
Diagonal Size: 23.8in
Max Resolution: 1920 x 1080
Response Time: 5ms
Speakers: Speaker(s)
Interfaces: DisplayPort, HDMI, VGA (HD-15)
11 In Stock
£106.81 ex VAT
£128.17 inc VAT
Expand your view and your productivity with this 60.5 cm (23.8-inch) diagonal, FHD monitor when you're working from home or at the office. This sleek monitor makes hybrid work easy and complete via a crisp, smooth screen, built-in audio, and simple design, so you can do more everyday.
  • 75 Hz Refresh Rate
    Experience smooth, life-like video and clear detail with a 75 Hz refresh rate that provides fluid movement from frame to frame.
  • Adjustable Tilt and Height
    The tilt and 100 mm height-adjustable stand helps deliver the perfect view to maximize productivity.
  • Built-In Dual 2W Speakers
    Listen to music, meetings and more with the built-in, dual 2W speakers.
  • 3-Sided Micro-Edge Bezel
    See and do more on your screen with a 3-sided micro-edge bezel that maximizes your viewing area for a sleek design and seamless dual-monitor setups.
  • Easy Joypad OSD Button
    It's never been easier to configure your display with the Joypad OSD button to adjust brightness, resolution, and volume.
  • Low Blue Light Mode
    Keep your eyes comfortable with subtly warmer display colors onscreen.
HP P24h G5 - LED monitor - Full HD (1080p) - 23.8"
LED-backlit LCD monitor - 23.8"
Energy Class
Class E
Power Consumption (On mode)
15 W
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080 at 75 Hz
Pixel Pitch
0.2744 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 8000000:1 (dynamic)
Response Time
5 ms (grey-to-grey with overdrive)
Colour Gamut
72% NTSC
Input Connectors
HDMI, VGA, DisplayPort
Display Position Adjustments
Height, tilt
Screen Coating
Anti-glare
Voltage
(50/60 Hz)
53.89 cm x 19.64 cm x 46.92 cm
4.6 kg
English / United Kingdom
Environmental Standards
TCO Certified Edge Displays, TCO Certified Displays 9, ENERGY STAR Qualified
Carbon Footprint
170 kg carbon emissions
VCCI, WHQL, CB, CCC, PSB, FCC, RoHS, KCC, ICES, cTUVus, Energy-Related Products (ErP) Lot 6, TUV Bauart, CEC, KC, ERP, CECP, CEL, EAC, CEL Grade 1, ISC, RCM, CEL Grade 2, SEPA, BIS, low halogen, TUV Rheinland Flicker Free Certification, NRCS, EU RoHS, Mexico Energy label, Taiwan BSMI RoHS, Energy-using Products (EuP) Lot 26, UAE, Mexico NOM, Australian-New Zealand MEPS, Vietnam MEPS, South Africa Energy Label, Ukraine Energy Label, Australia MEPS, TUV low blue light, WW application, Argentina S-Mark, EuP Lot 26
3-year warranty
Display Type
Energy Class
Class E
Diagonal Size
23.8"
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2744 mm
Pixel Per Inch
93
Brightness
250 cd/m²
Contrast Ratio
Colour Gamut
72% NTSC
Response Time
Vertical Refresh Rate
48 - 75 Hz
Horizontal Refresh Rate
30 - 86 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Anti-glare
Backlight Technology
LED backlight
Colour Temperature
6500K
OSD Languages
Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Russian, Spanish, Dutch, Japanese
HDCP, Frame Rate Control (FRC), On-screen Digital Controls, Low Blue Light Mode, Flicker Free technology, 3-sided micro-edge
53.89 cm x 19.64 cm x 46.92 cm - with stand
4.6 kg
Audio
Speakers - stereo
Output Power / Channel
2 Watt
DisplayPort (HDCP) , HDMI (HDCP) , VGA
Mechanical
Height, tilt
Tilt Angle
-5/+23
Height Adjustment
100 mm
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), detachable stand, VESA interface support
1 x VGA cable - 1.8 m , 1 x HDMI cable - 1.8 m
Backlight Life
30,000 hours
Security Slot Type
Kensington security slot
Input Voltage
(50/60 Hz)
15 W
15 kWh/1000h
Power Consumption (Typical)
18 Watt
Power Consumption (Max)
28 Watt
Power Consumption Stand by
0.5 Watt
Included Software
HP Display Center, HP Display Manager
Dimensions & Weight Details
With stand - width: 53.89 cm - depth: 19.64 cm - height: 46.92 cm - weight: 4.6 kg , Without stand - width: 53.89 cm - depth: 5.15 cm - height: 32.36 cm - weight: 3.38 kg
Shipping Width
59.5 cm
Shipping Depth
12.4 cm
Shipping Height
39.1 cm
Shipping Weight
6.74 kg
Sustainability Information
TCO Certified
ENERGY STAR Certified
Carbon Footprint
Manufacturing (kg CO2e)
91
Logistics (kg CO2e)
2
Use (kg CO2e)
73
EOL (kg CO2e)
2
Total Carbon w/o Use Phase (kg CO2e)
170
Limited warranty - parts and labour - 3 years
5 °C
35 °C
20 - 80% RH
Response Time: 5ms
Interfaces: HDMI
Interfaces: VGA (HD-15)
Brand: HP
